Is chainbrite (Park Tool CB-4) bad for chrome?
I am restoring a very nice bike with chrome lugs. The bike is very dirty and has probably sat for 30 years. The lugs looked a bit pitted but not much more than surface blemishes.
I had been using a water and dawn mixture to clean it up, but there was some caked on grease on the bb shell. I rubbed a little Park chain cleaner/degreaser (cb-4 chainbrite) to help soften the caked on grease, and it did absolute wonders for the chrome in the bb shell. It was wild. Almost like it's some crazy liquid polish.
My question is: is there any reason I can't clean the lugs with this cb-4? Is it harmful to chrome? Park says it is biodegradable, plant based degreaser, safe on aluminum, plastic, and carbon, but makes no mention of chrome or steel.
Pictures below of the BB after cb-4 was applied, and a before photo to show what it looked like before.
Likes For J_Climacus:
señor miembro
Bikes: '70s - '80s Campagnolo
Liked 6,654 Times
Interesting bike. Windsor?
Biodegradable doesn't make it mild.
I'd be more concerned if it had anything caustic like Brasso, which cleans by "etching".
I've never used chainbrite, but it may work similarly because a chain's wear and tear will really come from mileage, not a chemical.
Liked 2,959 Times
Odds are it's very safe for chrome. But realistically, it wouldn't matter unless it were extremely corrosive.
That's because, whatever harm it MIGHT conceivably cause, it won't be there long enough.
That's true for all solvents and cleaners. Leave them on only long enough to do their jobs, then wipe of rinse them off.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Liked 331 Times
Pretty frame!
The material data sheet is available here:
https://www.parktool.com/assets/doc/..._SDS_en-NA.pdf
It lists 2-Propanol, 1-(2-butoxy-1-methylethoxy)- 2 as the active ingredients. I'll leave it to any resident chemist to delve into what those many be and what plant they come from.
