Seized rotor bolts
Quoted: 53 Post(s)
Liked 5 Times
Seized rotor bolts
Ugh . . Removing a 6-bolt rotor. Bolts were stuck. Sprayed with PB Blaster, and 4 of them came out. The other two rounded.
I realize now I should have slotted them with the Dremel, but I drilled them out to remove the rotor. Now the studs are still in the hub. I can’t get them with the vice-grips — not enough of the bolt is above the surface. And I don’t want to use the dremel now for the same reason.
What’s next? I sprayed with more PB Blaster in the meantime. I’m thinking a reverse drill bit and extractor is the next thing to try. Any other suggestions?
Quoted: 863 Post(s)
Liked 1,105 Times
If you have the right sized reverse bit than try that first and if no luck try the extractor bits. A regular bit with extractors will also work fine. Let the PB Blaster do it's thing for at least a couple days if the drill/extractors don't work at first. If you happen to have a mini-butane torch try heating up just the bolt a little or a soldering iron on the bolt can help too.
Quoted: 53 Post(s)
Liked 5 Times
And somewhere I have a mini-torch from my golf club-building days. Thanks for that suggestion.
Likes For sfh:
Quoted: 568 Post(s)
Liked 425 Times
Please do keep us posted on this, because as far as I am concerned, there is no hope for this short of drilling them through and retapping to the next size up.
The OP messed up when they knew they should have slotted the screws, but didn't do so. Not sure why this happened. I do this successfully all the time with water bottle cage bolts. These are the bolts that are the most exposed to water from above.
Pen oil almost never works on anything that seized up. Heat is your friend here, and a burned piece that can be unfastened is much better than unscathed broken bolts.
Quoted: 1006 Post(s)
Liked 1,688 Times
After letting the PB Blaster sit a few days if it still won't budge then try freezing before heat. I have had much better luck freezing then with heat. Try some "CRC Freez Off". If you can't get a can easy then use a can of Dust Off used for air blasting computer key boards. They usually have Triflorethane in them. Just hold the can upside down and spray your parts.
Likes For zandoval:
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1108 Post(s)
Liked 219 Times
However, right before trying to unscrew, it is important to consider the materials.
I presume that the hub is made of aluminium, and the bolts are made of steel.
So, if you heat it up, aluminium will expand faster and more than steel.
If you cool it, you get the opposite effect - so it might make things worse, more difficult.
Relja
Likes For Bike Gremlin:
Quoted: 687 Post(s)
Liked 456 Times
If you use a reverse bit, try drilling a tiny hole in the centre of the bolt to give it some purchase. On a steel bolt, this is easier said than done.
Generally bewildered
Quoted: 1152 Post(s)
Liked 342 Times
In machine shop work, the first step after Kroil or PB Blaster is usually heat, using a rosebud tip an an oxyacetylene torch. Here, you could use a home depot propane tank and torch tip. But one needs to be judicious and not overheat. If you're not comfortable with a torch, amd possibly ruining the temper of the hub, don't do this. Or find someone who will do this for you (machine shop).
Using a left hand drill could work. But you need to start the hole in the center. You COULD grind the remaining stud flat if there's any protuberance, and then use a center punch, and then a small starter drill, and then put the LH drill in and try it. When center-punching support the arm on the hub with the stud in it. That is, don't just whack the stud with a center punch. Support the hub arm. So put a piece of steel stock in a strong vice, rest the arm with the stud on that, and whack it. The goal is for the shock to be taken by only the stud, and the piece of steel stock, so as to not induce a lot of shock stress on the hub arm.
Frankly, though, this is not a task I'd relish doing with a hand-held drill. I'd much prefer to fixture (hold) the hub rigidly using a mill. First use the mill and an end mill bit to flatten the surface. Then a small center drill. Then the LH bit.
I think you may find that "drilling it out the next size larger " is not easy. The bolt is steel and will shoot your dirll bit into the aluminum hub without warning. My same though applies: if you can fixture the hub on the table of a mill, you will have some control over the hole location. One thought: if your bolts are titanium, they will work harden and you will not get them out with normal drills. You'll need carbide bits.
I never had luck with extractors. All of the problems with LH bits above you have with extractors and they've rarely worked for me.
The last resort I can think of for salvaging the hub would be wire EDM (electrical discharge machining). It will certainly work, but it may be expensive. Find a machine shop. Might be cheaper to buy a new hub.
If you do salvage the hub, the lesson here is to use lots of anti-sieze on the new bolts!
These are through-holes, correct? Any chance that you can access the bolt from the back with a right-hand drill?
Some ideas anyway.
Some ideas anyway.
Likes For WizardOfBoz:
Liked 342 Times
I think a mill (or milling machine) is called the same in the UK. It's like a drill press on steroids. Very rigid. Has a table underneath the chuck that holds a tool (an endmill, a facing mill etc). So that one can move the workpiece sideways and back and forth to cut slots. Here's a used one. It has a face mill mounted in the arbor (for smoothing surfaces as the move side to side or back and forth). But if you put a drill bit in it, and mount a workpiece securley underneath it, the milling machine will drill the hole pretty much exactly where you set it up. The rigidity of the machine minimizes the bit wandering.
