help me to choose the right spokes
This summer I completely broke my wheels and am in the process of building new ones.
- hubs = Campagnolo C-record/8sp
- rims = Archetype Hson
- spokes = what to mount? ... mumble
- classic 90s bicycle, for regular training, ~40-50Km per day
- for occasional long trips max 160-180 km on weekends
- asphalted roads, never dirt roads or anything else
- slight road stress
- few climbs, mostly flat, so I'm not very interested in the "weight" issue
- I would like to prefer comfort over performance (medium profile = greater inertia and stability)
- average speed 32km/h, maximum speed 50km/h
- many curved trajectories (that's why I prefer c-record with cone and ball hubs, rather than sealed bearings)
- possible routes with cross wind (that's why not high profile, but medium profile rims)
- my weight is around 67kg
- Sapim Race
- Sapim Laser
aged to perfection
Liked 1,317 Times
DT or Sapim, 2.0 / 1.8 butted. I recommend 3 cross rear, 2 cross front
"many curved trajectories" ? I'm curious. please explain how that is a decision criteria for spokes ? or bikes ?
/markp
/markp
![](https://cimg0.ibsrv.net/gimg/bikeforums.net-vbulletin/970x647/spacex_launch_vafb_5adce53a02499d8d7fba309663b695c75c51aef7.jpg)
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Liked 780 Times
or he's mounting JATO Rockets to his bike... that would certainly reduce road stresses... until the bike lands again..which would also possibly break wheels.
![Big Grin](images/smilies/biggrin.gif)
nice pic, btw.
Likes For maddog34:
It's more a decison for the hubs, I see the difference with ones with cones and balls (80s and mid 90s), versus ones with sealed bearings (Campagnolo Chorus > 1997). On curved trajectories those with cones and balls are more efficient with less friction.
The long trips I take on weekends (and the weather forecast says that the weather conditions will be ok and stable for the next 10 hours) are practically all straight, with few curves. Practically the opposite.
The Race ones are 2.0mm butted.
What do you think about them?
I will probably also assemble a third wheel, with a 900g internal gear hub on a Archetype Hson rim: will the Sapin Race be fine in this case too?
Liked 780 Times
Bingo! I go around half of the lake, over and over again, for training. In practice I do the same closed route, I start from A, I go around, and I return to A, the same curves, a lot of bend, all on the flat.
How did your wheels "break"? Did the rims wear out? Spokes snapping? Hubs failed?
personally, i'd advise that you do more basic bicycle maintenance, and less electric shifter discussing.
- Front wheel: rim bent and ovalized, inner tube exploded
- Rear wheel: rim bent
- No damage to hubs, no broken spokes, but two spokes on both wheels are bent.
I dismantled everything, I could recover the Campagnolo Mirage hubs, but I preferred to take two C-Records/8sp hub, which I found NOS but for cheap by pure luck.
aged to perfection
Liked 1,317 Times
Also, sorry to say, Campagnolo Record and Chorus hubs of the 1997 vintage are cone and cup bearings, not sealed. I've had mine apart to install ceramic bearings. See pic #2
going back to your original question, the Sapin Race or Laser spokes will be fine, or DT Competition. Use the 14g (2.0 / 1.8)
/markp
![](https://cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/467x536/force_diagram_8c84171c552b85f16390d451335ec264149500b2.jpg)
![](https://cimg6.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1515/ceramic2_fe2352450df7634de7fb0276cd8da00be1d9ae94.jpg)
really ? ya think ? when you are leaning into a turn there is minimal sideload on the bearings. The apparent "downward" force in a turn is the vector sum of gravity and centripetal force imposed by going around the corner. See diagram below. The force is normal to the frame, which is why you lean into a corner. This effect is discussed at length in "Bicycling Science" by Frank Whitt and David Gordon Wilson. It's like a coordinated turn in an airplane.
- Chorus HB-00CH (1997) cone and cup
- Chorus HB-20CH (1998) sealed bearings
DT are more reliable than Sapim. Pillar are reliable and cheaper than either.
Likes For mpetry912:
Umm, I was thinking about how these two hub tecnologies do support of loads not perpendicular to the ground as the rotation elements inside the hubs must support different types of loads.
