Hunting for an old Dura ace FH-7700 right side rear Cone
While checking out some Dura ace FH-7700 hubs I picked up recently, I have found I need to replace two of the right (drive) side cones (3A0 9803). I've searched but have yet to find any available. Just thought I would see if any of y'all might know a source. Fingers crossed, thanks!
Best hubs ever. I own a few sets, as well as the similar XTR units. The 7700 axle has the standard 10 x 1mm threading. These hubs take 9 x 1/4" balls - so this is all standard stuff. If you find any cone with roughly the same specs, including height, then it should work. The cone height doesn't have to be exactly the same, as you may be able to rig some spacers to approximate the original fit. Dust cap: ditto - don't be shy and play around to make it work.
Find yourself a bike Co-op and root around in their used hubs and cones bin. We have many pounds of this stuff.
Likes For Dave Mayer:
Quoted: 4231 Post(s)
Liked 3,940 Times
I have a stash of older Shimano cones, I'll take a look but some have no part numbers so a photo would help. Andy
AndrewRStewart
AndrewRStewart
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1300 Post(s)
Liked 742 Times
there's always a chance that a cone will be bad in the used hubs, but Ebay will help you get a refund, depending on the sale agreement in the ad... i've returned one rear hub out of ten or so bought.... it arrived loose and heavily greased...
all my CL purchases are in person, local.
i've taken one XTR hub open and inspected it in front of the seller... then handed it back to him... it was also "set loose and heavily greased"... i consider that a sign of trouble..the drive side cone was badly pitted... i didn't bother wiping off the second cone..
i once bought a rear wheel/hub for less than half of his asking price, that i opened up and showed the bad parts to the seller... i then helped him rebuild another wheel while i was there... i just wanted the RIM from the first wheel mentioned, And teaching someone HOW to properly rebuild a hub is worth the trip anyway! The hub i swapped out of the rim i wanted was later rebuilt too... he had moved washers around, put in a spacer from some wally world hub, and used the wrong type of seals and jam nuts to try and re-align the wheel to a Bent Swing Arm on his frame...
older generation NOS XTR and DA parts are SPENDY.
the first time i bought a used hub strictly for salvage parts was for DA 7400 series hubs...
Likes For maddog34:
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 882 Post(s)
Liked 1,232 Times
Quoted: 1954 Post(s)
Liked 2,199 Times
As already mentioned buying a complete hub ensures that everything will match. The obvious donor is an WH-7700/7701 since they use the same FH body.
But there are a few pieces to this. If you look to mix and match you want the cone to be similar, (I'm not an authority on grind differences), and the dust seal to work. The FH-7700 seal is 214-0600. The FH-7700 DS cone dims are M10x13.2mm. The Ultegra FH-6500 uses the same 214-0600 seal and the DS cone dims are M10x13.5mm. Now finding an FH-6500 might be equally difficult.
You can get aftermarket cones from Wheels Mfg, but they don't offer one for you hub.
https://wheelsmfg.com/products/hub-p...=1711224210326
John
John
Liked 2,199 Times
John
Also, the rubber seal ring is different from prior Shimano FHs. These seal rings were different on each side (DS/NDS) and matches to the seal interface on the freehub body. The closest match for the 7700 would be the cones & seal on the other FH from the same era or slightly after. Possible candidates would be 6500, 6600, 5500, 5600 & 4400, and possibly a few others. You need to pull the tech doc and compare the part numbers for the seal ring.
Here is the tech doc for the FH-6500, that uses the same rubber seal ring. See #8 & 9.
Not sure if the more modern FHs that uses the one piece cone/seal ring/cover is the same size as the prior ones. Here is an example. See #5.
Likes For KCT1986:
Quoted: 858 Post(s)
Liked 1,092 Times
Shoot these folks and email. They have a collection of some odds and ends parts complete with a webpage from 1999. Great Place though. Yellow Jersey, Ltd., Arlington WI USA Everything Cycling Since 1 April, 1971!
Liked 3,940 Times
Chuck- I do have a number of various NOS Shimano rear cones in DA, Ultregra and MtB versions, including cones with the extended length past the ball track's small end. Here's the closest I can find to what is in the Ebay link sale (and is the RH cone still on the axle in that photo). IIRC the seal is located around a separate spacer between the cone and the lock nut (unlike most Shimano cones which have the seals assembled onto the cone's grooves).
Is this cone I have what will work for you? If it is and you PM me we can share info off public forum. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Hello Andrew, Here are some photos with and without
the O-ring:
the O-ring:
Quoted: 1617 Post(s)
Liked 2,225 Times
Such are the challenges with C&V stuff. I had the same issue with a 7200-rear hub. A BF'r sent me a rear hub with a split hub housing with good parts. Saved the day.
Liked 3,940 Times
I'll look again now knowing what to aim for. Andy
AndrewRStewart
AndrewRStewart
Liked 3,940 Times
I think I have the correct version w/ the seal too. Here's a shot. Andy
AndrewRStewart
AndrewRStewart
See post #8 for the EV of FH-6500, which is somewhat similar. Also, lists some road FHs that use the smaller seals, some with seals on a separate spacer. Some Shimano MTB FHs of the same era as the 7700 had the same seals.
