School me on pressing headset cups.
Ok, so I just bought what I thought was a Park HHP-2 clone, the Unior 1680/4. I saved about $100 over the Park, and supposedly it will press 1" , 1 1/8", 1 1/4" and 1 1/2" cups. My headtube is 1 1/8 to 1 1/4, so I figured I'm all set. I thought the drifts would fit nicely in both cups. I get the thing in the mail, it's looks nice, a beast, like it will last three lifetimes. But unless I don't understand something, it looks like the drifts won't do what I thought they would....like they're too small for the bottom cup. It's as if the drifts are for 1" and 1 1/8", but one has to remove the drift and rely on the large end piece to press in the bottom 1 1/4" cup. The drift does seem to fit the top cup. With the bearing removed, the drift sits inside the cup, and rests just on the edge of the cup where the bearing would sit. Is that called the "race?"
Maybe I'm doing things incorrectly? The headset is a Cane Creek 40, ZS 44/28.6 and EC44/33.
I notice on the park HHP-2, from reading the verbage, the drift itself will fit 1, 1 1/8, and 1 1/4, but one needs to remove the drift and use the big end piece for 1 1/2.
I passed on other less expensive presses, because they said they wouldn't press 1 1/4". I assumed they meant the drift itself wouldn't fit the 1 1/4 cup.....just like this one I have doesn't. Would you consider it false advertising for Unior to advertise 1" through 1 1/2" if the drift won't even fit properly in a 1 1/4" cup?
Am I thinking about this correctly? Thanks
No experience with the Unior 1680, but it looks like many headset presses with a series of stepped fittings that may or may not fit snug inside your headset bearings or cups.
It has flat surfaces on either end that will put pressure on a headset cup as you turn the clamp, and that's usually good enough.
I'd take out your bearings and do one headset cup first. After that one is seated, do the other. The tool will apply reasonably even force, even if it doesn't have a fitting that perfectly mates with the inside of a headset cup. The headtube will determine whether seated cups are aligned, not the tool.
You should not have to reef down on the cups. Most headset presses have handles that would seem to encourage destroying parts through over torqueing.
Quoted: 3624 Post(s)
Liked 3,047 Times
Liked 3,047 Times
The Park tool we used back in the day (80s - 90s) didn’t have any of those spacers. We just used the flat surfaces to press cups in. But then, we were mostly dealing with regular bearings, not cartridges.
Likes For smd4:
Quoted: 860 Post(s)
Liked 1,103 Times
Try here. Check the video too. Headset press (uniortools.com)
In any case, I just rooted through my basement and found the $30 press I used four years ago to press these cups in. The drifts fit in the cups like they were made for it....no wiggling at all...seat perfectly, top and bottom. Oh well. I guess I should have looked harder before ordering this thing. Postage back to Italy is probably cost prohibitive. This thing is heavy.
Quoted: 5931 Post(s)
Liked 2,825 Times
Forget about the specific parts for a moment and consider what's needed.
With steel headsets it's OK to press by the rim of the cup, since the part is plenty strong enough. However with an aluminum cup, is important to press from the center so the cup itself isn't stressed. The "cone" side is easy since you'll always b pressing from center.
If you don't have a proper stepped sleeve, you might try dropping the cone into the cup (without balls) and seeinf if it's tall enough to protect the rim. Otherwise feel free to improvise any adaptor which will achieve the purpose.
FB
Chain-L site
FB
Chain-L site
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1301 Post(s)
Liked 745 Times
or you could just use a quality 2x4 and a mallet like was done for DECADES..... just don't hit yer thumb.....
in the future, a very expensive robot will be sold that will install things with nary a finger lifted by the bike owner... and then it will bill you for it's time plus taxes for the sake of nostalgia.
Likes For maddog34:
Liked 2,825 Times
So, I approach jobs by knowing the basic principles, and WHY we do jobs a certain way.
Pressing a headset (any headset) you want to press directly over the cylindrical part going into the frame. This eliminates thr risk of distorting the cup that might happen if you pressed on the unsupported overhang.
Doing that is your job, using either a bought part, or improvising one.
If you know what matters you can do any job with confidence.
