dura ace 7700 chainring bolt substitutes?
What chainring bolts are compatible with dura ace 7700? Paying 40eur for NOS just feels silly.
Chain fell off twice on a ride, fixed ur, fell of straight away, notices two bolts missing (this explaing all the creaking and the wobbly chainringa I've dealt with lol). Also, so you all use loctite in chainring bolts?
Quoted: 1121 Post(s)
Liked 1,356 Times
a) I'd be suprised if bog-standard bolts do not fit;
b) no, don't use locktite, lube the threads and tighten them enough that they don't slip.
(you can make a tool for the backside from a common table knife, bend the tip 90 degrees and shape it to fit with a dremel cut-off tool).
LBS had some stronglight bolts so will mount these now
Quoted: 3663 Post(s)
Liked 3,100 Times
Likes For smd4:
In either case, I had some Loctite 222 so I applied just a tiny film on the threads before installing.
