Ofmega crank question
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 589 Post(s)
Liked 705 Times
Posting here rather than mechanics sub forum as it seems like a vintage manufacturing question. I’m working on an 1980s bike with an Ofmega crank that I got used nearly 3 years ago. I know no history of it, but it seems low miles but stored poorly for maybe 30 years and probably seldom if ever serviced. Pulling the crank showed marks in the taper in the crank. I just thought perhaps at one time someone used an improper crank puller, although the rest of the crank wasn’t scratched up.
Kinda hard to photograph, but this is how it is along with the nds crank also. Things tighten up fine and no riding problems. Searching the internet however for similar Ofmega cranks shows the same thing. People selling these cranks don’t picture it, but on most one can get a sense of it from pics. Here are photos from the net:
So, what is this? Was it something to do with the manufacturing process? My Park tool puller didn’t cause this, and it seems that most have this.
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
I don't see any such marks on the Ofmega and Avocet (made by Ofmega) cranks I have here. The blemishes look consistent with galling damage. Has the bike been left outdoors and/or in a corrosive environment (e.g. road salt, ocean breeze)?
Likes For JohnDThompson:
Quoted: 589 Post(s)
Liked 705 Times
No history on bike, but no salty environment around here. I just found it curious that these gouges were all at 45 degrees to the taper flats and were present in so many others that I saw pics of. They appear to be mechanically caused and there wasn’t any sign of any other metal or debris upon disassembly either. These marks are also at the very outside ends of the taper where galling shouldn’t happen as the crank spindle didn’t reach that far.
Likes For Mr. 66:
Quoted: 1118 Post(s)
Liked 1,346 Times
The hole was made - possibly tapered - but round; then the taper was machined. What you see is the part of the hole not removed as the taper was made - that's why you see it of the outer part of the taper flat and the bolt seat (the taper is smaller there).
It's not a problem, the crank doesn't bear on the axle at that place but on the corners.
Likes For oneclick:
Quoted: 589 Post(s)
Liked 705 Times
As a side note, these cranks seem quite light with a sort of delicate look and feel. 144bcd doesn’t do it for me though.
Likes For sd5782:
Quoted: 1653 Post(s)
Liked 857 Times
Just make sure you never combine the cranks to a different brand BB as Ofmega uses a proprietary BB with tapers that only works best with Ofmega cranksets.....
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Quoted: 589 Post(s)
Liked 705 Times
Interesting on the bb tapers. This 1984? Torpado has a Campagnolo bb and I am about 99% sure it is stock. I’m not planning on switching anything out on it. It would be another bit of Italian confusion such as I read about other campy bottom brackets and cups.
I have experienced a case where LBS was unable to remove an Ofmega crank arm - their extractor tips (multiple tools)
were too large in diameter, hanging up on the top of the crank arm rather than sliding through to engage the crank spindle end.
They almost stripped out the extractor threads by exerting too much force.
My solution was to cut a piece of drill rod stock so that it extended beyond the end of the crank spindle. I inserted
the drill stock and then set the crank extractor tool so that it made contact on the drill stock, which was centered
in the spindle. The crank came off cleanly.
There is a residue of marking on the crank arm similar to yours.
Likes For cyclophilia:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3936 Post(s)
Liked 6,618 Times
Quoted: 589 Post(s)
Liked 705 Times
I thought of that, but the marks go nearly to the bottom of the tapers. The cranks would have surely popped free long before the extractor would have been threaded that deep. The many others seen on internet searches would have all have suffered the same fate.
señor miembro
Liked 6,618 Times
Quoted: 589 Post(s)
Liked 705 Times
Exactly
Liked 1,346 Times
in the spindle.
in the spindle.
Every crank extraction that screw gets placed in the end of the axle, and the extractor bears on it.
Quoted: 2368 Post(s)
Liked 1,761 Times
A close-up of a new old stock arm might help solve the mystery.
Stop reading my posts!
Quoted: 1467 Post(s)
Liked 1,104 Times
applies to SOME but not to EVERY Ofmega spindle, likewise do not assume it applies to each and every Avocet (rebranded Ofmega) spindle, either. Best to consult Sutherlands for the fine points.
Likes For unworthy1:
feros ferio
Quoted: 1405 Post(s)
Liked 1,356 Times
I wasn't aware of Ofmega proprietary spindle tapers. I replaced the original 144mm Ofmega cranks on the Bianchi with newer 130mm Bianchi-branded cranks that may well have been made by Ofmega, as well.
Liked 1,104 Times
Old fart
Liked 3,454 Times
Only true for early production Ofmega. By the late 70s, Ofmega adopted the same taper as Campagnolo. If your crank uses the early taper, it will sit too far out on a Campagnolo-type taper spindle.
Quoted: 589 Post(s)
Liked 705 Times
Some pics for you folks fluid in Italian and Campagnolo. The only other Italian one I have is a Shimano that I used for a short time on a Frejus I no longer have. That one in 109mm allowed me to use a first generation Superbe crank on that 64 Frejus instead of the cottered 47-50. The Torpado I am cleaning up is stamped 84 on the BB. Shell is 70mm and the spindle is 115.5 withe the drive side being about 2.5mm longer than the nds.
Loosely mounted for photo
Thick cup vs thin?
NDS
Quite a difference in center section, both marked 70
Tapers appear the same
The spindle side by side photo is distorted as the front Shimano spindle is 109mm and the back Camp that is on this bike is longer at 115.5.
Thick cup vs thin?
NDS
Liked 857 Times
IIRC, The Ofmega Mistral cransets I had used on a few builds, might have still required Ofmega BBs to get the chain lines to run correctly, and those cranksets were already from the 80's.....
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1177 Post(s)
Liked 2,073 Times
I'll never understand the Italians copying the looks and designs of one another. Did they not have a proper patent system?
Whenever I see Ofmega cranks, I immediately see Campagnolo, maybe with the arms "mexicaned" out like E. Merckx' bike.
"Leave the gun. Take the Colnagos."
Old fart
Liked 3,454 Times
Quoted: 589 Post(s)
Liked 705 Times
I notice that one has the marks that I have mentioned and pictured.
Bikes: 1964(?) Frejus Tour de France, 1967(?) Dawes Double Blue, 1979 Trek 710, 1982 Claud Butler Dalesman, 1983 Schwinn Paramount Elite, 2014 Brompton, maybe a couple more
Quoted: 319 Post(s)
Liked 692 Times
I am not an engineer, but I wonder if that little bit of space in the middle of the flat would make it less likely to seize?
As oneclick said, the middle of the flat shouldn't be bearing any load.
