Basic Cadence Meter?
Quoted: 81 Post(s)
Liked 7 Times
I'd like to get a basic and reliable cadence meter and odometer for my road bike.
It should cost less than $50, be easy to install & operate as well reliable in all kinds of weather including cold & rain. I ride off the grid periodically so it shouldn't be dependent on cellphone networks.
If it will track data on my phone great but it's not a requirement.
Any recommendations?
Location: western Massachusetts (greater Springfield area)
Bikes: Velosolex St. Tropez, LeMond Zurich (spine bike), Rotator swb recumbent
Quoted: 67 Post(s)
Liked 67 Times
You may need to go above $50, especially if you want wireless with smartphone or Garmin integration.
Google "bike computers with cadence".
If you are willing to buy used and don't mind wired and not "smart", used Cateye Astrale 8 can be found on E-bay for well under $50, I am sure there are others but this is what I have used.
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 476 Post(s)
Liked 558 Times
You can get Magene sensors for under $35 from Amazon. They work with phone apps. You don't need cell coverage to use the sensors. They communicate with your phone over the Bluetooth interface.
I run "Cyclemeter" on my phone. Costs $10 per year and does exactly what I want.
I use a bar mount to hold my phone. Mine is made of aluminum and came off of eBay. They are cheap. Just be sure that the mount you get has long enough fingers to hold your phone or your phone case.
All told, it should run you about $60.00 for sensors, mount for phone, and software.
Likes For DangerousDanR:
I have a Cateye Strada Cadence on my bike. Simple, wired.
Might be just a bit more than the 50$ you're aiming for.
Just Pedaling
Bikes: YEP!
Quoted: 347 Post(s)
Liked 563 Times
XOSS speed and cadence sensors cost me under 20 US for the pair on ebay and a free phone app called SuperCycle. I already had the RAM mount for my phone since I was already using it for a bike computer with the GPS function. I found the sensors to be much more reliable but still use the GPS function simultaneously for mapping my rides. Magene are almost the same as XOSS-Blue tooth connectivity. HTH
Quoted: 4008 Post(s)
Liked 7,505 Times
Quoted: 6330 Post(s)
Liked 4,922 Times
Both Wahoo and Garmin make a cadence sensor that is both Ant+ and Bluetooth enabled for < $40. With either of those and a app on your smart phone you can connect to it and record your cadence along with the app using your phones GPS to record your track, speed and distance so you can look at it later. Or even while cycling if your phone shows well enough in the bright sun and you don't mind the extra battery drain.
The Ant+ or Bluetooth will allow you to use that sensor with most any of the common GPS/Cyclometer makers should you later decide to pony up the money for a decent head unit. IE. Garmin or Wahoo.
Some of your more inexpensive wireless sensors might depend on a proprietary standard that limits you to always using that particular brand. Which being the inexpensive brand might break or quit in a year or two. So buying better quality can be the difference between 12 or more years of use vs just a couple years of use before it breaks.
Likes For Iride01:
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 678 Post(s)
Liked 431 Times
The Garmin cadence meter used to be right at $50, and installation involves two rubber bands. Easy, reliable, affordable.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Quoted: 523 Post(s)
Liked 231 Times
Check out the sub-forum https://www.bikeforums.net/electroni...hting-gadgets/. You might see other answers to your question there.
Quoted: 1869 Post(s)
Liked 666 Times
Liked 666 Times
Quoted: 2629 Post(s)
Liked 1,979 Times
Just a person on bike
Bikes: 2015 Trek 1.1, 2021 Specialized Roubaix, 2022 Tern HSD S+
Quoted: 132 Post(s)
Liked 86 Times
The value of your life doesn't change based on the way you travel. - Dawn Schellenberg (SDOT)
