Sodium Hydroxide to strip anodization off rims?
I know any removal of anodization will late a layer of material with it, but will the lye weaken the rim in any other way? I'm mainly worried about chemical reaction.
Quoted: 573 Post(s)
Liked 434 Times
Sodium Hydroxide is what is used to strip off anodized car mags and motorcycle parts, so would also apply to your rims.
It might be a good idea to strip the wheel down to just the rim, hub and spokes removed.
Likes For soyabean:
Bikes: a couple
Quoted: 563 Post(s)
Liked 871 Times
Lye will eat anything right up to and including dental fillings. It is an alkali. I've used t a lot to remove ugly anno before polishing. After using, make sure you neutralize the lye before proceeding. Vinegar in a spray bottle followed with water works.
Quoted: 4245 Post(s)
Liked 3,990 Times
Having seen a number of home stripped anodizing results I will only add that don't be surprised if the rim looks pretty bad after. If the rim has eyelets take a lot of care rinsing the lye off there. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Mad bike riding scientist
Quoted: 6296 Post(s)
Liked 4,333 Times
Sodium hydroxide is more highly reactive with the aluminum than with the aluminum oxide layer that makes up the anodized surface. That is likely the cause of the poor results. Because of the higher reaction rate for aluminum, I would also be dubious about the strength of a thin aluminum part like a rim following treatment. There is no way to preferentially control the reaction.
Stuart Black
Stuart Black
Bikes: a couple
Quoted: 563 Post(s)
Liked 871 Times
Garbage bag and oven cleaner were the method used. Oven cleaner is lye based but not pure lye. Does the job without the scars of leaving it in too long. If you don't neutralize the lye, it will keep eating.
Your mileage may vary.
The wheel has to be dissembled.
Liked 4,333 Times
Been doing this since the 70's. Done 15 or 20 rims with no issue.
As to the process, no matter what the concentration of sodium hydroxide, it will react with the aluminum more readily and at a higher rate than with the aluminum oxide. The result will be an unknown change in the structure of the rim. Further, sodium hydroxide may not even be removing the anodized layer since conditions to form the sodium aluminate are quite severe. It’s more likely that the dye used on anodized rims is being decolored rather than the anodized layer is being removed.
Stuart Black
Stuart Black
Likes For cyccommute:
Clark W. Griswold
Quoted: 4527 Post(s)
Liked 4,230 Times
The real question is why do you keep buying anodized rims? Lots of rims out there that aren’t anodized.
Bikes: a couple
Quoted: 563 Post(s)
Liked 871 Times
It was mostly for friends. When you can get one blue outer and one green one, you make them both shiny.
Other times it was when could get one dark anno and one something else. mostly from need
Likes For Schweinhund:
ignominious poltroon
Quoted: 2319 Post(s)
Liked 3,548 Times
Likes For Polaris OBark:
Liked 3,548 Times
I ruined a centrifuge rotor (by accident) with a sodium hydroxide spill. I wouldn't take a chance on wheels I cared about (which is any wheel that I would ride).
Quoted: 996 Post(s)
Liked 596 Times
It might seem that it keeps going, but the reaction will stop when all of one (or more) of the reactants has been consumed. The limiting factor is probably the NaOH.
Here's the reaction for aluminum and sodium hydroxide:
2NaOH+2Al+2H2O→2NaAlO2+2H2
Notice that one of the products is hydrogen gas... maybe enough to burn.
Bikes: a couple
Quoted: 563 Post(s)
Liked 871 Times
Thank you for the heads up.
Bikes: a couple
Quoted: 563 Post(s)
Liked 871 Times
Ok, so here goes.
Best guess is give it about 3 hours with the oven cleaner and I could polish this thing in an hour or so including sanding.
wheel is a matrox 550 out of the bin
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/1600x720/img_20230619_111313767_2a90f68a26ce67e1950dbef3b02657c9946c9502.jpg)
wheel
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/1600x720/img_20230619_111307265_81205c346a4ba788a3d81da1e77375fc216e3fb2.jpg)
wjeel with 1 minute of sanding with 1500 grit and no oven cleaner
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/720x1600/img_20230619_111251794_2d79b91946e328c5a81519f2dea4ca219989a0fb.jpg)
2 hours in oven cleaner and about 1 minute with 1500grit
![](https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/1600x720/img_20230619_081542157_8276c62e72ade06410e8339d334c65a04c38971d.jpg)
![](https://cimg6.ibsrv.net/gimg/bikeforums.net-vbulletin/1600x720/img_20230619_081545617_hdr_1475afde38b898606103e2d312687b0dbd159bc8.jpg)
wheel
![](https://cimg7.ibsrv.net/gimg/bikeforums.net-vbulletin/720x1600/img_20230619_081634045_hdr_38dab78cfa241ebfe6061af32ed3f242ba8a51c0.jpg)
