Preferred products: polishes, waxes, degreasers, etc
wondering what products (techniques as well) that you use to keep your whole bike clean and ready for play or show.
Quoted: 4227 Post(s)
Liked 2,491 Times
I don't perform any cosmetic beauty treatments on my bikes.
Likes For wolfchild:
Quoted: 788 Post(s)
Liked 1,843 Times
I just sort of wipe it down when needed but don't use any special products.
Likes For jaxgtr:
52psi
Quoted: 790 Post(s)
Liked 803 Times
Dawn dish soap & water.
Likes For Fahrenheit531:
Klaatu..Verata..Necktie?
Quoted: 10584 Post(s)
Liked 12,188 Times
Simple Green on the drivetrain - don't soak, just spray on, use brushes to help dislodge the dirt, then wash off with copious water. Water with Dawn dish soap on the frame and wheels. You can use a Detailing spray on it, but DON'T let it get on your brake pads or braking surfaces! On raw Titanium, spray a little WD40 on a cloth and wipe the clean frame with it.
Wolfchild's Helpful Hints.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3932 Post(s)
Liked 6,591 Times
wondering what products and techniques to keep your whole bike clean.
Don't ride in the rain.
Likes For SurferRosa:
Mad bike riding scientist
Quoted: 6271 Post(s)
Liked 4,300 Times
I avoid using oil based lubricants on the drivetrain which significantly reduces the need to clean at all. I have to clean enough really dirty bikes at the co-op to get my cleaning fix. I reasonably certain that this person just uncapped a quart of 10W-40 and poured it over the bike on a weekly basis.
Simple Green is fairly ineffective in my experience. I found Armor All Extreme Wheel and Tire Cleaner works much better. Let it sit for a few minutes and even this bike came out much, much cleaner.
Stuart Black
Stuart Black
Bikes: Franklin Frames Custom, Rivendell Bombadil
Quoted: 125 Post(s)
Liked 216 Times
While I only wipe my frames clean locally, as in certain places at a time as called for and generally with water, a rag and/or mild window cleaner. I occasionally use some Blue Magic metal polish on some of my raw finish Specialized hubs from the 80's.
I've also found that WD-40(from the gallon cans) also makes for one all-in-one cleaner/polisher. After lubing my chain with it I'll occasionally wipe the stays and/or other tubes with it on a rag, Cleans polishes and lubes in one shot. Ahahahahahaaa ... very nice !
I use diesel or mineral spirits as a degreaser, which isn't very often and only for bearings.
Quoted: 2333 Post(s)
Liked 2,097 Times
I did 75 miles in off and on drizzle yesterday and the bike and my legs were coated in debris like leaves, mud, worms.
I took the chain off and put it into mineral spirits, turned the crockpot of wax on, and washed the bike with hot water and Dawn detergent. I dried it. Then I took a shower and ate. At that point, I took the chain out, wiped the excess wax off, and reinstalled it. It is rare that I wax any of my bikes but I use the same automotive wax that I use on my cars. (I do not use a degreaser on my bikes because there is no grease to remove, ever)
Liked 3,103 Times
For a detailed look, graphene with a matte finish.
so far, the carbon stuff hasn't exploded.
-Oh Hey!
-Oh Hey!
good cheap fun
Pedro's Bike Lust is my favorite bike polish, Muc-Off Matte Finish Detailer works great and smells amazing, Finish Line or Muc-Off bike wash for general cleaning, and Finish Line Gear Floss is great for cassettes and freewheels if you're not taking off the drivetrain to soak or put in a parts cleaner. Mother's mag polish for shiny bits.
Quoted: 3625 Post(s)
Liked 3,047 Times
I wipe off road dust with a cotton rag and any household spray cleaner. I run the chain through the rag to keep it clean. Use the rag like floss to clean between the sprockets. I also will blow heavier debris away with my air compressor. I use Armorall on the hoods. Then I use a ceramic car wax on all surfaces, including the frame, chrome stay and lugs, and components—probably any quality wax would work, but I’m currently using Hydro Slick from Chemical Guys.
Quoted: 790 Post(s)
Liked 348 Times
When I am cleaning old grease of drivetrain parts I use kerosene. If my chain gets noisy I put a bit of motor-oil on it. Sometimes I will wipe a few parts of a bike down with an cotton rag. I have an old can of chrome polish marked "Mopar" that is probably from around WWII, it still works to polish something if I am so inclined, but it is almost completely empty.
Bikes: 1995 Specialized Rockhopper,1989 Specialized Rock Combo, 2013 Specialized Tarmac Elite
Quoted: 213 Post(s)
Liked 589 Times
Meguiar's Ultimate Liquid Wax. Protects the finish and I'm guilty of liking a clean shiny bike. I've used Ballistol to clean chains because I have a lot of it on hand. Brush to clean between links and re-lube with Dumonde Tech Classic Lite.
Quoted: 2632 Post(s)
Liked 1,985 Times
Squirt some Dawn in a bucket, add hot water, wash. Done. Good enough.
Likes For pdlamb:
Quoted: 1447 Post(s)
Liked 2,037 Times
for dust and similar - try a Swiffer dust cloth (instead of rags or paper towels etc)
Swiffer dust cloths are amazing for cleaning dust and loose dirt from bikes (frame, components, rims, etc) - and can also work well on lubricated drivetrain parts (chains, cogs, rings, RD pulley wheels, etc)
Swiffer cloths will also continue to work when they are fairly well used - so you can get multiple uses from one cloth
we ride on a fair amount of crushed limestone, gravel, and dirt trails and roads - so the bikes are often covered with a blanket or layer of the stuff ... Swiffer cloth is great for quickly removing that stuff
if you use a chain lube that does not attract or sheds dirt / dust fairly well - Swiffer cloth will remove whatever dust / dirt that did cling to the chain, cogs, and rings
Quoted: 8400 Post(s)
Liked 9,316 Times
I use Pledge on my road bikes, I never wash them unless they get muddy/gritty. I let the mountain bike get pretty nasty before I wash it. I haven't washed it this year.
Don't think I washed my car this year, either.
Habitual User
Quoted: 5064 Post(s)
Liked 8,351 Times
For regular between-ride cleaning, I hose my bike off and wipe it down with an old t-shirt. Anything too sticky to come off with just water, I use Simple Green. For deeper cleaning of drivetrain parts, I like Muc-Off Drivetrain Cleaner.
Bikes: 2002 Eddy Merckx Team SC Resto-Mod; 2019 Ibis Hakka MX; 2017 Spot Brand Ajax Belt Drive
Quoted: 169 Post(s)
Liked 192 Times
I've been using Muc-Off bike cleaner the last few years. Seems to work well. Pedros Bike Lust is incredible for shining up your bike, but I almost never do that. I use Pedros biodegradable solvent-free degreaser to clean my drivetrain. Finish it off with some Muc-Off dry lube. One of these days I'll try immersion wax. Maybe.
Habitual User
Liked 8,351 Times
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2139 Post(s)
Liked 1,653 Times
For chain degreasing, I use whatever kind of commercial degreaser the store has when I go buy it. That is Zep right now.
I put it in one of those bicycle specific chain scrubber thingies and pedal backwards for about a minute.
I rinse, let it dry, then apply Finish Line dry chain lube.
For washing, I use commercial car wash. The same stuff I use on my truck. I rinse, then apply Lucas Slick Mist Marine Speed Wax. It is sprayed on a wet surface, followed by a quick towel dry.
The Lucas Speed Wax is one of the best products I have ever used. I'll never paste wax again. It only lasts about half as long as paste wax, but it takes about 1/10 the time to apply.
