View Poll Results: Do you change tire pressure during a multi-surface ride?
No, pump tires up before ride and forget it.
18
58.06%
Maybe release some pressure once, then forget it.
5
16.13%
Add pressure after a gravel section once.
1
3.23%
Adjust pressure up and down as necessary.
1
3.23%
Only touch the stem and pump when fixing a flat!
6
19.35%
Voters: 31. You may not vote on this poll
Adjust tire pressure during ride?
Quoted: 2629 Post(s)
Liked 1,979 Times
Another thread on tire pressure got me thinking. I've read several articles by authors who will release tire pressure when they come to a gravel section, and pump the tires back up when they get back to pavement. So what's your plan on mixed-surface rides?
Quoted: 3306 Post(s)
Liked 2,146 Times
Keep riding. It’s a rubber tire, it and I can adapt to the trail/road surface.
Likes For Steve B.:
Habitual User
Quoted: 5047 Post(s)
Liked 8,307 Times
Really?? Riding with someone who did that would get irritating really quickly.
Likes For Eric F:
Bikes: Indeed!
Quoted: 1517 Post(s)
Liked 3,504 Times
I increased pressure once on a ride that began with 35 miles of gravel followed by 40 miles of pavement, but otherwise I don't bother.
Brent
Brent
"I have a tendency to meander sometimes." B.G.
I've thought about it. From my house I have 10 miles of road riding to get to gravel. Even then the gravel is interrupted by paved trail sections.
So i am always looking for that compromise set up. I have let air out once when i reach the grav. But stopping to pump back up is a real effort - my hand pump is not fun to use past 30 psi!- so have not done that yet.
I tend to find myself on the gravel with tires that are a bit too skinny and higher pressure (because I dont like feeling slow on pavement).
Quoted: 48 Post(s)
Liked 32 Times
Depends on the bike & trails. 99% of the time I’m on 28mm’s and don’t change anything.
If I’m out with the 60mm tires, it’s usually an all-day ride or all-week camping & shredding and I crank them up for >45mins of road and drop them when the trails get hairy for what looks like is going to be more than an hour.
Sunshine
Quoted: 11048 Post(s)
Liked 7,596 Times
I do not adjust my tire pressure mid ride. And I would not ride with people who adjust their tire pressure mid ride.
I don't own a frame pump that I trust to consistently read psi to the small amounts that I would want to adjust.
I mean...how much faster will I be on pavement with 5psi more in the tires?
.ost of my solo rides are 40-60% gravel. And I flip between paved and unpaved probably 5 times.
Genuinely can't imagine adjusting pressure once, much less over and over.
Quoted: 4855 Post(s)
Liked 3,994 Times
I've done rides where it is 25-35 miles to the gravel. I leave the house at ~70 psi, drop to whatever is right for the condition, then pump back up for the ride home. Doing 50-70 miles on 30 psi or less is work I just don't want to do. Not when I can ride in style for the expense of 5 minutes of pumping. (Granted, I might change my ways if I had to use a minipump.)
Method to My Madness
Quoted: 2041 Post(s)
Liked 1,535 Times
Likes For SoSmellyAir:
Quoted: 7087 Post(s)
Liked 11,206 Times
I've only seen this once, towards the end of a long hill climb competition. It was a points ride -- first one up each hill got the most points, etc. We got to a hill that started out paved and then sort of fizzled out into dirt and grass and rubble...At the bottom, a couple guys reached down and pushed in their Presta valves to let out a bit of air. Nothing precise about it.
Quoted: 451 Post(s)
Liked 1,068 Times
I just use the Silca tire pressure calculator to determine best tire pressure prior to a ride. Having to mess around with my tires mid-ride is annoying.
I carry both my road bike and gravel bike with me and change according to the terrain. No need to change tire pressure as each one is calibrated properly.
Liked 1,535 Times
Habitual User
Liked 8,307 Times
Liked 1,979 Times
Hard to tell sometimes. There were a few threads a couple years ago on how to ride one bike and steer another (useful to get the second bike home from a shop). And there was a spoof ad a few decades ago about the Ford Gargantua, which had a spare Explorer on the roof in case you had a flat tire.
Liked 1,535 Times
I know.
I would rather get a ride to the shop. When my son was in elementary school, there was another dad who (1) rode with his child to school, and (2) rode home one handed while holding on the child's bike with his other hand. Looks kind of iffy, especially given that the school was on a fairly busy street with additional traffic from all the parents dropping off their kids.
Quoted: 1465 Post(s)
Liked 1,491 Times
I’m ride with a group that has a few who like to “air down” when we get to the gravel.
Our paved road ride to that point is maybe 6-7 miles and we don’t really go that fast. They also never air back up on the way home, which usually has longer stretches of paved riding due to the route we take. Also no one ever has a gauge - it’s just “psssst pssst psssst” at the last stoplight before the dirt and then we’re off.
I always worry that I’ll let too much out and then smash a wheel on a rock/root.
Liked 3,994 Times
After 50+ years with Zephal HPs and HPXs, no way am I going back to the dark ages of pumps that only sorta work or one-use throwaways. (Now, trying to get one of those pumps on a modern CF bike is a challenge I haven't tried yet. I'd probably settle for the left seatstay though I really don't like it.)
Pedalin' Erry Day
Like others have said, when I have more than a little bit of pavement to ride to the start of the dirt I'll start with my pressure a bit high at the start of the ride and then let some air out when getting to the rougher surface. I don't bother adding more when getting back on pavement, but there's no 'cost' to having slightly faster rolling in that initial segment since letting some pressure out takes mere seconds.