- There are those perpendicular to the ground, which act when the wheel is perfectly straight.
- There are those which develop different angles with the ground, when turning or steering; the rotation elements oppose a force opposite to that acting on the hub, in order to cancel it, and it is precisely this type of reaction that differentiates the work of the hubs
- When the wheel is straight, the direction of the resisting force has the same inclination, therefore 90° with respect to the ground, whether the rotation element is a sealed bearing or spheres.
- When the force is not perpendicular to the ground, the resistant direction of the industrial bearings remains perpendicular while that of the spheres follows the same inclination as the acting force. The inclined force will act differently on an industrial bearing, which will offer less resistance, compared to cone and spheres, which therefore guarantee greater resistance to efforts with the wheel inclined with respect to the ground, reducing friction, overheating and wear. of the materials, as well as allowing better smoothness of the hub in these situations.
Liked 2,965 Times
I don't do brands, so am speaking purely about function.
First, use only double butted spokes, because there's no logical reason not to.
As to gauges, go light for the front, either 1.8/1.6 DB or 2.0/1.6 DB. 2x or 3x doesn't matter. I know you're not focused on weight, but there's no reason to build heavier than necessary.
For the rear, 3x 2.0/1.6 DB on the right, and 3x 2.0/1.6 DB on the left. Using thinner spokes on the left (slacker) side makes it easier to properly tension a dished rear wheel without going too high on the right side.
Again, it's not about weight, but finding the best choice for the application.
One hidden beauty in my suggestion is that you're still buying only 2 different spokes if you build the front 3x, because frilont and left rear will be the same.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Liked 2,965 Times
In any case, start by deciding on the type and gauges you prefer, then see who makes them.
It's also OK to mix brands, but not on the same flange, ie. DT for front and left, and Sapim for right rear. Though I prefer not to (less to explain), it's sometimes necessary based on availability.
Sapim has had several documented periods of quality issues leading to breakages. Given the price, I see no reason not to get one of the common alternatives that have no such reputation.
And if you run into some old stock of Wheelsmith 2.0/1.7 butted - those are good, too.
Use regular brass nipples with either Triflow, or Triflow and Spokeprep. (Or boiled linseed, if you must.)
Liked 780 Times
"or DT Competition".. TWO wheel builders in Portland have quit carrying DT spokes... "too many problems" with the double butted ones.. "we don't stock DT any longer" was all the second shop said... i recently went shopping for more spokes... i came home with Sapim Race and Sapim Straight Gauge spokes.. i learned a long time ago to buy in bulk... 100 in a box, and up... i buy nipples 1000 at a time.
I have a preference for the wheelsmith butted when I can find them but prices seem to be going up, the longer taper to the butting is supposed to be better. Last two builds this year were sapim race since they were easily available, don't have any complaints about them, they seem to work just fine. Also never had an issue with DT, based on build I couldn't care if it was DT or Sapim, sapim had the same, shorter butting length but have it closer to the threads and elbow so maybe an insignificant amount lighter.
Liked 4,091 Times
I weigh barely more than the OP and have been using DT Revolutions for all but the DS rear (or the Wheelsmith or Sapim equivalents) in both round and bladed with zero issues and have for nearly forever. OK, so there's twist. Deal with it when you build. (Bladed spokes make the twist easy to see.) Maybe it takes a few more minutes. But for wheels that go on for years and thousands of miles, well worth the nicer ride. (I'm not saying this for everybody, but us sub 155 pounders will do just fine.)
I've used Lasers (28, 3x) and been very happy with them. To finesse the rear wheel dependent on dish make the spoke cross-sectional area proportional to tension so that spokes all stretch the same amount. Sapim have Laser (1.5 mm), D-Light (1.65 mm) and Race (1.8 mm) all with 2.0 mm butts; DS/NDS ratios D-Light/Laser 82%, Race/D-Light 84%, Race/Laser 69%. Monitor wind-up when tightening by marking the butt above the nipple with a Sharpie.
I like and use Revolutions, but you should have a reason to use super light spokes. If the build isn't going to be super light itself, why put yourself through the chore of building with them and dealing with wind up?
An off centered rim would do more to strengthen the rear wheel than this or that choice of spokes
