Tall Quill Stems Other Than NITTO Technomic?
I want to put a tall quill stem similar to a Technomic on one of my bikes, but I also plan on having that stem pantographed. NITTO Technomic stems have the "Technomic" logo engraved on their sides, making it difficult to panto them. Do any other manufacturers, vintage or modern, make a similar stem with an extra-long quill?
Check out www.djcatnap.com for articles on vintage Japanese & French bicycle restorations, components and history.
Quoted: 1637 Post(s)
Liked 1,856 Times
I'm partial to 90 degree stems , instead of tall Technomic type stems. When the 'rise' exceeds the 'run' the stem starts to look awkward. With a 90 degree stem there is less of the rise.
Anyways, a Sakae stem should provide some space for pantos:
Once you strip the black paint and logo off.
Likes For icemilkcoffee:
Quoted: 803 Post(s)
Liked 760 Times
Soma, and Origin8 both have a tall 26.0 stem. Don't believe either are quite as tall as the technomic though. And both have print of some kind that will have to be removed.
Bikes: Vintage Raleigh and more modern Roberts
Quoted: 58 Post(s)
Liked 165 Times
Kalloy make similar stems that are cheaper but not quite so nicely finished as Nitto but perfectly good quality that might suit your needs, search Kalloy Uno for different models I have this one on a bike.
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 545 Post(s)
Liked 1,079 Times
The Soma Sutro stem splits the difference between the Technomic and most normal height stems. It is about 1 inch shorter than a Technomic stem. There is a design laser etched on top and Soma is etched on the sides. I have several in black and silver, both 25.4 and 26 mm. Here is one on my Cannondale.
1990 Cannondale ST400
Likes For Pompiere:
I'm partial to 90 degree stems , instead of tall Technomic type stems. When the 'rise' exceeds the 'run' the stem starts to look awkward. With a 90 degree stem there is less of the rise. Anyways, a Sakae stem should provide some space for pantos. Once you strip the black paint and logo off.
Likes For Catnap:
Quoted: 1137 Post(s)
Liked 653 Times
In terms of vintage stems, I believe Belleri made some tall plain quill stems comparable to Technomics. I saw a few at Yellow Jersey in Arlington WI last time I was there.
Tell us more. I would love to know how you will do the pantograph work.
"It's a fine line between absolute genius and sheer stupidity"
For the Zunow stuff, however, I'm planning to work with CycloRetro in Melbourne, Australia. La Vie Velo Classique is not currently doing panto work on brands the owner doesn't already have set-up for. I reached out to the owner of CycloRetro and he has done Zunow pantograph work before. He's also open to doing new brands, and doesn't charge a set-up fee for them. His prices are very reasonable, and from the photos on his website, everything looks top-notch. It'll cost over $1000 for a full groupset, but when you consider the unobtainium-level rarity of a full-panto Zunow group, and the typical time and costs it takes to acquire each component on the vintage market (if you can even find it!) it's by far more cost-effective to have it made custom.
Quoted: 805 Post(s)
Liked 1,839 Times
Back in the day SR did make a lot off nice 1 inch unbranded minimal branded stems with either or both tall height or long length but like the one I have most are on working whole bikes. But relatively plain and basic with nice smooth light finish and quality alloy good for engraving polishing if you can find one. Random example off ebay I have no relation to seller just a example.
https://www.ebay.com/itm/25632985157...Bk9SR8DL4ZyIYw
Bikes: I hate bikes!
Quoted: 432 Post(s)
Liked 732 Times
Not sure if this style would work but I got this on Amazon for $12.
https://www.amazon.com/WEERAS-1-Bolt...grid_rp_0_16_i
Likes For fender1:
Quoted: 432 Post(s)
Liked 732 Times
I saw those and was interested, but concerned it might be low-quality due to the price. Can you share any photos of the actual stem you received? What’s your thoughts on the quality now that you have it in hand? Also, is it made of steel or aluminum? It looks like it might be steel…
I can confirm it is aluminum. The finish is good, not great. I imagine it could be polished a bit more.
It only seems to be available in a 90mm length.
Hope that helps!
Likes For fender1:
fender1 thanks for the photos! I agree that the finish of that stem leaves a bit to be desired, especially from that last "behind" angle. However, that could be cleaned up with an hour or two in the workshop. It's classy and tall, and a good deal for vintage restorations.
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 589 Post(s)
Liked 706 Times
Ditto on the SR. They made a Technomic length one, but in short reach. I also found one about an inch shorter in about an 80 mm reach. I like it. @Pompiere, what bag is that on that nice looking Cannondale? It fits nicely with that build. Classy rig.
Quoted: 545 Post(s)
Liked 1,079 Times
Thanks! What else to use on a Cannondale bike but a Cannondale bag? It is a Cannondale Signal that I bought back in the 1980s. I found the bike two years ago at the Bowling Green swap. It had been rode hard and put away wet, but it cleaned up well.
Quoted: 589 Post(s)
Liked 706 Times
Thanks Ron. I wasn’t aware of that version of Cannondale bag, but I like it. I hope I’d doesn’t suffer the fate of my older Cannondale bags and break at the attachment latch. I don’t have an aluminum bike and was never very interested, but the ST Cannondales do look interesting to try sometime. My only gripe is that I read where even getting 32s on was a bit iffy.
Zenith make a 180mm quill stem without any branding. It is the same as the Dia Compe Gran Compe one but half the price. It comes in 25.4 or 26.0 clamp size, but I think it is only available in 80mm reach.
Quoted: 589 Post(s)
Liked 706 Times
Found a pic of the 80mm SR. It is about 22.0 diameter vs 22.1 on some others that are marked 22.2. With the wedge bolt it snugs up nicely and looks plenty vintage. Fairly tall too.
I did have to search for a time on eBay to find this one, and I don’t remember seeing it in this height longer than 80 reach. The 60 reach is more common, and taller still. I think Origin 8 also makes one that is more modern looking. The lettering is easily removed on it.
