Mysterious 'grease' under BB
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 268 Post(s)
Liked 80 Times
See, on the plastic thing w/grooves? It tends to make shifting sluggish. Where did it come from? Been appearing for cpl months; after a ride. Fix is easy- degreaser > toothbrush > rinse > dry. Never happened before on any bike. Happens mostly on the Masi, shown, but also on the Kona.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1306 Post(s)
Liked 750 Times
"Never happened before on any bike."
wanna bet on that statement?
possible sources? An over-greased Seat Post... an over-greased Headset... and, the Most Likely, an over-greased Bottom Bracket.
keep wiping and cleaning.. cleaning a bike by hand with a rag is the best way to inspect a bike for problems... and don't forget to wipe each spoke too.. it's a great way to feel a loose spoke before it causes a bigger problem.....
Likes For maddog34:
Quoted: 268 Post(s)
Liked 80 Times
Yea, I thought about over greased BB, but the BB has been there for years; this problem has only been going on for cpl months.
Forgot to mention, theres a lot of crud coming down the DT- like from the water bottle. So now, I am extra vigilant about preventing the bottle from leaking- doesnt seem to make any difference.
Quoted: 6350 Post(s)
Liked 4,948 Times
Check your plastic thingy with the grooves (BB cable guide) and make sure the cables aren't sawing into it. The grease and/or oil is probably coming from as previously suggested by another and likely it's just attracting grit from the road which is what really is making the shifting sluggish in the narrow grove they've sawed for themselve.
The plastic thingy (BB cable guide) only cost me $2.00 last time I needed one.
If it is in fact something from your bottles, then maybe it's the sugar in it getting sticky as it dries. I constantly am cleaning my dried hydration mix and salt from my sweat off all the tubes of my bike and the BB.
Likes For Iride01:
Quoted: 569 Post(s)
Liked 426 Times
If the OP is complaining about this, it means they aren't washing their bike enough, ever.
I mean, is it even grease at all?
I was components on my bikes religously.
Old toothbrushes are my friends.
Quoted: 1635 Post(s)
Liked 2,727 Times
You use an energy drink? I wouldn't think grease would make it sluggish. I'm going with a leaky water bottle.
Quoted: 3639 Post(s)
Liked 3,064 Times
You're got a lot going on with that down tube. Are you sure something else isn't interfering with the cables and causing the sluggish shifting?
