Is this bent or?
Is this bent or?
This is from a 1975 Schwinn Suburban. One side of the caliper is bent forward, something I have not seen before. It lines up well with the cable as it is now, so I am wondering if it was done this way at the factory. The brake works OK and I probably won't try to bend it back but I am just curious.
Quoted: 3646 Post(s)
Liked 3,087 Times
It lines up with the cable?? You know the cable is flexible, right? It will almost always "line up" with whatever it's attached to.
There’s a good reason why you haven’t seen it before. It’s bent. You can probably bend it back. And when you adjust it, get those shoes a little closer to the rim.
Quoted: 6370 Post(s)
Liked 4,971 Times
I'd be leery of bending it back. Might break. So if it's working now, then consider whether it'll be worth the trouble and expense to get something else should you break it.
Hard to tell from the angle of the pic, but that looks like a pretty good bend. I've never tried to bend brake calipers, but I wouldn't think they are made from a alloy that is very ductile. And during that act of getting bent, it probably made that area of the bend less ductile.
note...
This might also be the pic angle, but is your down tube slightly bent? Put a straight edge along the top of it and look at that area just 2 or 3 inches from the head tube. Might just be the way those electro forged head tubes on Schwinn's looked. If that is one of the models that used the electro forged head tube.
note...
Liked 3,087 Times
I'd try to bend it back. If it breaks, so what? Get another one.
Those brakes function poorly enough without the bend, which certainly doesn't help. And it looks like crap to boot.
Likes For smd4:
Likes For KerryIrons:
Liked 3,087 Times
You all who think aluminum breaks every time it bends probably shouldn't ride in airplanes.
Quoted: 568 Post(s)
Liked 508 Times
Just replace it. It isn't worth bothering with. I probably have better in my old parts bin.
Liked 4,971 Times
The OP just needs to be aware that it might break. If it works well enough for the OP like it is, then that is a consideration for whether to attempt straightening. I might try to straighten it. But I also have some brakes on the shelf that I can put back to use if it does break and not have to spend money.
Liked 3,087 Times
I don't think I'd bend it back. At the very least, I would leave it alone if it works OK (as OK as those brakes ever worked). Otherwise, go to your local co-op and get a replacement for like $5-10. You could 'probably' bend it back with no (visible) damage, but that's your front brake. 75% of you braking comes from there. Do you really want to take the chance that it will break just when you need it the most. ...I'm not a mechanical engineer but bending like what's shown in the photo is not like what happens in airplanes when the 'wings' flex.
Quoted: 4624 Post(s)
Liked 1,773 Times
Likes For Kontact:
Droid on a mission
Quoted: 320 Post(s)
Liked 286 Times
Quoted: 442 Post(s)
Liked 1,038 Times
Anyone who has worked on a lot of those old Schwinns or similar bikes has bent those calipers plenty of times. The aluminum used to make them is quite soft and malleable.
Likes For bboy314:
Quoted: 5985 Post(s)
Liked 2,915 Times
This is a very classic problem of that era.
The front wheel spins around, possibly from a crash, banging the upper brake arm against the downtube.
If the brake n is working, leave it alone. If not, replace the brake.
That said, we often straightened the arms successfully, but it takes judgement born of experience to make that decision.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Liked 3,087 Times
I like all the geniuses who say keep using it as is. Bent in a way such that using it will make it bend further.
Bravo!
Bravo!
SE Wis
Quoted: 2756 Post(s)
Liked 3,427 Times
Likes For dedhed:
Liked 3,087 Times
Thanks for all the replies. I am grateful for everyone who takes time to answer questions on the forum. I can see now how the bending could have taken place.
Since the brake seems to be working OK I am leaning towards leaving it the way it is. I am genuinely curious in how continuing to use this the way it is would cause it to bend further?
This bike is destined for an outreach that serves unsheltered people. I think I have some pads to replace these with.
Mad bike riding scientist
Quoted: 6286 Post(s)
Liked 4,329 Times
Airplane hulls aren’t made of cast aluminum.
Stuart Black
Stuart Black
Likes For cyccommute:
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
Liked 2,915 Times
It WILL bend more if banged against the downtube again.
FB
Chain-L site
FB
Chain-L site
Liked 4,329 Times
And if something is bent way out of shape it gets replaced as well as detailed explanations of how it got that bent.
Stuart Black
Stuart Black
