Vertical Bike Storage
Quoted: 607 Post(s)
Liked 690 Times
Guess it's time to upgrade my storage.
I've been using a cheap gravity stand that leans on the wall and it's good for 2 bikes and kind of... meh.
My goal is to store 6 bikes (one of which is a fat bike) vertically hanging by the front wheel and am looking for suggestions.
Right now I'm considering a simple wide hook from a hardware store for each bike into a stud.
Is there a better solution?
(didn't find a recent vertical storage thread)
Quoted: 1605 Post(s)
Liked 1,788 Times
I use this type:
It works fine. Unlike hooks you don't have to drill anything and you can move the stand around as needed.
Likes For icemilkcoffee:
Likes For Steel Charlie:
Quoted: 9660 Post(s)
Liked 6,366 Times
I use Gladiator GearTrack panels and hooks. It’s sold at Lowe’s. Inexpensive and has a finished look.
Quoted: 7084 Post(s)
Liked 11,188 Times
Likes For Koyote:
Quoted: 4543 Post(s)
Liked 5,049 Times
Likes For PeteHski:
I was thinking the same. It is a routine thing to stand a bike on the rear wheel to wheel it around the shop or anywhere in tight quarters. Quite quick and easy. From there it is an easy lift. I have a hard time picturing how you would easily lift the rear wheel to a hook.
Likes For staehpj1:
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
Something like this, spaced approx 30cm apart, alternate the bikes up and down, works great.
Quoted: 887 Post(s)
Liked 2,320 Times
^^ Very nice set up. I store my bikes in a conventional bike rack in my shop where my machines are . I keep one or two bikes at my house . Usually one of them is on the stand for maintenance. Vertical storage makes more sense for residential storage .
Likes For Kabuki12:
Liked 5,049 Times
Quoted: 1090 Post(s)
Liked 707 Times
Try it both ways. You'll see.
Likes For sweeks:
Liked 5,049 Times
Because the front wheel flops around, so you have to control it and line it up while you're hanging it up. With the rear wheel you can grab the frame literally anywhere and just lift it up and onto the hook, without worrying about the front wheel. If the bike is light enough you can do it with one hand.
I have so much room now, I need more bikes.
Likes For bblair:
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 344 Post(s)
Liked 245 Times
I hang a couple of rim brake bikes by the wheels from the garage ceiling, but beware if you don’t know, hydro disc brakes don’t always react well to being upside down.
I have had the same situation. Also I have had one where the hook was on a wall and higher up over something that the bike had to be lifted over. I find it easier to roll the back wheel over the bench, generator, machine, or whatever obstruction. Also I am likely to have to roll the bike down a narrow obstructed aisle to get to the wall it hange on and rolling it vertically makes sense.
Liked 707 Times
Yes, my comment was for situations where you have to lift it off the ground. Your setup looks easy to use. How do you accomodate different types of bikes, with different wheelbases? I'd need to accomodate 700c and 26" wheels, and even within those groups there's a variety of lengths. Seems like a setup with adjustable hook height would be nice.
Quoted: 7674 Post(s)
Liked 3,557 Times
I stand the bike on the rear wheel, wheel it into position, and put my knee into the back of the seat for leverage. Easy to use a tilt of the foot to lift the bike while holding the bars ... bike goes right onto the hook. Lifting a heavier bike by the rear wheel has not proved to be as easy---I tried both ways. Also, harder to find a secure grip on an inverted bike--a hand can slide on the top tube pretty easily.
All my bikes hang clear of the floor ... because I have bikes of different lengths (plus my wife's bike) I would have to adjust each hook to each bike ... and I like to switch the hanging order so the bikes I am riding more are nearer to the end. Also, no studs---straight cinder-block wall. I decided to build an overhead shelf/rack combination. It was great when I built ti, but now there is so much stuff in the garage it takes a wrestling match with an octopus to extract a bike.
What I wanted was sort of what @ridelikeaturtle has. What I got looks like three chimps on speed got into the power tools. Oh, well.
Likes For Maelochs:
Liked 5,049 Times
Method to My Madness
Quoted: 2039 Post(s)
Liked 1,533 Times
... works better than something like this: Project Source 1-Bike Horizontal Bike Hook in the Bike Racks & Storage department at Lowes.com
Likes For mpetry912:
Quoted: 3594 Post(s)
Liked 3,014 Times
In the shop we hung them by the front wheel. Conveniently, bikes come with these built-in hand holds that allow for easier lifting.
Likes For smd4:
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
I hang two short wheelbase recumbent bikes on a wall with supports from Amazon - very similar to what I’ve seen in home improvement stores. Rear wheels not far above the floor, which makes it much easier to hang up compared to ceiling mounted hooks.
https://www.amazon.com/Storage-Verti...8&sr=1-16&th=1
