Tubes on Gravel bikes??
Curmudgeon
Bikes: Specialized Diverge Comp
Liked 33 Times
Is anyone still riding with tubes on their gravel bike? Since jumping into gravel riding and bikepacking several years ago, I've ridden only tubeless. However, I thought it would be a good thing to clean out all the old Stans sealant and add new. Now, I cannot get the tire to seat properly, and I've tried everything I know. It's crazy. Instead of continuing to fight it, I thought I could just install tubes, since the TWI show lots of tread still on the tire. Thus, I'm curious; is anyone riding their gravel bikes with tubes?
Liked 493 Times
Yes, while I also like tubeless, I've gone back to tubes (TPU) because they're light/supple and I tend to switch out tires often so tubes are less messy.
Liked 4,001 Times
Of course there are. Perhaps we just don't feel the need to post about it
Andy
![Smilie](images/smilies/smile.gif)
AndrewRStewart
AndrewRStewart
What are you using to inflate them ?
Liked 2,207 Times
I have 2 mt. bikes that are tubeless, yet kept the gravel and road bikes tubed. I just find tubes easier to deal with, I've been riding 35 years and am pretty proficient at changing a flat, as well I rarely get flats.
Likes For Steve B.:
Liked 4,001 Times
Likes For Andrew R Stewart:
A little soapy water around the bead will help the tire to fully seat. Also an air compressor or a floor pump that can introduce a lot of air at one time can help.
Likes For choddo:
Yeah that’s exactly what I was going to suggest. A bit of soap and a track pump with a reservoir (or a compressor) usually do the trick.
Likes For choddo:
Gravel and tubes works for me.
Never had a flat on gravel,either.
Likes For rccardr:
Bikes: 3Rensho SuperRecord Export, Bridgestones MB1 RB1 XO2, Colnago Super, Medici GranTurismo, Schwinn Paramount, Olmo Competition, Raleigh Portage, Miyata 1000, Stumpjumper, Lotus Competition, Nishiki Maxima, Panasonic DX6000, Zeus Criterium
Liked 91 Times
also cross posted in the thread "Do tires (tubeless) not hold air as well as they age?"
i've heard and read this to be a problem with tubeless. the handful of my friends who have at least one bike tubeless wheelset have discussed the pros and cons. one con being : if they have to remove the tire for some reason - they can't get the tire to seal again well enough and end up tossing the tire and having to buy a new one . seems like one of the bigger potential downside to tubeless
Likes For brooklyn_bike:
Liked 91 Times
OP describes same problem you're having : https://www.bikeforums.net/bicycle-m...-they-age.html
Just curious - I recently swapped in some used tires I had that still had some life left in the tread on my gravel bike. Same rims the tires were originally on. I'm used to tubeless tires going through phases where they seem to fluctuate in how well they maintain pressure when new (at least this has been my experience) as the sealant does its thing, but these tires just aren't settling back in and stabilizing. I've gone over them and I don't think there's any leaks at the valve stems, and the bead is seated all the way round. I don't see sealant coming out anywhere. I've put in a double dose of sealant too. Could it be that older rubber gets more porous as it's more dried out? These have been sitting in a hot garage for the better part of a year.
Liked 2,207 Times
Having ridden for 4 years on tubeless mt. bikes, I certainly see the advantages for a gravel riding situation. I run much less air on my mt. bikes, around 15-20 psi and the ride is terrific. I’m just too lazy to bother setting up my gravel wheels for tubeless.
Likes For Steve B.:
Until the sealant creates a thick enough layer on the inside of the tire, air will leak out. Takes several days of riding to get the sealant evenly distributed around the inside of the tire/rim. As long as everything is mounted up properly, and the right amount of sealant used, the tire will eventually seal. Been tubeless on my MTB for years. Some tires leak more than others. Especially old used tires.
Likes For frdfandc:
Liked 3,054 Times
Jan Heine of Rene Herse fame or infamy often uses tubes depending here is a pretty good write up on tubelss https://www.renehersecycles.com/tubeless-faq/
Life is too short not to ride the best bike you have, as much as you can.
Likes For squirtdad:
