Was there ever an FC-7700 compact?
Bikes: (shortlist) Cyclops, Marinoni, Mariposa, Air Firday, Pocket Rocket Pro, NWT, SLX Fuso, Claude Pottie (France) x3, Masi Team 3v, Lemond Zurich, Bianchi OS
Quoted: 169 Post(s)
Liked 34 Times
I expect Shimano back then assumed that if you were riding Dura Ace you were strong enough to not need a compact crankset.
but time waits for no man and the hills are starting to feel steeper.
I would like to keep the look of my 7700 groupset.
but I don't think there was ever a compact FC-7700
is there a workaround or alternative to lower my small ring toothcount?.
Quoted: 1613 Post(s)
Liked 1,806 Times
They have a triple crankset in the 7700 generation, but no compact
Likes For icemilkcoffee:
I don't think there was a Dura Ace compact crank until the 7900 series; the 7800 series offered a triple.
Likes For ljsense:
Blamester
There is a long cage 7700 rear derailleur if that helps. You can go bigger on the back. 7800 looked exactly the same but i don't know if there was a long cage version.
Or a triple.
Or a triple.
Quoted: 1626 Post(s)
Liked 2,693 Times
I looked. Ended up with a r700.
Quoted: 169 Post(s)
Liked 34 Times
in fact it is my brother who was asking me.
I suggested a triple (I even have an Ultegra tripe complete groupset) but he is too proud to ride a triplel it seems.
Makes no sense to me but....
Quoted: 3614 Post(s)
Liked 3,033 Times
I'll admit that I simplified my question and phrased it in the first person, as a "Me" question.
Quoted: 1446 Post(s)
Liked 2,020 Times
with a compact and semi-compact double cranksets and cassettes with fairly big large sprocket and 11 and 10 tooth small sprocket he can have low gears for climbing and still have top end ...
Quoted: 456 Post(s)
Liked 486 Times
The answer (no) was already stated; I believe compact cranks came about during 10 speed, so the 7700 line would not have them. When I used to run Ultegra 6600 I went with a R600 or R700 compact crank. It was a technically non-series component but it matched well with the rest of the 6600 line.
Likes For tFUnK:
Quoted: 4558 Post(s)
Liked 1,697 Times
Richey made compacts that fit on that Octalink BB.
I run 7400, 7700, 7800 cranks.
7400 and 7700, i run 47, 48, 49 big rings, 39 small. If you have a clamp on front derailleur, just move it down a bit. For braze on , get a front derailleur extender .
i run 28 or 30 cassettes, even 32 with a woolftooth rear der extender
7400 and 7700, 130 generic rings are easy to find and wont ruin the look
Quoted: 523 Post(s)
Liked 460 Times
To maintain the look your best bet would be an Ultegra triple. My choice would be to forget the look and get a newer compact crankset by Shimano or FSA, and upgrade the bottom bracket to outboard.
Liked 1,697 Times
Be aware that front derailleurs don't like jumps larger than 16 teeth, and the smallest chainring you can put on a 130mm BCD is 38t, and those are difficult to come by and as soon as the teeth or chain begin to wear a little the chain my start skating over the shims between the rings. And a 2.5 percent gain is negligible.
Likes For Kontact:
Keefusb
Bikes: 60cm 1992 Paramount, 60cm 1995 Cannondale R900 (son's bike), 1994 Cannondale H300 (mine), 1994 Cannondale H300 Killer V (wife's bike), 60 cm 1989 Eddy Merckx Corsa Extra SLX
Quoted: 83 Post(s)
Liked 58 Times
Stronglight makes a 38T inner chainring that is compatible with 7700. If you get them in silver, you have to get right up on top of it to see that it isn't a Shimano ring. The Stronglight 38T is also available in 7005 aluminum, which is a pretty hard alloy, and should last a long time. I have the 38T inner rings on both of my bikes with DA 7700 cranksets. It sounds silly but there is a very noticable difference between a 38T and a 39T when climbing.