FB
Chain-L site
FB
Chain-L site
Quoted: 1110 Post(s)
Liked 1,050 Times
OP, a lot of times the stepped piece for the park really only fit into the headtube, but any of the park shop level headset presses I've used, which would have been made in the last 30 years, had large ends of the presses that weren't flat, they had shallow steps that the headset cup would fit in. The stepped adapters were always used to fit the headtube, only press in one side at a time, while the other adapter may or may not be used on the headset cup. I've seen headsets like the king that had bearings crushed from using the stepped adapter, I've never heard of the rim of a headset being crushed from not using it.
Likes For Russ Roth:
Not true in my experience, kings the bearings aren't pop out cartridges, you just press against the rim of the cup and no worries.
"For headsets not fitting #530-2 cup guides, simply press using threaded press plate and sliding press plate. Pressure on the outer rim of aluminum head cups may visually scar the cups. If not using the guides, it can help to press one cup at at time."
Generally bewildered
Quoted: 1152 Post(s)
Liked 342 Times
As I understand it, there are two bushings (pic below) that face each other on a shaft. On one end of the shaft you have the threaded nut with handles. On the other you have a collar that can be affixed to the shaft at various points on the shaft. This allows you to use the setup easily with many different frame sizes without having to run the nut up and down, and allows you to put the tool in place easily, again, without having to take the nut off. If you are putting in a cartridge bearing seat, and the bushing isnt big enough you can reverse the bushings and use the flat side of them to push the seat on. If you are installing the bearings themselves, you absolultely positively don't want to just push on the inner race. You want a flat surface to push on both the inner and outer races at the same time to ensure that the rule is followed: no force is to be transmitted axially through the bearing in any install. The Unior is a great tool for a shop, where you have to install cups on many different frame sizes. At $182, its probably overkill for the home shop/single bike user. Doesn't stop me from wanting one, though!
Mad bike riding scientist
Quoted: 6270 Post(s)
Liked 4,299 Times
So this is an aluminum headset with cups that take cartridge bearings. With the bearings removed, the "cone" (you're referring to the drift?) that comes with the headset drops right through one of the cups, catching nothing at all. I'd be pressing the rim of the cup. The other cup opening is a little smaller, and one edge of the cone just barely catches the edge of the race. Not by a lot though. I did just notice that Cane Creek makes an accessory "tool", a ring that sits nicely in both cups, and accepts the standard stepped drift. It's exactly what's needed here. The one side is beveled to the same curve that the race is in the cup, so it sits perfectly in the cup, like it was made to., Oh wait, it was made to! lol. $17, ships free. I would have had the same problem with the park tool.
Stuart Black
Stuart Black
Liked 1,050 Times
You shouldn’t use the stepped adapter on a cartridge bearing headset according to Chris King’s installation instructions. You should be pressing on the outer edges of the headset to avoid damaging the bearings. King doesn’t make them anymore but here’s a very affordable one from Fleabay. You could also use the flat part of the press (red arrows below) but I’d probably use something as a pad (plastic or aluminum) to cushion the flats. There is a problem with doing this as there is nothing to center the press so great care should be used if doing this.
Liked 3,047 Times
Liked 745 Times
it also doubles as a BB cup press.. some careful hand alignment is required.
and i always have a decent 2x4 trim piece and my Mac deadblow around, if needed.
i'm amazed that no one has mentioned using a bearing/race/seal installer of the correct size.... https://www.ebay.com/itm/19393832361...Bk9SR4Ce1s6uYg
i have a Park HHP-3 press.. it works by pressing on the rims of the cups.. and it works wonderfully after i fitted a couple straight 3/4" ID PVC couplers onto it.... along with the supplied spacer, i can mix/match to achieve the needed centering, thereby maintaining near vertical alignment to the cups and frame.
Can you post a photo of your PVC solution?
Liked 4,299 Times
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 342 Times
Do one side first with the adapter in the headtube and its a lot easier to line up with the flat plates and get that second cup in square. I've got that same cheapie press and it works well enough, but you do need to be cautious when pressing in the second cup that its sitting centered on the first cup and you're holding the second cup centered to the tool when starting. Should probably stop being lazy and make a set of adapters on the lathe and drill press from aluminum that would center the common outer diameters of the headset cups but I never think of it till I want to use it.
Liked 1,050 Times
Didn't realize that was the Unior version in the pic. Mine is not unior quality, I'm familiar with the brand and a number of their tools, but clearly is a ripoff of the unior design. This is one of those items where the park shop version is the best but I don't install enough headsets, especially with modern frames, to justify the cost and went with one that looked good for 80.
