Rebuild low end RockShox or go rigid?
So, I decided to dig into the Indy C, and found the ends of the elastomers crumbling. Instead of replacing the elastomers, should I just replace the shox with a chromo fork?
Both the elastomers and the rigid fork cost around the same amount, and the reviews of the Indy C say that they’re very stiff and useless on anything besides gravel anyway.
Should I rebuild it or replace it?
Quoted: 1150 Post(s)
Liked 1,783 Times
I would go hardnose, some bikes are ok with a strait swap. Some may claim that you need suspension compensation for the swap. I had the Kona Project 2 on the Trek 930 I did for a campus cruiser.
What bike are you building up?
Likes For SCbike864:
Quoted: 1381 Post(s)
Liked 1,769 Times
Not sure but I might have the same problem.
I snagged this Devenci from the dump (landfill site near my lake cottage). I took it for a short spin after ensuring that it was road worthy and safe to ride. It rides, compared to my vintage road bikes, like a tractor, but that is to be expected. Anyway, looking forward to a complete refurbishment when I get back to Canada in the Spring...
Sunshine
Quoted: 11048 Post(s)
Liked 7,595 Times
https://www.bikeman.com/CARV-FK410S-S1009-RK.html
https://www.bikeman.com/CARV-FK410S-O1009-RK.html
Likes For mstateglfr:
If you're going to use this bicycle for commuter duty, or just tooling around in a metro area, I suggest you get a nice rigid fork with some braze-ons/"bottle mounts." While the suspension is nice to have...it is kind of annoying to maintain over time. If you are unsure of whether you're going to want/need the suspension later, you can always just clean the grease and grime off your suspension fork, and put it away in a clearly labeled box you can shove away in a closet.
I have found that a good overall fit with better-quality tires offers the most cost-effective suspension with the least amount of maintenance. The only major exception to this rule is when riding off-trail/going actual mountain biking.
Likes For smoothness:
Bikes: 2017 Sage Skyline, 2015 Co-Motion Periscope Tandem, 2012 Soma Smoothie, 2006 Kona Jake, 1978 Richard Sachs, 1977 Peugeot UO18c, 1977 Peugeot PRN10, 1974 Allegro Schweitzermeister Model 76, 1972 Hugo Rickert Spezial, 1971 Fuji Finest
Quoted: 120 Post(s)
Liked 634 Times
Rebuild kits
This company has replacement elastomers. I remember years ago, I also found springs to replace the elastomers that worked well for a Quadra 21. Don’t remember that company, though.
https://www.suspensionforkparts.net/...dy-s-1998.html
Likes For Sactown_Albert:
