Bearings for SHIMANO DURA ACE WH-9000-C50-TUB Wheels
Hi,
I bought used SHIMANO DURA ACE WH-9000-C50-TU. At least... I think they are SHIMANO DURA ACE WH-9000-C50-TU because they looks the same as these seen on google and they are fully carbon made tubulars.
However, on the wheel itself I see the tagging :
Front : Dura Ace WH-9000 LC SP-13
Rear : Dura Ace WH-9000 KF SP-13
The wheels do not turn as smoothly as I think they should and the springs are rusty.
Can anybody (@gfk_velo :-)...) provide relevant part numbers for :
1. Front wheel bearings (preferably ceramic ?).
1. Rear wheel bearings (preferably ceramic ?).
3. Axle springs
Thanks
3. Axle springs
Thanks
Liked 5,020 Times
See if one of these EV's (exploded views) matches what you have.
You'll probably find that the part numbers are the same for most of the bearings and sets with retainers. But I didn't look to compare.
https://si.shimano.com/en/manual/sea..._model=wh-9000
Other info on Shimano stuff can be found here... https://si.shimano.com/en/#/
Springs? In the free hub or the quick release?
Thanks iride01
The following EVs have all the parts I need...
https://si.shimano.com/en/pdfs/ev/WH...TU-F-3343A.pdf
https://si.shimano.com/en/pdfs/ev/WH...TU-R-3344A.pdf
Hi,
3. Axle springs
3. Axle springs
When you reference "axle springs" are you talking about the centering springs on quick release axles?
Likes For KerryIrons:
Just for your reference, ceramic bearings are appropriate in very high speed, high temperature, and acidic environments. None of that applies to bicycles. Ceramic bearings on bicycles are marketing hype, not performance improvement. Once the bearings are properly lubricated and adjusted, that is as good as the hubs will get unless there is actual damage.
The EVs are a bit confusing...
Front wheel :
Part #3 Y23321000. Volute Spring. Does the part number include 2 springs for both sides ?
Part #6 Y4BN98030. Ball Retainer (5/32"). Does the part number include 2 bearing sets for both sides ? Does the "retainer" include the balls ?
Rear Wheel :
Part #6 Y00091270 "Stainless Ball (3/16") 22 pcs". The EV itself says "13 pcs" which does not correlate to the 22 pcs of the part#. I would expect 26...
Part #7 Y25R98080 Ball Retainer (3/16") Do I need this ? Do they get worn out ?
Liked 3,107 Times
I'll take 'em, no matter the "hype."
Liked 4,003 Times
As to the springs- most all shops have a misc. parts box where they put bits that come off repairs but could still be used. QR springs are one of these items. If fact no springs are even needed, they are much like a threadless headset top cap. Once the QR (headset bearing adjustment) is set the springs (or top cap) are just going along for the ride while adding zilch to the system. Andy
AndrewRStewart
AndrewRStewart
SE Wis
Liked 3,428 Times
I am referring to the Volute Springs.
Front wheel :
If you look up that part # it shows one spring
Part #6 Y4BN98030. Does the part number include 2 bearing sets for both sides ? Does the "retainer" include the balls ?
Again look up the part # and it's one unit. All the ones on Ebay show the balls included.
Rear Wheel :
See above
There is likely 9 balls in the retainer on the other side so 22. Or it's a typo as we see #11 says "freewheel body" when it's a freehub
You don't "need" a retainer at all and most wheels are loose balls. In fact many people get rid of it and go to loose balls allowing more balls to be used.
You can pop out the old balls from the retainer and fill it with new ones.
Front wheel :
Rear Wheel :
See above
Thread derailleur
Bikes: Croll '94 & Cannondale Supersix '15
Liked 492 Times
Shimano produces high quality hubs. Holds true for the bearings, as well.
From my experience, I highly doubt rust exists, unless someone totally thrashed these.
Most likely, some grit got in there and these require a simple rebuild.
Liked 3,107 Times
I guess someone has to believe steel is better in every instance.
But being lighter and smoother than steel isn't really "hype." They're more like...you know...facts. Pesky, no doubt.
If you're referring to me, you are incorrect. I think that ceramic bearings are surely a better choice for high-speed (e.g., 10,000 rpm) applications in relatively clean environments.
They're lighter by around 5 grams per wheel, depending on the specific bearings. So, yes, that's a fact. But once you pack all the bearings in grease, they're not smoother than steel. Oh, and they might actually be less durable than steel bearings, and they might also damage steel races. A little reading.
Here's a challenge: find a source, other than a company that sells ceramic bearings, that affirms their usefulness in bicycle parts.
Liked 3,107 Times
Not worries. Will continue to run them to no appreciable detriment. Have fun.
I didn't read any company's marketing materials. Ten grams is ten grams. Adding grease doesn't make ceramic bearings rougher than steel. And by the time I "dent" my races using ceramic bearings, my bike will likely be in the landfill somewhere.
And I never claimed that adding grease would make ceramic bearings "rougher" than steel...Rather, it eliminates any (theoretical or measurable) advantage of ceramic bearings in the friction measurements, as explained by an authority in the linked article that you didn't read.
Ceramic bearings won't necessarily create "appreciable detriment" on a bike; they're just pointless, like tits on a bull.
Liked 3,107 Times
The point is making MY CUERRENT BIKE as light as I CAN MAKE IT. Simply, really. For most people.
Nice Glory reference.
SE Wis
Liked 3,428 Times
Every has to figure out their own cost/benefit ratio of grams to dollars
Buy yourself a package of the same-size Grade 25 steel balls. Stainless not required. If the inside of your hubs is such a watery mess that you need rust-resistant balls, then you have much bigger problems. Such as using a pressure washer to clean your bike, or driving at highway speeds in a rainstorm with the bike on a rack.
Pop the old balls out of the plastic retainer and press in the new ones.
Likes For Dave Mayer:
If your steel ball bearings are rusting, then there is something seriously wrong with your maintenance procedures. Ceramic bearings will save maybe 10 grams per hub, which is meaningless. Ceramic bearings are "smoother" than steel bearings only if they are higher grade than the steel bearings. You clearly have bought the hype.
Liked 3,107 Times
[QUOTE=AvantGarden;23058595]Hi,
3. Axle springs
Thanks[/
Ceramics are a waste of money for our use. You can replace the balls in the retainers if they show excessive wear. If the balls have their factory finish, they can be reused.
3. Axle springs
Thanks[/
Liked 3,107 Times
