Vintage Carbon Fork?
Velophile
Bikes: See Signature.
Quoted: 11 Post(s)
Liked 17 Times
Are we calling late 90s vintage yet?
I’m picking up a ‘98 Titanium Davidson tomorrow with what I assume is a 1in threadless Time equip pro fork. If the frame and carbon fork are immaculate would you ride it without worries or should I anticipate picking up a 1in threadless carbon Ritchey ?
2009 Specialized Roubaix, 2013 Specialized Rockhopper 29er, 1996 Guerciotti PRX, 2016 Jamis Renegade Expat !
Quoted: 2341 Post(s)
Liked 5,198 Times
I'm regularly riding 5 forks on bikes that old or older. I don't worry about them.
Steel is real...and comfy.
I would give it the usual "new to me" inspection for obvious cracks, corrosion, etc and ride it if it looks good. I regularly ride 90s carbon forks with no problems. Actually, one I bought had a crack near the fork shoulder but I hadn't noticed it until after I bought it. I actually put about 100 miles on it before I noticed, and I still have all my teeth. I took it out of service but hope to repair it and use it again.
Quoted: 4554 Post(s)
Liked 1,697 Times
Carbon repair is mostly about fixing impact damage to frames, not structural failure from normal use or structural forces exceeding the design. There is too much going on in the crown to presume that a repair is going to be strong enough to both replace the damage AND make up for whatever flaw allowed it to crack in the first place.
Used forks are cheap. Please throw that one away.
Likes For Kontact:
Quoted: 3464 Post(s)
Liked 2,834 Times
Consider the steerer material. Many early carbon forks used an aluminum steerer.
I have this beautiful Look carbon fork, aluminum steerer. Elegant art and I knew the original owner. His steel fork was misaligned from new. I corrected that, exchanged the forks, later sold the frame set on.
Bad example
Quoted: 867 Post(s)
Liked 344 Times
Liked 1,697 Times
Most old carbon forks had steel steerers. Aluminum only started being used for threadless - and most of those were still steel rather than alloy.