Adcock-Shipley and Textron used to build mills in the UK. The most prevalant brand of mills from long ago were Bridgeport machines and hence milling machines are often called "Bridgeports". Here is a pic of a pretty heavy duty mill made by Cincinnati back in the day:
Quoted: 820 Post(s)
Liked 3,065 Times
carbide drill bits/
as mentioned will make a pilot hole mucho easier.heat gun if no mini torch works well also.
One option is just ignore it and run 4 bolts, as long as the two broken ones aren't beside each other it won't cause a problem. One of the old weight weeny tricks was just to run 3. I ran 5 for years after one of the mounting holes on my hub broke.
Drill them out and install helicoils. Lazy half assed option, drill them out and run a bolt all the way through the hole and put a bolt on it.
Liked 1,688 Times
WOW... I want one. Honey... Can I put it in the kitchen?
No, really, nice machine... Thanks for the pic...
Do note that there are Mathematicians, Engineers, and Machinists. Good Machinists are touched by God...
Likes For zandoval:
Liked 342 Times
I want one too, but putting in a three phase 575V 60 amp service is a big discouragement.
Quoted: 568 Post(s)
Liked 425 Times
This thread really is a good example of "think hard before you dig yourself a deeper hole".
I remember my newbie days when I would try to hammer in a seized seatpost, just to get it to unseize with hopes you can twist it out after.
Likes For soyabean:
I am potato.
Quoted: 1826 Post(s)
Liked 1,703 Times
One solid option wouldv'e been to install the wrench and give it a good percussive rap with a hammer to break the friction at the first sign of trouble.
Now with the head removed, a hit on the bolt with a punch to dislodge the friction/corrosion/bond on the upper thread surface of the bolt hole is the next best option. Then perhaps twisting the bolt by the threads from the backside if accessible.
Torx bits are a superior design against round-out. Always remember to try with the next larger size first to ensure you get the proper size wrench. And use sharp tools in good condition.
I secure rotors with torx bolts, copious amounts of blue loctite and torqued at 5nm. Which, because the Loctite sort of acts like a lube, comes very close to 7nm required of a dry installed bolt. If you torqued to 7nm dry, it stands to reason that even if you didn't over torque you may still have galvanic corrosion in the interface that lube or thread locker would have never let moisture in to initiate.
Good luck.
Also the "drill out the threads and use a nut/bolt combo in that hole," as suggested above is a reasonable permanent fix. All machinery designed for regular service over long service life has replaceable hardware as a matter of design. Bicycle hubs should be designed this way. If not for the shop labor component dealing with fiddly small hardware and risk of rotor contamination by service techs grubby hands, they probably would be.
Good luck.
Likes For Bald Paul:
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 276 Post(s)
Liked 461 Times
PB and Kriol are good but also try a 50:50 mix of acetone and transmission fluid.
Likes For biker128pedal:
Liked 342 Times
Yes! All you need is ten 42lb bags of flour, ....., a custom 600 quart bowl, and about 420 baking pans and a VERY large oven. Plus the rewired electric service...
BTW, your strategy is a good one. We had a leak under the kitchen sink at my house. Caused the shelving underneath to sag and decay. My wife wanted it fixed. I dithered. One day she said "You know, to get that done, you probably need a SawzAll or something"....
"Why... yes. Yes, dear, I believe I do".
I had a new 3/4 inch marine plywood shelf covered by flooring linoleum installed the next day.
And I have a Sawzall!
Quoted: 557 Post(s)
Liked 500 Times
Otherwise if you have no luck with a 4mm left handed drill, drill it out with a 5mm drill, and then fit a thread insert (Helicoil or similar, they will specify the exact drill size to use).
Quoted: 53 Post(s)
Liked 5 Times
Thankfully, this isn’t urgent. The goal was to swap the rotors to another wheel set, and I have the rotor removed. But I want to have the old wheel in good condition so I can re-use or sell it.
Quoted: 53 Post(s)
Liked 5 Times
Traveling for the holidays, but I’ll post when I get back to make another run at these. I’m optimistic but cautiously so. Initially, I couldn’t move any of these bolts. I sprayed PB Blaster before I ruined all 6 of them. And 4 of them moved pretty easily after. So maybe a reverse drill can get them, but I appreciate the important of drilling in the center.
Yeah, no question I screwed up drilling them out before slotting. Really I screwed up not starting with PB Blaster because I bet all 6 would have come out. I’ll find out when I do the other wheel. I’m definitely a novice at this, and I’ve no shame in a lesson learned.
Happy With My Bikes
Quoted: 887 Post(s)
Liked 2,349 Times
Quoted: 53 Post(s)
Liked 5 Times
The smallest LH bit I have is 1/8”. Is the suggestion to use an even smaller bit (like 1/16”) for a pilot. I only have that in RH, but it should serve as a fine pilot hole.
Happy With My Bikes
Quoted: 887 Post(s)
Liked 2,349 Times
RH or LH doesn't matter for the pilot. And the pilot does not need to go all the way through. Although if you do have enough material on the sides that you can drill through without getting into the threads, that will help with the warming and cooling cycles should you need to do that or it will give you the option of using a screw extractor.
Some pictures would help us to see that we are indeed actually giving you god ideas.
