Crankset, stripped pedal threads, looking to replace.
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
I have a 2019 Kona Rove ST that I bought new, and it has the stock "SRAM S350" crankset that came with it. Upon removing the pedals that have been on for years to try some new ones, it turns out the right side crank pedal threads are stripped. Stripped like, you can slide a pedal in and out--will not grip/tighten (I had installed a new set of pedals---all seemed good, but after about 5 min of riding the right pedal came loose, and now no pedal can be tightened in there. My guess is the previous pedal must have been in a little off. I noticed upon removing it some metal shards coming out).
Maybe this is repairable? I dunno how much can be done in a case like this. I'm fine w replacing the cranks, but I can't find the same "SRAM S350"(that's the only spec I have on it from Kona) crankset anywhere. There are some on eBay, but they're named a little differently(for ex. "GXP"), and I'm a bit of a noob with this stuff.
What specs should I be looking for in researching a replacement crankset for this bike?
Pretty sure this is it: https://www.sram.com/en/service/models/fc-s350-1-a1
https://archive.konaworld.com/archive/2019/rove_st.cfm
Here's one that looks similar on eBay:
https://www.ebay.com/itm/19492311385...640cb63b344011
Quoted: 4590 Post(s)
Liked 1,740 Times
You could repair it with a heli-coil. Or replace the arm.
Quoted: 1110 Post(s)
Liked 1,050 Times
GXP is a reference to the style of crank/bb interface. GXP is a through axle system with a built in spindle on the chainring side that's 24mm on the right side but 22mm on the left side. The crank probably also comes in DUB which is a 29.something diameter spindle. Suggests you'll need to know which standard your sram 350 crank is using. However, the kona specs say GXP for the BB, so yes, the GXP 350 crank in your ebay link will fit the bb standard the kone parts list claims the bike came with.
Likes For Russ Roth:
Likes For choddo:
Quoted: 559 Post(s)
Liked 501 Times
Beware of the thread insert taps that incorporate a taper reamer to take the hole out to size - they're a pain to use and IME don't cut a clean properly sized thread. Maybe the set I had was a cheap knock-off, and there are good ones that work, IDK.
Likes For grumpus:
Quoted: 284 Post(s)
Liked 313 Times
Thanks for all the replies. Kona sent me a couple SRAM links that should work as this S350 was either an OEM spec piece only, or has been discontinued. But as they also suggest, I'm gonna take it down to my LBS and have them order something, just to make sure!
Likes For pbass:
Bikes: old ones
Quoted: 26481 Post(s)
Liked 10,448 Times
I would suggest asking the place you take it about either a threadsert repair, or an old standard spark plug helicoil, which are still available in RH threading (that is the same as pedal threading), if you look around. The old car guys use them (a lot). But most cities big enough to support a bike shop will have at least someone who can do threadsert crank repairs. When I worked at the co-op here, I did many of them. Got a couple of nice cranks that way, that were otherwise getting tossed.
Threadsert repair kit from Unior
Helicoil crank repair kit (cheaper...possibly a better repair)
If you start calling auto parts places, you want a helicoil in RH thread that is 9/16"x 20tpi. It's an obsolete standard for cars, but they are still around for obsolete car repairs.
Likes For 3alarmer:
Bikes: old ones
Liked 10,448 Times
...they work OK, as long as you remove the crank arm from the bike, hold it flat in a bench vise, and make sure you are tapping your new hole at 90* to the arm. ( I use a small carpentry square to check as it starts to bite in.) Some cranks are more easily tapped by starting on the back side, which is usually pretty flat. The threadsert needs to be locked in with red Loctite. Helicoils are easier to use, if you have access to them.
Likes For 3alarmer:
