TPU justification for tubulars
I read the TPU threads. $30 or $40 for a tube that saves you 40-60 grams over butyl.
They just had a special -- Vittoria Corsa tubular for $85 for a pair. A whole race tire with a lighter rim for the price of an inner tube.
No beef with TPU tubes. I'll probably get some. But for know I'm not going to feel too bad if I flat a tubular. It's cheaper than a day of golf.
I’m a little Surly
Bikes: Two Cross Checks, Karate Monkey, Disc Trucker, and a VO Randonneur
Quoted: 699 Post(s)
Liked 1,303 Times
It's not just the weight with TPU is the better ride and better rolling resistance. If you want to ride tubies go ahead if I were going to ride a bike with 25's I'd probably ride them too, just add a bit of tubeless sealant and you need to worry about flats
Quoted: 1635 Post(s)
Liked 1,840 Times
Ridenow TPU tubes are like $7 each.
The other advantage of TPU tubes is that they are easy to carry as spares. You can't say the same for your tubular tire now.
Veteran, Pacifist
Quoted: 3935 Post(s)
Liked 4,927 Times
Tubulars = a good reccomendation for one's fast pavement bikes. I used sealant as a precaution, until a couple of stems got plugged. I probably stopped during first ride with valve stems at bottom on wheel. Anyway, I carry my sealant now. Makes for a longer stop to seal a flat, but never a valve stem concern. I very rarely flat.
Bikes: I have a few
Quoted: 348 Post(s)
Liked 235 Times
Thread Killer
Quoted: 3222 Post(s)
Liked 1,769 Times
Pirelli’s top tubular, P Zero Race SL use TPU tubes inside. It’s the tubular supplied to all their sponsored World Tour teams when not on tubeless. At over $100 per tubular, way more expensive than running TPU innertubes, so I’m glad I run clinchers!
On yesterday's ride I had a flat and replaced the rubber tube with a RideNow TPU tube. I bought some to carry for times like that. I bought them on AliExpress for about the same cost as rubber tubes. When I got home I put another TPU tube in my seat bag. Hopefully I won't use it for a long time.
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 915 Post(s)
Liked 1,993 Times
I just received 2 aerothanes in the mail and when I picked up the package I thought it was empty.....
Quoted: 4598 Post(s)
Liked 5,143 Times
This is the main reason I’m interested in TPU tubes ie emergency spare for my tubeless setup. They appear to be much less bulky than regular tubes.
Likes For PeteHski:
https://www.excelsports.com/vittoria...ad-tire-2-pack
I ordered a pair and they look great, arrived quickly.
Likes For ljsense:
Thread Killer
Liked 1,769 Times
That’s what big TPU companies and their media lackeys want you to think. They have ways of manipulating the images to make their old, warmed-over technology look smaller than butyl. Next thing you know, they’ll fade you into believing they’re more durable, have less rolling resistance, weigh less, and hold pressure better, too. They won’t stop until we’re all back in tubes! This battle between Big TPU and Big Tubeless is ruining cycling! Jan Heine for UCI President 2024!!!
Liked 1,840 Times
Veteran, Pacifist
Liked 4,927 Times
I run my tubulars at a pretty high pressure (but nowhere near 175psi - the rated max). Vittoria (in clinchers) has always been my 'go to' tire. I was a little disappointed in the Vittoria Corsa tubulars, not as supple a feel as I was expecting. Mine are 25mm.
Liked 5,143 Times
Thread Killer
Liked 1,769 Times
Puncture resistance could certainly be better than latex, but pro racers don’t fix flats on the road anyway, so they’re almost certainly after the weight savings compared to a latex tubed tubular.
Thread Killer
Liked 1,769 Times
What stops me buying one as an emergency spare is the very mixed reviews in terms of reliability out of the box, especially reports of fragile, leaky plastic valve stems. This season I have been riding without a spare tube. Relying on sealant and Dynaplugs. The idea of a very compact, lightweight tube still appeals as a last resort back-up, but not if there's a high chance it might fail out of the box. In that regard I have more confidence in a regular tube, but don't like the extra bulk.
I don’t use $8 China-direct TPU tubes, though.
Liked 5,143 Times
I was reading reviews of Tubolito and Ridenow. They both appear to have potential issues with the valve stems. Also read somewhere about the valve stems not sealing well with my Silca mini-pump head. Enough bad user reviews to put me off for now.
Thread Killer
Liked 1,769 Times
Hmm, yeah, not heard of those as widespread problems, but I selected Aerothan, and have only used Aerothan, based on the fullness of their technical marketing presentation, which, because it was clear and specific in its explanations and claims, gave me confidence that it was a soundly conceived and well-engineered product. I was not impressed with Tubolito’s presentation, which as I recall was centered on lightweight, whereas Schwalbe claimed specific achievements in weight reduction as well, but also puncture resistance, cut resistance, rolling resistance and presented test results to back it up, with comps to butyl, latex, and a “plastic tube” indicated in orange, a thinly veiled reference to Tubolito, I assumed.
Likes For chaadster:
Habitual User
Quoted: 5067 Post(s)
Liked 8,370 Times
This is exactly what I have done, and why I’ve done it. 2 TPU tubes takes up the same or less space than 1 butyl tube, and weigh less.
Likes For Eric F:
Liked 5,143 Times
Bikes: I have a few
Quoted: 348 Post(s)
Liked 235 Times
Of course -- it's at Excel Sports. Someone pointed me to it in the Totally Tubular thread.
Quoted: 517 Post(s)
Liked 657 Times
How much do you weigh? Is this a track bike? The experience of decades says that if you need over 100 psi on the road then you should be on wider tires. Pumping to that pressure does not make you faster as suspension losses climb dramatically due to the super hard tire having essentially no compliance. Higher pressures mean less traction, faster tire wear, and reduced comfort for no benefit in rolling resistance. What's not to like?
Veteran, Pacifist
Liked 4,927 Times
I ride smooth roads, I guess.
Too much 'compliance' feels mushy - fine if you ride straight lines. Not fine if you descend at 30+mph on a twisty road, as I do on every ride from my home = ~95% of all my rides. YMMV
Thread Killer
Liked 1,769 Times
I'd thought Eclipse disappeared many years ago, but apparently not! I went back to look at BRR's TPU Crr test, and saw Eclipse had been added to the original test results sometime last year. They're pretty hard to find, but this E. Dubied place, somewhere in Germany, seem to be the main source, although I didn't look all that much:
https://edubied.com/products/eclipse-endurance-tube
