Raleigh Super Grand Prix
Likes For JFHenry:
Bikes: 1984 Gitane TdF, 1986 Look Équipe, 1983 Colnago Super
Liked 167 Times
You just need to commit enough to this place to make 10 posts.
1. Write back and tell us how you got your Raleigh.
2. Write again to tell us about where you like to ride it.
3. Someone will respond and ask for details.
4. Respond to them.
5. Write again to tell us if bicycling helps your recovery from cancer. It does for me, and plenty others here too.
6. Respond, and before you know it you'll be sharing pictures of your bike and rides.
Here's a picture of my buddy's Raleigh,
4. Respond to them.
Likes For cyclic_eric:
They will take most common stems but originally they had a GB Forged stem . If you have a local bike shop that has been around a while , or even a co-op , they should have something that will get you going. If you have the handlebars , make sure to check the clamping diameter because that will vary. Take the handlebars with you if you don’t have calipers to measure. The steering tube on the Super Grand Prix is standard English.
Likes For Kabuki12:
I wish I had a local shop, I can’t get brake pads locally. I have all the parts, the stem is cracked, probably over tightened.
So far the bike groups I have found in the area are mountain bike stuff.
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Liked 757 Times
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Likes For tiger1964:
Likes For JFHenry:
Liked 167 Times
25.4 most likely refers to the handlebar diameter. So the clamp of the stem onto the handlebar is designed for that 25.4mm (1 inch) diameter.
90mm generally refers to the length of the stem along its top, measuring from the quill-draw bolt (the vertical bolt that goes into the steering fork) to the center of the handlebar.
There are plenty of stem length options available, generally from 50mm to 150mm long, depending on which will fit you and the bike best.
The stem can also be raised up and down of course, making sure you don't raise it above the limit line marked on the shaft of the stem.
Stems also come in longer vertical lengths to allow the stem to raise up higher.
You'll have to gauge what you'll want to make the bike most comfortable - a very worthy pursuit.
Thanks for the information.
Never thought about fit much more than adjusting seat height when I was a kid.
I guess it won’t matter which size I start with because I don’t know what I need. Sounds like how I start most projects. 😂
Likes For JFHenry:
Liked 167 Times
I can't begin to tell you how much time I've spent adjusting my fit to the bike. But it's worth it! The feel between rider and machine is a great pursuit. Sure the seat adjusts up and down, but also fore and aft, and the critically important tilt. Gotta keep the boys happy.
I don't see a Raleigh catalog for 1980 online, but here is one for 1979:
Raleigh Catalogs
Also another related bike forum thread from 2019:
Super Grand Prix serial numbers...
Raleigh Catalogs
I have a 1978 Super Grand Prix in one of my sheds , so probably very similar to the OP’s bike. I just can’t remember the length of the stem. I DO remember seeing the GB Forged detail embossed on the sides. If I were to guess from memory , I would say about 90mm. The handlebars are unmarked but most likely GB as well. There is probably markings and or date stamp under the bar tape near the end of the bar.
Señor Member
Pic assist:
Hard to see stem details
Are bar-end shifters standard on the Raleigh Record? I'm asking because I am trying to ID my old 1979 Raleigh, and that has downtube shifters.
cyclic_eric;22918340]I can't begin to tell you how much time I've spent adjusting my fit to the bike. But it's worth it! The feel between rider and machine is a great pursuit. Sure the seat adjusts up and down, but also fore and aft, and the critically important tilt. Gotta keep the boys happy.
I need to learn more about fit, I’m also dealing with degenerative spinal disease and have a spinal fusion.
Likes For JFHenry:
Señor Member
Liked 1,191 Times
Bar-ends entered the Raleigh realm with the 1978 SuperCourse (I got a new one - stock back in the day). As the Super Grand Prix was pretty much a Super Course frame (made with tubing that was a step down from 531 in the three main tubes), and fitted with essentially the same components as the Super Course, it doesn't surprise me that the author's SGP has them.
I think I may have introduced some confusion. I was referring to the picture from CO_Hoya, which you said was your bike, a Record. And that picture has bar-end shifters. My bike, which might be a Record, has never had bar-end shifters. Hence my question.
For what it is worth, my serial number is W I 9 0 0 0 2 3 7, so made in Worksop in the ninth fortnight of 1979, but I'm not sure what specific model it is. The main distinguishing features seem to be the "suicide" brake levers (as in the picture) and pump lugs under the crossbar tube. The stem is GB-forged, with Maillard hubs, Sachs-Huret downtube shifter mount and Suntour 6-speed freewheel.
I'll be posting pictures as soon as I have permission.
Likes For JFHenry:
Mine also has SunTour bar end shifters with spiral wound steel cables and brake “noodles”. The wheels were Wienman 700c with HF Normandy hubs . I put a set of Mavic rims and LF Campagnolo Record hubs. My daughter rode the bike for a few years and loved it so when she moved away I put it in a shed for safe keeping in case she ever wanted to get back into riding it. I keep thinking I will get it out , tune it up , and ride it every once in a while.
Fond memories
Fond memories
Likes For Kabuki12:
Nice to have those memories.
I had a Grand Prix as a kid, probably put 10,000 miles on that thing. The SGP was like the holy grail back then.
I wish I knew more about the details and parts, life got in the way and I was away from riding for a long time, still got the bug.
Likes For JFHenry:
