Removing Hub End Caps
I have a set of Bontrager Paradigm wheels and I’d like to remove the hub end cap.
Trek makes a tool
https://www.trekbikes.com/us/en_US/equipment/bike-accessories/bike-tools-maintenance/bike-shop-supplies/unior-hub-genie-20mm-end-cap-removal-tool/p/24925/?colorCode=black
but I’d like to have this end cap off sooner rather than later.
Do you folks know of an alternate way of doing this?
I wonder if this tool would work on other brands?
Trek makes a tool
Quoted: 5995 Post(s)
Liked 2,932 Times
Odds are you can use an appropriate expanding wall anchor. If you can find the right size in a solid wall anchor, fit it in, then use the screw to expand it until it holds, then yank. A hollow wall anchor would also work if there's enough depth to work with.
Otherwise, use a piece of dowel or wood that fits. Drill it and saw one side so it can spread. Run a wood screw in until it jams, and yank.
Unless servicing these will be a regular thing, I'd improvise something before shelling out the dough, even if time weren't a concern.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Can it be drifted out (flat punch and hammer) from the opposite side? I don't know if this is a front or rear wheel, and setup on the other side.
This is a front wheel with center lock on the other side.
I doubt a punch would work due to the sleeve ( lack of better word) inside the hub matches the inside diameter of the end cap, meaning that you won’t be able to get purchase on the edge of the end cap by inserting a punch in the opposite side.
Liked 2,932 Times
I like the integrated finger grip.
FB
Chain-L site
FB
Chain-L site
