Oval chainring on a Brompton
I tested a C-line 6 bear brompton with oval chainring and standard brompton pedals. It climbed slopes easier and accelerated faster on flat roads too. However during the test ride, the slope was wet after hours of drizzling, so I didn't pedal when going down the slope. I was comparing 44 teeth round ring with 44 teeth oval ring.
I believe that the oval chainring will actually reduce the paddling power if you have mastered the circular pedalling technique with clipless paddles. What was your experience with an oval chainring on a Brompton?
Quoted: 659 Post(s)
Liked 744 Times
Although not a brommie, I have ovals on a few of my bikes and they really shine on climbs.
Palmer
Quoted: 1704 Post(s)
Liked 1,889 Times
Likes For tcs:
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 276 Post(s)
Liked 247 Times
I ride/race XC and CX using either a 32T or a 36T sram eagle chainring. the 32 is circular while the 36 is oval and go the oval one because it was cheap at the time of purchase. I cannot notice any difference between the 2 in term on pedal feel or efficiency. The numbers show the same; I run Garmin powermeter pedals with "cycling dynamic" analysis and on the same CX course, I get the same number in 32 or 36T (with more speed on the 36T obviously).
Quoted: 233 Post(s)
Liked 151 Times
Used to have them for triathlon.
Felt a bit different, but never got better timings nor less tired legs.
I'm also not a 'princess and the pea' type of person, so maybe I was just too boorish to appreciate the refined aspects of the whole thing...
