32-33" inseam guys
32-33" inseam guys
Guys with a 32-33" inseam what road bike size frame do you y'all ride. I measured my inseam height with a marker against the wall. To get my inseam number. The pants I'm wearing right now are a comfortable fitting 34waist and 30 length. I have other pants longer than 30 but none lower and I have some 33 and 32" waist pants but none 35. I'm 6' 185lb. Leg and torso proportionate athletic build.
Quoted: 6351 Post(s)
Liked 4,952 Times
Mine is 34.5" I'm 5' 11". I currently am on a 56 cm Tarmac. I like a somewhat aggressive position it gives with a fair amount of drop from the saddle to the bars/hoods. I tried the 58cm model, but I felt it was not as sporty handling as I wanted and since frame stack increases with size I would be limiting how low I could go with the bars for me. Frame reach also increases with increasing size. Though that's only in general, you might find some exceptions. Older vintage bikes might scale the reach differently with size than newer bikes. But there is no one pat answer. You have to consider each model individually for size.
For my 2020 Tarmac, Specialized recommended either a 56 or a 58 cm frame. There are some models of bike I would be suggested a different size because of the differences in the geometry between the two models. So don't just blindly look for one particular size bike. You'll be frustrated when you get to the bikes that are letter sizes. <grin>
I use to ride a 59cm Raleigh Competition GS and a 60cm Schwinn Paramount. Before that a 25" (about 64cm) Schwinn Varsity. All comfortably.
Likes For Iride01:
I just picked up this 25" 86 bianchi sport sx 700c. I feel like it's a clear indication of how tall of a bike I can stand over. It feels like one more cm and it's going to be in contact with my pelvic bone. The 23" 83 nishiki international feels nice. Standing over it but that with 27" wheels.
The bianchi doesn't feel weird when I ride it. It's just up in me when in standing. That's not the end of the world for me but is it for some people ?
Liked 4,952 Times
I seldom want to straddle my bike and stand with both feet on the ground. Typically when I stop, I keep one foot on the pedal so I'm ready to go when it's time to go. So leaning the bike toward the side that has the foot on the ground quicky makes that top tube lower. Leaning the bike lowers the saddle too. So many times when I'm stopped, I'm still in the saddle with one foot down and the other ready to go.
Likes For Iride01:
Habitual User
Quoted: 5091 Post(s)
Liked 8,403 Times
I'm 5'-9", 180lbs.(ish), with a pants inseam of 32". I generally ride a 53-54 / Medium frame.
Likes For Eric F:
5'10". Riding a 55 cm bike. 32" inseam. Just as important might be the geometry of the bike you decide on. Do you want a bit more upright endurance style for example.
Likes For Acadianbob:
Quoted: 531 Post(s)
Liked 476 Times
Likes For oldbobcat:
Veteran, Pacifist
Quoted: 3940 Post(s)
Liked 4,937 Times
I'm close to your height. If you can stand over the 25" (63.5cm) frame barefooted with a cm to spare, then your inseam is most likely longer than what you state in post #1, by at least a couple of cm. My guess is a 24" (61cm) should be a good French fit, probably a 23" (58.5cm) the best competitive fit. But there are so many other variables to make the frameset a good fit.
At 6'1" with a 34" cycling inseam (pubic bone height) my range of vintage frame sizes is 58 -63cm. But 59-61 cm = the sweet spot for fit and with normal stem lengths, classic drop bars, etc.
Likes For Wildwood:
Bikes: Dawes Double Blue, Vision R-42 SWB, Bacchetta Giro, Lemond Maillot Jaune, Lemond Washoe, Holdsworth Special, Gitane Champion du Monde, Bob Jackson World Tour, Bianchi Professional, Nashbar C/Tour
I'm just a hair over 6' with a 33" inseam. Longish arms. My first "adult" bike (fitted by the bike shop) was a 25" Raleigh. Back then, the only measurement that mattered was the rider's ability to straddle the top tube. If you could do that with a little room to spare, the bike fit.
After I crashed the Raleigh, I bought a 58cm Dawes. I've ridden 58cm ever since. The owner of my LBS thinks that I should ride a 56cm, but he's never actually measured me.
Bikes: 2017 Raleigh RetroGlide iE
Quoted: 60 Post(s)
Liked 24 Times
I have no idea how the frameset is measured, but I am 5'11", with an inseam of 33".
Measuring from the bottom tube to the top of the seat of my Raleigh measures 26" at its current adjustment height, allowing the balls of my bare feet to touch the ground when seated..
Quoted: 531 Post(s)
Liked 476 Times
