Wide wheels
Learning the ropes
Wide wheels
Why do people opt for wider rims (e.g. Reynolds assault's) instead of older designs that have spokes that go almost all the way to the tire (like Shimano WH-RS500)? I tried out the Reynolds Assaults, and while they were faster on a straightaway, whenever I had a crosswind AT ALL, it was like I was riding a sail and I felt like I was working harder to keep the bike upright than I was working to get a reasonable speed. What am I missing? Do the gains somehow outweigh the cons?
Should Be More Popular
Quoted: 22750 Post(s)
Liked 9,133 Times
Likes For datlas:
Learning the ropes
Quoted: 1111 Post(s)
Liked 1,050 Times
Rim design matters for how well the wind effects things but I have my 12yo daughter on 32mm deep rims on her road bike and 45mm deep on her track bike and even in stiff winds on the track has never struggled to control her bike or riding along the ocean with high wind speeds. At only 41mm deep I wouldn't think they'd be effected that badly unless they're not a newer shape or you're riding in really high winds. Basically though, unless you have a tailwind that's faster than you're going, you're always riding into a wind and an aero profile rim when specced with a proper size tire will always help you save time/energy. When companies speak of watts saved at 40kph/25mph which seems like an absurd speed for the average rider to maintain, they're actually referring to combined speed, if you're doing 15mph into a 10mph wind you're hit their 25mph, so they really do have the benefits reputable companies claim for the average rider.
Quoted: 484 Post(s)
Liked 300 Times
Look Bikealangelo, just because you have the coolest username... okay, that's all I got.
Weight can a factor too - in that lighter AND newer riders might feel uncomfortable on deep section wheels.
But yeah, there are pros and cons...
Cons:
- can be heavier
- are more expensive
- can be a factor in strong cross winds
Pros
- faster
- look cool
- look cool (worth mentioning twice)
Cons:
- can be heavier
Pros
- faster
- look cool
Quoted: 20810 Post(s)
Liked 9,456 Times
When it comes to cross-winds, rim profile is important. My Reynolds Assaults were significantly worse in cross-winds than my current Zipp 303S; I don't really feel much wheel push, at all, with the Zipps; it's less prominent than on the frame/my body. With the Reynolds, it's was like an invisible hand nudging my bars.
Habitual User
Quoted: 5104 Post(s)
Liked 8,414 Times
Quoted: 1467 Post(s)
Liked 1,495 Times
I've noticed crosswinds buffeting me around a few times while on my Zipp 303S, but only in some pretty extreme conditions, and even then it's relatively minor.
I have a shallower depth wheelset and I've never felt the need to swap due to wind conditions.
Liked 9,456 Times
I'm curious WhyFi - what do you weigh and which Assaults did you have? I'm about 180lbs and love my 42mm Assaults - haven't felt any adverse effects from the wind.
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
Experience also affects the perception of the wind - at first it feels a lot stronger than it will after a season of adjusting to it. Shape still affects it, though.
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
Something else worth mentioning in a discussion of deep rims is the shape. Early attempts at really aerodynamically efficient rims were V-shaped, with flat sidewalls and a fairly sharp apex. Later, engineers learned that it's better to make more of a U-shape, or even to bulge the sidewalls out slightly wider than the bead area. Today's fastest (and most expensive) rims have little bumps around the circumference of the apex, the area where the spokes enter. These are claimed to prevent a stall, or area of low pressure next to the rim, which could add a little inefficiency.
I'll add my own opinion with this... Among all the wheels I have for my several bikes, there's only one carbon set. They are Reynolds rims. I don't know the model, but they're ten or fifteen years old I think, with really nice but heavy hubs. They're my deepest rims (although not much deeper than some 20 year old alloys I have) and they're V-shaped and a bit on the heavy side. I don't have any illusions that they are faster than some much less "fancy" wheels. They *might* be no better than some really old-tech but lightweight box section rims, for the kind of riding I'm doing. I still love them. They look cool, they make me feel like I'll be able to ride fast, they're more than tough enough for the use I put them to. And did I mention they look cool?
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
People will laugh, but this is a thing.
I've made no attempts in this forum to hide the fact that I'm a Cat 6 racer. When you're trying to beat a guy who probably doesn't know he's in a race, image is important. Psychology makes a real difference in athletic performance. I show up with my coolest looking bike and my favorite bib and jersey, and I'm ready to push myself hard. With lesser gear, I'll have an excuse to underperform.
You can start making fun of me now. (Hides under desk)
My suggestion is to go staggered. My favorite wheelset to this day is the 2023 Winspace D45 where you have a 46mm wheel upfront and 54mm at the back, this allow for more control upfront while still getting pretty good aero gains.
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
My newest wheels are not really deep at maybe 40mm but that is about as deep as I want for here in Colorado. It is pretty unaffected by crosswinds and similar to my 30mm alloy rims. I woudl not want deeper for two reason- crosswind stability and stiffness. Deeper carbon wheels tend to be stiffer/harsher and the crosswind stability is reduced. If I loved in flat terrain where it isn't too windy, I'd maybe step up to the 404s or keep 404s as a 2nd wheelset, but nothing deeper. The 303s are very comfy and light wheels and I bet the 404s are heavier and stiffer/less compliant.
I don't know.
Quoted: 337 Post(s)
Liked 909 Times
I'll admit I only bought them for the hotness. I wanted hot wheels for decades. When I built my Ritchey (had it built), I went for it. Since 2016 when I got the bike, I can remember maybe a half dozen times when wind was a small issue. Maybe cuz I opted for a less deep v-section for the front.
Likes For RB1-luvr:
I should also note while deep wheels will be faster it also really depends on your power. I am smaller rider and average 140W-150W, so nothing amazing and for me to get a heavier 65mm spun up to speed especially in a lot of stop and go cycling was tiresome. People will debate all day about rotational weight or if the weight of your wheels actually matters over watts saved via deeper aero wheels, but they always seem to forget these aero gains are mostly tested in win tunnels and as 20+ MPH. Again this is why I would recommend your front wheel being 50mm or less unless you are putting out some serious watts
What makes you think that people forget that aero differences are often tested at 20+ mph?
Quoted: 4608 Post(s)
Liked 5,151 Times
Liked 1,050 Times
That 20+ mph for best gains is a combination of you and the wind, not just you. The wheels in the wind tunnel may be spinning but they're not moving forward so in the windtunnel all of that 20+mph is how fast the wind is moving not the rider. On the road its a combination. So even a slow rider can find some benefit, even if they only average 14mph, a breeze can provide the other 6+ for full benefit.
