Verified case of sealant working with tubes
Quoted: 2407 Post(s)
Liked 2,999 Times
I have been using sealant in tubes for a while.
The results have been mixed, I have had cases where I am pretty sure sealant has worked but have also had cases where sealant just sprayed out and made a mess (28mm Vittoria corsa tires with conti race lite tubes at 115Psi)
Yester day I got slow flat (32 mm Rene Herse compass Stampede pass with extra lite casing, schwalbe tubes, 30 ml of Caffee latex, 80 psi)
I got off and was about to pull the wheel and put in spare tire, I noticed sealant coming from the sidewall and spun the wheel and found sealant coming out from 2 punctures.
I decided to experiment and got out the mini pump. I pumped the tire up a bit (50 to 60 psi at a guess) and looked at the punctures...where sealant was coming out, wiped sealant away and kept watching
Sealant coming out kept at lower rate......(shoulda taken pics) so I kept watching and wiping in about 10 minutes no more sealant, so I pumped it up to maybe 65 or 70 and made it the 2 remaining miles home
Pumped it up to 90 or and so far seems to be holding
My takeaways
1) sealant works better at lower pressure so use lower pressure and time to let it do it's thing
2) pretty sure is has helped with smaller puncture I did not see
3) flip a coin between putting sealant in a a prophylactic or carrying sealant to use to try to do a fix
4) don't blast away with a co2 cartridge
5) Patience grasshopper
6) may got back to conti tubes as I have had more flats that expected with the schwalbe
My takeaways
Life is too short not to ride the best bike you have, as much as you can.
Ride, Wrench, Swap, Race
Quoted: 1574 Post(s)
Liked 1,317 Times
Were the Conti tubes perhaps a little wider in the uninflated state?
Tubes stretch to fill a mounted tire, quite a bit actually.
But a stretched tube wall will produce a bigger hole after being punctured with the same thorn than a less-stretched tube.
As you suggested, sealants work best at lower pressures and smaller holes.
I've wondered myself how CO2 affects the sealing ability of latex versus air(?).
Bikes: Yes
Quoted: 3300 Post(s)
Liked 4,084 Times
I'd be curious about this too. I got some Schwalbe tubes recently that are labeled as being suitable for up to and including 700x28s. I'm using them like that and haven't flatted yet (ask again tomorrow), but these tubes are really small. I think the Conti tubes that say 700x25 max are bigger.
My Bikes
My Bikes
Quoted: 36 Post(s)
Liked 38 Times
I've set a few people up with sealant and have received positive feedback. Most recently, in a fit of experimentation ( or laziness), I repaired a personal slow leak with an ounce of sealant.
Bikes: A bunch of old bikes.
Quoted: 296 Post(s)
Liked 918 Times
squirtdad How long had the sealant been in the tube? I've heard that it doesn't last that long somewhere, and wonder when you put it in.
Liked 2,999 Times
caffelatex shows this for lifespan of a up to a year in a tube or tubularUsing the recommended quantity for tyre size/type, the expected Caffélatex lifespan is:
- Tubular (or Caffélatex inserted into latex/butyl inner tube): up to 1 year
- UST Tubeless tyre: 2-6 months
- Tubeless-ready tyre: 1-4 months
- Tube-type tyre: 1-3 months
https://www.effettomariposa.eu/en-us...e-tyre-sealant
Likes For squirtdad:
Liked 2,999 Times
