Punctures
Punctures
Giant Yukon running Maxxis 27.5/3.8”-5.0” schraeder valve tubes with the factory Maxxis tires. The trails I ride have “sand spurs” (pea size ball of thorns) and I have had considerable problems with getting punctures. After talking to two different bike shops that recommended not going tubeless on this bike, despite the rims and tires being “tubeless ready”, I am at a loss on how to avoid this problem.
Clark W. Griswold
Quoted: 4526 Post(s)
Liked 4,230 Times
Clark W. Griswold
Liked 4,230 Times
The trick with the duct tape is having a layer upside down so it is not sticky and then go around like normal with the tape side down.
Quoted: 684 Post(s)
Liked 760 Times
As for "tubeless", I don't know of a single 'standard' that makes a rim actually tubeless.
It's like calling something "organic", there's really no penalty for lying about it.
Tanis rim inserts might be a useful solution for you.
https://tannusamerica.com/products/a...46871379706152
Quoted: 3367 Post(s)
Liked 2,198 Times
Clark W. Griswold
Liked 4,230 Times
Tannus is a good solution but especially in a fat bike will be rather heavy but will certainly help if you do not wish to go tubeless. They aren't super weighty generally but getting to a wide tubeless will be more weight and rolling weight as well. I do use them in my rear Rohloff wheel on a bike but not on the fat bike yet as I think I might want to go tubeless eventually.
