Is this top tube dent fatal?
Well, I was really excited about this frame, but I just got it stripped down to rebuild and noticed a quarter size dent underneath the top tube. It's Reynolds 501 tubing (84 trek 520).
I'm shocked I didn't notice it before. I've been staring at this bike for.months planning the rebuild so part of me suspects I somehow did this while I was removing the headset today. Then again, it's on an area that's painted over with touch up paint or nail polish, so they could have tried to paint over the damage before, or maybe the paint is covering rust which weakened the tube and being in the stand applied enough pressure to crimp it.
Does anyone have an opinion on if this dent is fatal and/or a safety concern? If I take it to a shop and ask I'm pretty sure they will just tell me not to ride it because they don't want to be held liable. But you, internet patron, do not have that concern, so give it to me straight and tell me if you'd still ride it
Quoted: 996 Post(s)
Liked 594 Times
Looks like it's been there a while, and it's a steel frame. I wouldn't worry about it. I might clean it up and touch up the paint so it would be easier to tell if any cracks started forming, but it doesn't seem like an existential threat to me.
Quoted: 7161 Post(s)
Liked 11,359 Times
A small dent like that on the TT is no big deal.
Likes For Koyote:
aged to perfection
Quoted: 867 Post(s)
Liked 1,308 Times
I agree. what kind of frame ? or tubing? it's not a superlight tube (like 531SL)
I think it is non catastrophic. don't worry too much about it
/markp
/markp
Hey Mark, thanks for the reply. This is Cliff from CR by the way. I actually looked at some of your old posts in the CR archive before posting here. It's Reynolds 501. I don't really care about it cosmetically, I just don't want my top tube to snap in half while I'm riding down a hill
aged to perfection
Quoted: 867 Post(s)
Liked 1,308 Times
somewhere I'd bet there's a finite element simulation where a circular tube is subjected to a load and then the size or radial span (subtended angle) of the dent increases till it fails.
I think we'd both be surprised at how big the dent has to be to seriously compromise the strength.
these things happen. ride and enjoy
/markp
Quoted: 6377 Post(s)
Liked 4,974 Times
It's unlikely to suddenly snap apart. If it does surprise you like that, then it's because you didn't pay it any attention while a crack was developing over some unknown period of time.
As a general thing any time one is cleaning, airing up the tires or otherwise just admiring the bike, one should also look to see if somethings is different than it was before with the bike. Whether it's a dent or a part of the frame that was formerly in pristine condition.
Likes For Iride01:
Quoted: 5986 Post(s)
Liked 2,918 Times
Fatal? To you or to the bike?
Seriously, and discussion of tube damage in bike frames has to start with location. There's a world of difference between a dent near the head tube, and the same dent in the middle or the opposite end. Then depth and shape matter, as does the cause, if known. A buckle or upset or dent with a sharp crease is more serious than a clean dent as might happen if the bike falls against a lamp post.
As best as I can from the photos, the dent isn't in a bad place, and is shallow enough to be ignored, except for rust potential if the paint is coming off. High end race bikes have suffered similar dents from handlebars hitting the frame, and ridden for years with no issues.
If it bothers you, fill it with some body filler, and cover with some kind of decal or trim. Or do as an old riding buddy of mine did ----- put a band aid over it.
FB
Chain-L site
FB
Chain-L site
I’m a little Surly
Bikes: Two Cross Checks, Karate Monkey, Disc Trucker, and a VO Randonneur
Quoted: 699 Post(s)
Liked 1,304 Times
On my phone that looks like a rust hole, I’d strip the paint and look
Old fart
Quoted: 3617 Post(s)
Liked 3,456 Times
Likes For JohnDThompson:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1314 Post(s)
Liked 763 Times
i'd be more worried about the rust that that dent... the rust runs for quite a distance away from the dent, btw... look at the rough paint as a clue to the extent of the rust....
here's a chart showing weights and tubing thicknesses from Reynolds....
https://equusbicycle.com/bike/reynold...80brochure.jpg
- 501 - Reynolds 501 was a chromium-molybdenum (CrMo) steel, seamed, butted 3-tubes tubeset that made its debut about 1983 and was available in two different thicknesses.
- 501ATB - Mountain, All terrain, Off-road
- 501 Magnum - Same use as ATB
- 501SB - Single Butted
- 501SL - Special lightweight (SL) tubeset
Likes For maddog34:
Clark W. Griswold
Quoted: 4521 Post(s)
Liked 4,220 Times
Visually ugly and should be cleaned and dressed up with some paint but not fatal. Though me personally I probably wouldn't want to ride it unless I made the dent but that is just me being me. I think it probably has been there a while and will continue to be there a while and so long as you keep a good eye on it and maybe take some photos once you remove paint and then one of it painted and then just keep doing that over the months and years and check to see if it changes you will be fine.
The rust would be my biggest concern but I would look over the entire frame and make sure there is nothing else lurking.
Quoted: 575 Post(s)
Liked 618 Times
I agree with others that rust is not good and would look for local help if possible. Your worry with a shop may be valid but we have a one man shop in Portland who can be relied on to give it to you straight even if he is out the examination time and no repairs. Also In Tucson we have a frame builder who I have seen do that for myself and others. If he thought it safe he would clean that up, fill it and try to match the paint best he can with his stash of paint for a reasonable price.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3948 Post(s)
Liked 6,638 Times
Yuck. File/sand away all that nastiness between the red marks really well and follow up with naval jelly. Then take another pic.
Likes For SurferRosa:
Quoted: 1165 Post(s)
Liked 1,846 Times
You can press a lot of that dent with a removable face place stem. If it, the clamp, is the same size as the tube. You could roll it to, but that would strip the paint.
Coincidentaly, here is just that on a trek 520 made of Reynolds 501.
Not bad from dent to ding
Likes For Mr. 66:
Randomhead
Liked 3,802 Times
I almost never say this, but I would strip the paint from the dented area. It's about to fall off anyway. No more paint than the edges of the dent. Steel does crack from dents, and if any dent in history was going to crack, this one is it.
Likes For unterhausen:
This is unrelated, but I'm annoyed because I overpaid for this bike ($400). I knew I was overpaying, but I hate being the craigslist guy who shows up and haggles, so I just paid the money because I knew I really wanted this specific frame with the canti mounts and I'd been looking for awhile without finding one in my size.
However, Im very annoyed with myself that I didn't do a more thorough inspection before handing the cash over. I checked everything to make sure it functioned, pulled the stem and seatpost loose, etc. But somehow missed this.
It's all good in the end and a good learning experience. Just annoying! I'll probably put a saved search back up so that if another in better shape comes along, I can ride that one without the worry and re-home this one for a great price. I bought about $1k worth of non-frame parts to go on the build so it would be a shame to put all that on a bike I always have second thoughts about riding hard, even if those second thoughts are unfounded and the bike is probably fine. Or who knows, maybe I'll get to riding it and it will never give me trouble and I will just forget eventually. Time will tell.
I'll follow up when I've stripped the paint and took more photos.
Likes For J_Climacus:
Ok, I got the touch up paint mostly scraped off. For whatever reason, they slathered the paint on there even though the damage to the paint wasn't even that bad. The bubbly texture appears to have been just paint, not rust. That or it was a Rust-Oleum type product that was applied to what was at one point rust but did it's job and kept it from spreading.
The dent does have slight creasing. Tough to get a picture of but it makes me think the dent may not roll out that well if I attempt it. I may try the stem trick mentioned above, but due to the shape of the dent I'm not that optimistic about it.
All in all, it is not as bad under the surface as the touch up paint made it appear, but I'm still bummed and may try to source a frame without a dent. This strikes me as a dent, not a ding. In the meantime I will probably build this up like I intended to, though.
Old fart
Liked 3,456 Times
I don't think you have anything to worry about. The rust looks superficial, and the dent is far enough from the stressed area (head tube) to not be a serious concern. Steel does not fail catastrophically, and if/when it does fail, you'll have ample warning.
Speaking as a structural engineer, I've no concern for this. We deal with a similar situation often where forklifts run into building columns.
Between the frame joints, the frame is not working terribly hard. Most of the bending stress in the top tube is located near the joints which is why the strategy of butting increasingly thin tubing together as one moves away from the joints is effective. I'm pretty confident that the dent could just as easily be a hole and it would still make little difference. And that's good because, structurally, the dent may not be a whole lot better than a hole.
Likes For Harold74:
