USB Cable Question
Old 03-27-24, 05:40 AM
Tandem Tom
Quoted: 457 Post(s)
Liked 112 Times in 85 Posts
USB Cable Question
I recently saw a cable that was USB to 2 "C" cords. So you could charge 2 devices with one cord. As we are getting ready for a cross country tour this might be a benefit.
Any downside to these?
Thanks!
Tandem Tom is offline
Old 03-27-24, 08:23 AM
njkayaker
Quoted: 4310 Post(s)
Liked 1,387 Times in 967 Posts
Thanks!
They will charge the devices slower. If you have two separate cables, you have a backup.
njkayaker is offline
Likes For njkayaker:
Old 03-28-24, 05:36 AM
Tandem Tom
Quoted: 457 Post(s)
Thanks. The reason I was considering this is our charger block sometimes has too many items waiting to be charged!
Old 03-28-24, 05:54 AM
oldwinger14
Bikes: 2022 Pinarello Paris Di2, 2016 Orbea Avant Ultegra mounted on a Wahoo Kickr Core
Quoted: 89 Post(s)
Liked 123 Times in 75 Posts
I use one of these. Works great and eliminates the need to carry the charging adapter(s) for each of your devices. You just need this hub and the USB cables.Many models are available, each with various #s of USB A and C ports. Here’s the one I use. They come in all types of configs and prices.
https://www.amazon.com/Anker-Charger...s%2C217&sr=8-1
oldwinger14 is offline
Old 03-29-24, 07:22 AM
Tourist in MSN
Quoted: 3505 Post(s)
Liked 1,490 Times in 1,163 Posts
I have not migrated to USB C yet, still using older tech. I prefer to have a charger that can supply everything, even if that means more cords.
But since the trip that supplied the above photo, I have become self sufficient on my dyno powered USB charger, have not had to plug into any outlets on my last tour. And the tour before that, was self sufficient for the last half of that tour once I realized that one of my cables had high resistance to I quit using that particular cable. That bad cable cut my wattage flow in half into my powerbank.
If you are using USB C for the higher wattage, you can still get chargers that have several ports on the charger.
If you are also carrying a power bank(s), if that powerbank also works in a pass through mode, you can charge that powerbank plus a device that is plugged into that powerbank at the same time to charge both.
If this is for your planned trip of many many weeks on a bike, get the right stuff before you start. On one bike tour a decade ago, I brought a 3 into on adapter for the outlet so that in one port on that outlet I could plug in three devices. That came in handy several times when several of us at the campground had to share one outlet.
My sister is going to Europe in a few weeks, a few days ago I gave her an EU plug outlet adapter that would allow her to plug her laptop, her phone and her apple watch battery charger all into one outlet for her trip.
Tourist in MSN is offline
Old 03-29-24, 07:29 AM
Tourist in MSN
One more thing, on some of the newer USB C chargers with multiple ports, some ports may have more power available than other ports.
For example, I recently bought a new laptop that uses USB C for charging. I bought a separate charger for travel, this one:
https://www.bestbuy.com/site/insignia...hite/6495573.p
That has two USB C ports, but only one of the ports is rated for enough power for my laptop. So, if you get a multi port charger, make sure you keep track of which ports provide adequate power for your needs. I labeled my two ports on this charger for wattage per port.
