1979 Motobecane Mixte, "before & after"
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 481 Times
This became available to me as a project, and I couldn't say no. There's a lot of junk around, and while this isn't rare or special, it certainly wasn't junk and deserved to be put back in rideable condition. I had a lot of fun wiring up the dynamo lights, a great little addition that I think more bikes should have.
As received. Note the free security chain!
Here she is, "refreshed".
Likes For ridelikeaturtle:
Quoted: 891 Post(s)
Liked 2,325 Times
Good looking bike. I can see that bike cruising around the streets of Ireland.
Likes For Kabuki12:
Likes For daverup:
That buffed-up very nicely. I see you changed the headlamp: matching Soubitez lamp and bottle dynamo?
"... a great little addition that I think more bikes should have."
It would be nice if more frames had the mounting tab, avoiding those horrible clamps!
Likes For gilesa:
Quoted: 605 Post(s)
Liked 481 Times
It appears to be in the "Soubitez" style; but it's just the least expensive option I could find on aliexpress. Works well, and not far off the style of the original (especially the rear, which is nearly identical), though the wiring that came with it was quite thin. Instead of using a single wire from the dynamo to the lamps and using the bike as the ground/earth, I went with a better quality double-stranded wire to have a dedicated ground/earth wire, for a more reliable circuit.
Bikes: Aluminum and Steel
Quoted: 124 Post(s)
Liked 440 Times
That turned out gorgeous! I’ve never considered owning a mixte before. But seeing one that looks like yours gets my gears turning.
“Ride like the wind boy! Ride like the wind…”
-The Voice inside my head, circa 1982
Likes For IdahoBrett:
Quoted: 4555 Post(s)
Liked 6,513 Times
Looks like maybe fork replacement and has forged RDO w/hanger, true twin tube mixte Moto, sweet!
What does the tubing sticker say?
Any model name that you can see?
Likes For merziac:
Quoted: 605 Post(s)
Liked 481 Times
Also correct on the fork replacement at some time in it's life, I suspected that too, since this one appears to have maybe once been painted red on the upper 3/4ers of it, with the exposed chrome on the lower fork legs more pitted.
The tubing is 2040, which I know nothing about, but according to another post here on bikeforums, is just one step above gaspipe. Well, this bike is never going to be light, so might as well be compliant.
Quoted: 605 Post(s)
Liked 481 Times
With the catalog info I'm seeing, I'd say "1979" is as good a bet as any, unfortunately. A lot can happen between the factory, to the distributor, then at the bike shop, and over >40 years of bumping around.
Most likely a Mirage, given the handlebars. (All the other models, seem to have drop bars.)
Liked 6,513 Times
There was no model name anywhere. I didn't search very hard for an old Motobecane catalogue, that might show up something. "steel-vintage dot com" has exactly this same bike, same color, right down to the same stamped number on the bottom bracket shell (obviously not a serial number), and they said it was 1979, so I'd believe that.
It is a split TT but cool as heck, very nice.
Moto's are my favorite bike boom bikes, always seemed nicer and more elegant than many others to me.
Likes For merziac:
Liked 6,513 Times
And a Paramount just for fun.
Likes For merziac:
Liked 6,513 Times
I always have my eye out but really tall ones are very scarce.
Also keep in mind that "mixte's" are not womens bikes, it literally translates to "universal", one for all, butcher, baker, candlestick maker, postman, cobbler, etc.
Many companies only made just mixte's, nothing else.
Likes For merziac:
Bikes: Litespeed (9); Slingshot (9); Specialized (3); Kestrel (2); Cervelo (1); FELT (1); Trek (2)
Quoted: 440 Post(s)
Liked 3,553 Times
You tell your bike she looks even more beautiful now than she did in 1978!
WTB: Slingshot bicycle promotional documents (catalog, pamphlets, etc).
WTB: Bicycle Guide issues 1984 (any); Jun 1987; Jul, Nov/Dec 1992; Apr 1994; 1996 -1998 (any)
Likes For SpeedofLite:
Quoted: 343 Post(s)
Liked 637 Times
It is amazing what a good cleaning will do if the bike has good bones to start with . Add some polishing of the brightwork, new tires and grips and it looks like a new bike.
I do this stuff all the time at the Bike Exchange. I go in every week and check out what is in the to be worked on pile and am frequently rewarded with a bike that has spent the last 20 or 40 years hanging in someones garage, is dusty , with flat tires, and oxidized aluminum bits . A few hours , a few parts , and it is like new.
congradulations on a fine job.
Don't knock the 20/ 40 Hi ten steel. It is definately not gas pipe. Raleigh used it extensively on their "hundred year bicycle" and it is a good choice for a utility bicycle. For one thing you won't get many dents iin that tubing.
Likes For capnjonny:
Hi everyone, just came across this thread while looking for info on a 1979 motobecane diffusion bc1 - looks exactly like the one you restored. Really nice work by the way.
Likes For jelenart:
