Flat Pedal Shoes
Quoted: 206 Post(s)
Liked 66 Times
Flat Pedal Shoes
I now prefer to ride with flat pedals. Is there a flat pedal shoe that has a stiff sole? I invested in Five Ten Free Rider shoes and found the sole to be very flexible. This caused pain in the ball of my foot. I switched to a cleated mountain bike shoe and did not install the cleat. There is no more pain in the ball of my foot. Ideally, I would want shoes that are made for flat pedals without the cleat.
Bikes: Trek FX 7.3, Orbea Terra, Aostimotor S17 ebike, Huffy RedRock (first bike)
Quoted: 241 Post(s)
Liked 367 Times
I ride in Skechers hiking sneakers, they have thick non-slip sole. Plus, comfortable to walk around when you're taking a break.
Bikes: Cannondale Quick 2
Quoted: 27 Post(s)
Liked 32 Times
Five Ten Freerider Pro shoes are also very highly rated, albeit quite expensive and not for wide feet.
Good luck in your search.
Best regards
Barry, 77
New Jersey
Quoted: 1087 Post(s)
Liked 1,349 Times
I find having a large platform pedal is better than a stiff sole. With my platforms I can wear any shoe comfortably. I even did two tours using Crocs, comfortably. I commuted using Vans. One pair of Crocs was actually stiff, though I preferred the more flexible pair.
Quoted: 431 Post(s)
Liked 728 Times
Maybe try some stiff shoe inserts (insoles) so you could wear any shoe you like. Haven't tried these, but found on a quick search: Amazon.com: Carbon Fiber Insole - 1 pc | Rigid Carbon Fiber Shoe Insert for Recovery | Graphite Shoe Insert for Foot Pain, Arthritis, Hallux Rigidus, Turf Toe & Mortons Toe | Stiff Soles W's 12-12.5 Men's 11-11.5 : Health & Household
Might also try a local shoe or sporting goods store.
Likes For freeranger:
Quoted: 1368 Post(s)
Liked 1,699 Times
I ride in sneakers on platform pedals with toe clips and for the last few years I have inserts in them...arch support inserts with semi-rigid support from the balls of the feet to the arch. $12-$18 at Wal-Mart.
Quoted: 408 Post(s)
Liked 184 Times
The bike store owner wore Vans. At the time I didn't care for them, but later decided to purchase a pair with good insoles. I use them now for work and play. Van's makes good shoes. Well made and durable.
Lopsided biped
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times
I got quite a surprise when I tried riding in basic Teva Universals, the cheapest ones they make, and that was on standard-sized pedals. They worked perfectly well.
Get a set of pedals that are long enough (Catalyst, in my case) and you can wear anything you like.
Likes For jack pot:
Quoted: 1877 Post(s)
Liked 1,751 Times
What has the world come to? Somebody somewhere needs to bring back the Bata Bikers. They would be ideal for most flat pedals
Quoted: 4611 Post(s)
Liked 5,155 Times
Likes For PeteHski:
Liked 5,155 Times
I don’t have the regular Freeriders to compare, but the Pros are much stiffer than any sneakers I’ve owned. They are obviously less stiff than my carbon road race shoes, but they don’t cause any foot pain when used with full sized mtb flat pedals.
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2142 Post(s)
Liked 1,655 Times
I have arrived at Under Armor Charged Pursuit as my go to shoe for riding flats. Check some out next time you are in a store that sells UA. UA has some killer deals online on a frequent basis.
Henderson, NV
Bikes: Trek Alpha 3700, GT STS DH, Raleigh Grand Prix, Fisher Montare, Fisher CR-7, Fisher Aquila, Diamondback Sorrento, The Bike Beat Revolution, KHS XC 504R
Quoted: 354 Post(s)
Liked 637 Times
I find my Specialized 2 FO flat 1.0 good for riding on wide flat pedals. Most of my riding is in dry conditions.
