Shifters for a 21 speed
Hey everyone!
I need help figuring out what shifters to get. I have an old Denali 7005 21 speed road bike with the twist shifters which need replacing. Shimano Revo 3x7. I would prefer to keep the twist kind so I ordered these cheap ones, "MEGHNA Bicycle 21 Speed Shifter Twist Shifter Lever 3 x 7 Speed Grip Shift* from amazon
and no way will they fit around my drop handlebars. The original ones were quite the pain to get off. Can you recommend any twist ones that will work? What should I get?
Thank you, thank you!
Beau
Beau
Twist shifters on drop handlebars? That's new to me. You might strike out on that one. Fortunately, there are other shifters that would at least work. If you don't get an answer here, try your local bike shop - they have suppliers and could probably look that up for you to see what's available.
cowboy, steel horse, etc
Bikes: everywhere
Liked 7,994 Times
Some of those Denalis had split handlebars so you could undo the stem and then remove the shifters that way.
Although the original Gripshifts in the early '90s were made for road bars, the vast majority are made for MTB bars which have a skinnier bar. Not sure what the shifters that came on the Denalis were like.
Likes For LesterOfPuppets:
Those shifters are for very old bikes or maybe some kids bikes. 22.8mm (7/8 in) - your bars are probably 1inch and maybe 1.25 inch where they meet the stem.
Saw an Amazon ad that said “will fit most bikes”. Absolute BS.
edit: although this site claims the Revoshift shifters are also for 7/8in bars. Interesting.
Shimano don’t specify. Have you measured your bars?
Likes For beauknowsdiddly:
Likes For bboy314:
SE Wis
Liked 3,428 Times
Likes For dedhed:
Thanks. So are most MTB bars 22.2 at the ends? I’ve replaced grip shifters once with thumb shifters and they were the same diameter clamp. It was a while back and I don’t remember checking the bar diameter.
Likes For bboy314:
I would have thought there would be more of a weight difference between a Denali and a Denali...
![Smilie](images/smilies/smile.gif)
Bikes: everywhere
Liked 7,994 Times
Clark W. Griswold
Liked 4,234 Times
I mean if you can split the bars go for it otherwise I would avoid putting much money towards that bike. It is made from old boat anchors and hope.
I like that idea! The new ones I got are crappy pieces of plastic! I hate them. I'll be doing something different for sure. $88 bucks for the end ones though.... and could I use a 3x9 shifter on a 3x7 bike? A little expensive but that might just be the route to go. The bars do split. I got them apart and they slid on just fine. I wish I knew about the split bars before I attempted to take the left shifter off. I got it off only in about 20 pieces LOL. Live and learn!
I'm probably going to end up replacing both derailleurs as well as the back wheel. So now I have to figure out what to get there as well.
Thank you everyone for your help! You guys are awesome!
![Biker](images/smilies/biker1.gif)
That’s still considerably less than a pair of STI brifters which are de rigeur on drop bars.
Two other options which I think are worth considering:
bar end friction shifters. More elegant than gripshifts and without the indexing hassle.
in-bar thumb shifters. I just much prefer these on flat bars to gripshifts.
Bikes: More bikes than riders
Liked 768 Times
If you otherwised liked the original Revoshift shifters, then I'd order up a new pair of them. Your original ones were probably SL-RS25 or SL-RS35...which are on the lower end of the Revoshift line. I recommend the SL-RS45 or SL-RS47...whatever you can find easily. These, with the silver bodies, have a much nicer shift feel than the lower grade ones. Pulling cable feels about the same between the two, but letting cable out is much nicer on the higher grade ones. The low grade ones just have a harsh snap-snap-snap feel, but the higher grade ones have some sort of clutch or slip mechanism inside to where you apply twist force and the cable is released somewhat slowly to where it's not just a snap/bang. It's not a 1:1 movement.
Hard to describe, but easy to appreciate, if you've felt the difference between the two.
Clark W. Griswold
Liked 4,234 Times
If stuff is growing on you I highly recommend a shower and cleaning the bike as well. Bikes shouldn't have anything growing out of them or from them. All around bad show.
People do silly things with their Denalis but don't put a bunch into it trust me even if you have had it a while there are so many bikes to be had that you will soon forget about that one.
Thanks again!
Likes For hokiefyd:
Likes For choddo:
Liked 768 Times
If you ordered the RS45 in 3x7 format, it should work on your bike...and I think you'll be happy with how they work and feel, especially compared with the Revoshift model that probably came on the bike (which is probably an RS25 or RS35).
There is a lot of variation in the Shimano Revoshift line. The RS41s also have a silver body, and I think they share the more premium feeling "overrunning action" of the RS45s and RS47s. The RS41s have a slightly different gear display type. Functionally, as long as you buy the model with the number of speeds that matches your crankset and cassette or freewheel, they all should work about the same. In general, the higher the number in Shimano's nomenclature, the more premium the product, at least relative to its peers.
