Pot that won’t burn rice
Quoted: 24 Post(s)
Liked 23 Times
I don’t know why but when I start to contemplate cookware I feel a sense of despair and my brain goes foggy.
I love rice to refeul but typical thin bottom pots will burn the rice, especially with my blazing stove. I want to try being real rice instead of instant.
I have two questions:
1.
I need a suggestion for a pot that I can cook rice in without burning the bottom, has a tight fitting lid, and with enough volume to refuel a 250lb guy. Weight is secondary to utility.
2. The rice I like takes about 15min. How many times can I do this with the standard gas canister and a Primus stove. Not sure if I’ll find anywhere to buy more gas
1.
Quoted: 24 Post(s)
Liked 23 Times
Sometimes I find writing questions down clarifying and immediately find my own answer.
So for the benefit of others wondering the same thing, Primus’ website says an 8oz canister has an average burn time of 3hrs using varying heat settings.
Update: certainly not in my stove. Maybe 40 minutes.
Likes For dvdwmth:
Bikes: Custom built LHT & Troll
Quoted: 872 Post(s)
Liked 152 Times
Turn down the flame up to reaching the boiling point. perhaps simmer a few minutes (often unnecessary) and let sit for 30 mins in a pot cozy (e.g. a sheet of Rova -- aerogel, available thru Amazon) . With an HX pot such at the Widesea HX, you'll probably be able to get decent rice with about 6g of butane. Perhaps run tests at home with a small scale to measure consumption. You may also experiment with instant rice, or do your own (i.e. cook at home a and dehydrate. In the field you'd cold soak and warm. probably less than 4g of butane.
Likes For gauvins:
I'm one hell of a rice snob and if I was looking at cooking rice on the go I would give this a try:
https://seatosummit.com/products/x-pot
I would also get an aluminum disk the size of the base. At least 1/4" thick, to help dissipate the heat.
Quoted: 3317 Post(s)
Liked 2,153 Times
Ditto ^
Sea to Summit makes mice stuff
Likes For Steve B.:
Palmer
Quoted: 1701 Post(s)
Liked 1,877 Times
Hawkins Ceramic Nonstick 1.5L.
7~8 minutes tops in the Hawkin.
If you are burning rice, it means you are keeping the fire on for too long. Turn the fire off while there is still some water left. Keep the lid on. The residual heat will let the rice absorb the remaining water.
That's assuming you're making white rice. Fried rice is a different dish altogether.
Quoted: 24 Post(s)
Liked 23 Times
Saw that sea to summit pot today but the only had the giant one.
I love the tiny pressure cooker. Currently cook rice at home in the instant pot in rice mode and it’s a huge improvement over the standard pot and lid. The bulk isn’t ideal but it’s a nice idea for reducing fuel.
I bought an msr stainless pot to try on the trip I’m starting next week as it has a little more heft then the ultralight ones. I’ll see how it goes.
I don’t typically burn my rice but the Primus stove I’m using doesn’t have the most subtle control over the flame and the thin pot I used before would go from cold to incinerate almost instantly. I only burned sausages last time but I was so tired and hungry it didn’t matter.
Quoted: 24 Post(s)
Liked 23 Times
so as a rice snob, what do you like to take on trips? I just bought a bag of new crop Thai jasmine that is pretty great and that’s what’s coming with me. The instant rice I brought along in the past just makes me sad.
Currently nothing particularly special. Of what is available to me Tamanishiki short grain is pretty good. In a pinch Nishiki medium grain will do.
If you have a gas stove top at home and want to make the ultimate rice you need to get a Kamado-san donabe pot. Forget about just being able to cook rice; you'll be able to cook perfect aldente rice time after time, good enough for sushi. If you want to crank the snobbery to 11 get one from the Iga region of Japan, the clay from there is regarded as the best for this purpose. They are not cheap but they are worth every penny.
Quoted: 18535 Post(s)
Liked 15,898 Times
Palmer
Liked 1,877 Times
Maybe you're not after a pot that won't burn rice, but a stove.
Perhaps a different burner with a broad flame head and fine simmer control is the ticket. The Soto Windmaster and MSR PocketRocket Deluxe get good marks in the reviews.
Likes For tcs:
I agree with the above poster, a lot of canister stoves have small high intensity burner heads made mainly for boiling water fast. I have a Primus classic trail stove I take when plan on more than just boiling water for tea. (Actually I have around 20 stoves)
Likes For plumberroy:
Quoted: 24 Post(s)
Liked 23 Times
I thought nishiki was pretty good so I’m curious about this other rice yiu mention. I just love short grain rice with a runny egg on top.
20+mph Commuter
Bikes: Surly LHT, Surly Lowside, a folding bike, and a beater.
Quoted: 1441 Post(s)
Liked 336 Times
Learn to like Minute Rice.
Also instant mashed potatoes and angel hair pasta. It takes more time to get the water boiling than to "cook" these foods. "Rehydrate" the food actually. All can be found in even the most backwoods grocry store.
The rice burns when all the water has boiled away so it is a problem with the cook and not the pot. The time to cook rice is relatively consistent for a given type of rice and so all that is needed is a timer to alert you when the rice is done. Brown short grain rice for example takes 90 minutes whether I am cooking 1 cup or 3 cups in the pot.
I've read good things about the Keith Titanium rice cooker. Never used one myself though.
KeithTitanium
KeithTitanium
Quoted: 24 Post(s)
Liked 23 Times
Likes For dvdwmth:
Quoted: 5234 Post(s)
Liked 3,609 Times
burning? it's supposed to be done, when there's no water left. when it's done, take it off the stove. fluff it up & put it in a bowl, then wash the pot before the residue dries. timing is everything. I also always ad a tab of lube like margarine, butter or a dash of whatever oil is around
also, I remind myself not to walk away from the pot. a little stir now & then doesn't hurt
Quoted: 1172 Post(s)
Liked 448 Times
If weight is really not an issue you could always utillize a small enameled cast iron stock pot to take on the road with you. It doesn't have to be a Staub or LeCrueset - you could obtain something that would work from a garage sale or one of the many off brands like "Martha Stewart" from Target. You could come up with a way to pack the stock pot with the matching lid so that road rattles don't crack the cast iron. The nice thing about the cast iron is once it reaches optimum temp you can turn the flame off and use a timer to turn it back on as needed for diminishingly less and less time until your rice is done to your liking.
For years I used an aluminum cook pot to make rice when touring. I would pick up a can of tuna at the last town of the day and then add water to rice and get it to boil and then turn the heat down to simmer. Once the water gets to the boiling point it is a waste of fuel to keep the flame up and the rice is not going to be as tender if cooked too fast for it to absorb the water. Even my electric rice cookers use an aluminum metal pot for the rice and no problem with burning of the rice on the bottom. A pet peeve of mine is seeing people cooking rice or pasta and leaving the heat on high and boiling off the water and wasting energy.
1.
1.
I had a MSR whisperlite backpacking stove, which could be throttled back to a low flame, sort of! It really ran best wide open. So I found a cooking plate that was made to go over a small burner on a house stove. Heavy but helped, but you still had to watch that flame from going out.
Also I used MSR stainless steel cook set. Heavy for todays standard. You can still get them on eBay.
What I ended up years later was using the jetboil stoves/pot system. Their setup you can cook rice on. I also ended up switching to Quinoa grain and adding a packet of tastebite to it. The Quinoa will be much more forgiving when used on a stove that uses Coleman fuel.
Bikes: 1970s Coppi/Fiorelli beater, 1973 Raleigh Competition, 1972 Bob Jackson, 1970 Cilo Sprint-X, 1985 Fuji Touring Series IV, 1969 Legnano Roma
Quoted: 218 Post(s)
Liked 198 Times
I'd be curious to research pot-cozy idea - once the rice + water at a rolling boil, can a lightweight insulating jacket (over the top as well) keep things warm enough that an extended time (20 mins? 25?) gets you to the same point as a normal 15-min ultralow simmer would.
If so, it could save on fuel, attention time, and even clean-up labor (less stuck-on starch to fight)
