10 speed 105 to new Tiagra
mechanically sound
Hi folks- my current ride has 105 10 speed shift/brake levers, which have been great but the shifters are wearing out. I’d like to just get new shifters, and discovered that Tiagra is the only 10 speed offering from shimano anymore. My question is if this would be a downgrade-ish move or if the current Tiagra is at least more of a lateral switch from circa 2005 105. Thanks.
Clark W. Griswold
Quoted: 4505 Post(s)
Liked 4,190 Times
The problem with the new 4700 (which is older now) is that it is more than likely an 11 speed pull ratio so while it is a 10 speed group it is not compatible with 10 speed stuff. I would generally stick with 105 but the newer Tiagra isn't absolutely terrible. However I would probably just upgrade to 11 speed at this point if you enjoy the frame and like the bike generally go for a nice upgrade.
Sunshine
Quoted: 11080 Post(s)
Liked 7,665 Times
Since you have the older style 10sp, you could use these shifters- a pair is $89 and they work well. The shifting style is slightly different from Shimano, but it is easy to learn.
https://www.amazon.com/MicroNEW-Shif...05076490&psc=1
Likes For mstateglfr:
Quoted: 3335 Post(s)
Liked 2,182 Times
I would just upgrade to 11. Shifters, rear derailer and cassette and chain. You can likely get away with using the existing crank and front derailer. If it’s a rim bike system (likely as it’s 10 spd.) the brakes are used as well, makes it easy.
Likes For Steve B.:
Quoted: 3261 Post(s)
Liked 2,581 Times
Microshift/Micronew FTW. You won't have to whack the brake lever sideways ever again.
Likes For seypat:
Should Be More Popular
Quoted: 22741 Post(s)
Liked 9,117 Times
Likes For datlas:
ignominious poltroon
Quoted: 2301 Post(s)
Liked 3,536 Times
The microshift option mentioned by several folks should be the most cost-effective option.
The upgrade to 11-speed option is more spendy, but probably worth it if you find the drivetrain parts on sale and you DIY.
Likes For Polaris OBark:
mechanically sound
Thank you for the opinions! I wouldn’t mind going 11 but it would mean new rear wheel as mine has an originally 9 speed ultegra hub. I will see about the microshift option.
Another option is the older Tiagra, 4600 series. They use the same shift cable pull ratios as the other Shimano 10 speed road groups.
Clark W. Griswold
Liked 4,190 Times
But if you are doing that just look for a 105 or higher. If I am going with old stuff I wouldn't go down in quality but either stay the same or go up.
Likes For veganbikes:
Quoted: 1158 Post(s)
Liked 1,267 Times
Like others have said, check out Microshift shifters. I actually prefer them quite a bit to Shimano. Their shifting design is much better, IMHO. And they work very well.
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
I have a 15 y.o. 105 10 speed group set and a new microshift AdventX. In some ways I prefer the Microshift lever. It isn’t as buttery smooth but I prefer the ergonomics and accuracy of the Microshift.
it’s to the point where if I had to replace the 105 I’d swap to the Adventx
Quoted: 6353 Post(s)
Liked 4,956 Times
In the grand scheme, the Tiagra RD-4700 isn't a lot of extra cost compared to the STI's alone. And a front DR might be needed too. But I'd wait to see how well the ST-4700 did or didn't shift the FD-4600. Though maybe you others know for certain.
Even with the cost of two DR's added in, It'd be worth it to me to have the newer and so far most current Shimano 10 speed road stuff on my bike. I never got use to seeing all the cables flying everywhere. Aesthetics are much nicer with them taped to the bars. IMO
mechanically sound
Thanks everyone for the info and insights. I got some micronew R10 2x10, they seem pretty nice. The ‘05 Masi marches on!
Likes For frankenmike:
Liked 9,117 Times
mechanically sound
Update w/ pics!
Welp, finally got around to installing the micronew shifters. Figured it would be a good opportunity to overhaul the drivetrain. Shifts perfectly on the stand, we’ll see how it goes on the road. Thanks again for the recs!
Shiny clean chain, shaken w/ solvent x2, rinsed w/ rubbing alcohol
Ooh fancy lol
Adios 105, thanks for 18 years of functionality
Hello micronew
Old school
Installed with brakes attached before new bartape
Ready to ride!
Ooh fancy lol
Hello micronew
Old school
Ready to ride!