Cheerfully low end
Quoted: 650 Post(s)
Liked 1,067 Times
I’m nearly a year into wearing only minimal/barefoot shoes, so I only wear shoes with a wide, foot-shaped toe box, no heel and no artificial stabilizing features.
Typically they also have a thin, very flexible sole. For biking, a transitional shoe like some of the Lem’s works well: all the other minimal/barefoot attributes but a thicker sole.
In particular I’m using the Primal Zen for biking and it works well. I would expect that some of the Altras could work well too if they didn’t have too deep of a tread.
Otto
Otto
slow on any terrain
Merrill hiking shoes work for me.
Likes For eljayski:
Different strokes I guess. I found exactly the opposite. Like the OP, I prefer flat pedals and not being clipped in. I have a pair of Venzo flats on my TT bike and they always hurt my feet on long rides. The pedals on my other bikes look like regular old school pedals and they're far more comfortable with regular shoes.
A tree you may want to bark up to are power lifting shoes, specially deadlifting shoes. Because you are supposed to be handling a lot of weight the last thing you want is a squishy sole, those shoes are designed with very stiff ones.
In specific look at deadlifting shoes. Unlike squat shoes they don't have the higher heel. Check out Amazon for what is out there.
Quoted: 206 Post(s)
Liked 66 Times
Decades ago they had a plethora of what was called touring shoes. A few come to mind. Beta Bikers, Avocet, Sidi. What they all had in common were stiff soles. My $100 Five Ten will probably spend eternity in the closet. I have come to believe that only shoes that are intended for cleats will be stiff enough for me. I am now using Pearl Izumi shoes. The cleat area has a removable cover. At least once I started riding with these, I had no more metatarsal pain.
Likes For daniell:
Quoted: 1457 Post(s)
Liked 2,066 Times
some possible options include -
Pearl Izumi X Alp or Trans Alps - fairly / relatively stiff
Shimano ‘touring’ or ‘mountain touring’ shoes - including older models like the CT71 or more recent MT701 ... they are rated just 4 or 5 on the Shimano stiffness scale - but still significantly better than the majority of freeride shoes including Shimano’s own GR5 shoe
note : when installed, the bolt on cleat cap / sole plug will provide additional rigidity / stiffness to the Shimano touring shoes ... without the plug too flexible
Sixsixone Filter shoe is stiff - but has a very thick tongue
some Bontrager MTB shoes could also be an option - but be aware many models (if not most) run narrow
Liked 1,349 Times
52psi
Quoted: 790 Post(s)
Liked 803 Times
I wish I'd bought more than one pair of these DVS/Cinelli Luster:
Super stiff sole, real leather, durable, good looking. I still wear the ones I've got even though they're beat to hell. Should maybe start looking for other options myself.
If you're a size 13 and like white shoes you can get a pair on ebay, it looks like. (If they were my size I'd have bought them rather than posting them.)
Likes For Fahrenheit531:
Bikes: Cuevas Custom, Cimmaron, 1988 "Pinalized Rockma", 1984 Trek 510, Moulton custom touring, Raleigh Competition GS, Bridgestone Mb-2 & 3, 1980's Peugeot - US, City, & Canyon Express (6)
Quoted: 1168 Post(s)
Liked 4,083 Times
Surprised to see Vans mentioned here, more than once. That said, they do now have a bike shoe, well BMX anyway. It is supposedly designed for bikes and pedal grip specifically - "VDFPR (Van Doren Factory Pedal Recipe) - This is our latest proprietary gum rubber compound, specifically formulated to enhance pedal grip and durability. Tested and approved by the Vans® innovation team and the top factory team riders, VDFPR is only available on BMX Wafflecup™ construction." I picked a pair up in a store and they are noticeably stiffer and heavier than a normal Van's sneaker (which are very flexible) but I doubt as stiff as many bike rider would be looking for?
Likes For SoCaled:
