Front Derailleur H Screw Question
Got the bike working fine. There was a slight rub with the front on the big cog, regardless of rear gear. Seemed to fix it with three turns of the barrel adjuster. Turned clockwise while sitting on the bike. Glad I didn't follow the park tool video and start screwing with the front Derailleur mount! However, the H Screw for the front is backed out almost all the way. One more turn out and it's coming out. Is this a problem? The enemy of good is perfect so I hate messing with it, but I'm a little concerned when I have it adjusted that way. If I screw it in it won't shift to the large cog. Repositioning the cage wouldn't help. To my eyes it looks like the cage is straight and the proper height. Does anyone else have the H Screw out that far?
Quoted: 6345 Post(s)
Liked 4,946 Times
What model FD do you have? And which side of the FD's skid plate is rubbing on the chain? Is this a group set that has trim positions? I don't know when trim was added, but 10 speed and greater rears have trim on the front that is handled mostly by the STI, but FD incorrectly set up will affect it's effectiveness.
I know you've ask about this before. But I'm not going to look back to get that information if it was given previously in another thread.
Likes For Iride01:
Quoted: 5942 Post(s)
Liked 2,844 Times
Why is the limit backed out so far?
Odds are that it's not doing anything at this point, and tightening it won't make a difference.
Keep in mind that limits don't affect cage position or shifting, which is about the cable. Limit screws do ONLY what the name implies ---- limit the range of travel in that direction.
Adjust the limit by shifting by pulling the bare wire from the down tube. Set the limit so you can shift to the outer ring crisply, but cannot overshift and dump the chain.
Once the limit is set, Adjust the cable for food shift response using the lever.
Likes For FBinNY:
As for adjusting, it should be 'out' just far enough to allow the chain to clear the outer cage when in the large chainring and outermost sprocket in back. The cable tension determines where this is. The H screw stops the cage from moving much further, which can cause the chain to fall over the outerring.
With modern index shifting for the front, the shifter 'clicks' into the proper position & pulls the proper amount of cable. The limit screw should be 'in' enough to limit movement at this point, or very slightly beyond. The cable tension should not be so tight that the cable is being 'stretched' by the shifter against the derailleur hitting the H screw. The shifter needs to have a little leeway in the front derailleur movement or a little more available stretch in the cable to release the mechanism.
So, in your case, the H screw may need to be set quite far out to work properly. If it needs to be quite loose to allow the FD to shift onto the outer ring 'so be it'.
Quoted: 568 Post(s)
Liked 425 Times
The FD cable should be redone, but more importantly, the FD itself must be correct on the seattube and miss the outermost L chainring by 1-3mm as spec'd by Shimano.
Once the cable is good, the H screw won't matter at all, because the FD cable will start tensioning the lever.
Quoted: 4585 Post(s)
Liked 1,739 Times
Likes For Kontact:
Bikes: Cannondale tandems: '92 Road, '97 Mtn. Mongoose 10.9 Ti, Kelly Deluxe, Tommaso Chorus, Cdale MT2000, Schwinn Deluxe Cruiser, Torker Unicycle, among others.
Quoted: 279 Post(s)
Liked 207 Times
Today, a front derailleur discussion is lacking if it doesn't include instructions for Shimano's newer front derailleurs. Without this, I was lost. Couldn't believe my eyes when my tried-and-true front derailleur techniques, honed over a few decades, fell completely flat!
Enjoy.
Modern Shimano Front Derailleur Adjustment Guide
Introduction
Shimano completely re-designed it’s front derailleur with the release of the Dura-Ace R9100 mechanical group set. This new modern front derailleur features a ‘toggle’ mechanism that is completely different to the ‘pivot’ design of the past. This new design has some different adjustment requirements which I will discuss later.
This new derailleur design has since filtered down to other Shimano group sets includes Ultegra (R8000), 105 (R7000) and GRX. Shimano explains the advantages of this new derailleur design to be;
Shimano’s new front derailleur design operates differently to it’s previous ‘pivot’ style derailleurs. The 2 major differences being;
Front Derailleur Adjustment Problems
At this stage you will probably find yourself in one of 3 scenarios;
The good news is that once the derailleur is installed correctly and the high/low limit bolts set, then cable replacement and tension adjustment should be the only ongoing minimal maintenance.
Are You Trimming the Front Derailleur When Riding?
Riding in certain gear combinations can be noisy if you are NOT trimming the front derailleur when you change sprockets at the rear. If you are unfamiliar with trimming the front derailleur, make sure this is not the issue before altering the setup of the front derailleur.
The front derailleur can be shifted to 4 different positions as illustrated in the following chart below. I will be referring to the names of these positions in the article later when we are setting up the derailleur.
This is a good time to test if your derailleur is shifting to these 4 different positions. Fit your bike into a workshop stand to make this process easier as you will need to rotate the cranks when shifting the front derailleur.
Riding with a crossed chain means you are riding in one of these 2 gear combinations;
Position #1: Largest Chain Ring and Largest Rear Sprocket.
Position #2: Smallest Chain Ring and Smallest Rear Sprocket.
Riding in either of these 2 extreme gear combinations is not recommended (and not really necessary). It is a recipe for a noisy drive train and will increase wear on your components. If you experience noise riding in either of these crossed chain gear combinations, it will either be caused by the chain running at an acute angle to the teeth of the gears and / or the chain scraping against the inside of the front derailleur cage.
If you are ONLY hearing the chain scraping inside the front derailleur cage whilst riding in either of these crossed chain combinations, then the front derailleur adjustment is probably setup OK (or very close). The noise can be eliminated by riding in other non-crossed gear combinations.
Disc Frame Notes: If your bike is fitted with disc brakes, you may experience chain rub when your chain is on the smallest chain ring and second smallest sprocket. This is because road bikes fitted with disc brakes (135 mm quick release or 142 mm thru-axle) both have the same wider rear hub spacing of 135 mm versus a traditional road bike with rim brakes narrower 130 mm rear hub spacing. This extra 5 mm width results in the cassette being located 2.5 mm further out from the center line of the frame, but Shimano have NOT moved the chain rings to compensate for this difference. So there is an increased chain angle from small chain ring to the smallest sprockets. If you adjust the front derailleur to eliminate chain rub in crossed chain position #2, you will likely experience more chain rub in cross chain position #1.
Tools Required
The following tools are required to adjust the front derailleur.
Before deciding if this is a process you want to try, I recommend reading through the entire article before commencing any work. This article is an overview of how I adjust my own front derailleur and should not be treated as professional advice. Please read my disclaimer at the end of this article.
It’s a good idea to clean the chain, cassette, chain rings and derailleurs before commencing the adjustment procedure. Once dry, re-lubricate the chain and apply a light lubricant to the pivot points of the derailleur. I use Tri Flow as it has a small straw attachment that allows you to get into these locations. When everything is clean and lubricated, you’re ready to start.
Here are the steps for adjusting a modern Shimano front derailleur.
1. Check the Front Derailleur Clearance Above Large Chain Ring
Problem: If your gap is not within the prescribed parameters of between 1 mm and 3mm, then this will need to be adjusted to ensure the best performance from the derailleur. If you need to align it correctly, I recommend reading my installation guide for a Shimano front derailleur.
2. Check Front Derailleur Alignment with Large Chain Ring
Next we will check the angle of the front derailleur in relation to the large chain ring.
3. Check the Front Derailleur Support Bolt & Frame Protection Plate
The front derailleur frame support bolt is an important step that can be EASILY overlooked as the support bolt is hidden away from view. Setting this bolt correctly improves shift performance as this bolt provides a secondary contact point to counter the shifting forces.
Find the location of the support bolt in the center of the derailleur body.
backing tape to stick to the frame prior to the derailleur support bolt pressing it into position.
You will know when the support bolt is in proper contact with the plate as tightening the bolt more will change the angle of the derailleur cage. Once the support bolt is in contact with the frame plate, check the rear end of derailleur cage is still aligned parallel to the large chain ring. Tightening the support bolt further will move the rear end of the derailleur cage out away from the frame.
4. Check the Shift Cable is Correctly Installed
Make sure the shift cable is routed correctly to ensure it is not interfering with the movement of the toggle mechanism on the top of the derailleur.
5. Preliminary Cable Tension Setting
Now we need to check the tension of the shift cable is sufficient. Make sure to always use a torque wrench when tightening the shift cable clamp bolt as the thread can be easily stripped if you over tighten this bolt. Shimano recommend a torque setting of 6 to 7 Nm.
Turn the cranks whilst moving the left brake lever all the way to the right to move the derailleur to the HIGH position. If the derailleur doesn’t move to the chain onto the large chain ring, the 2 most likely reasons are;
How to test: The chain should already be on the small chain ring. Press the inner (smaller) left shift lever multiple times until it no longer clicks as to release the derailleur cable tension. Now using your fingers, see if you can manually lift the upper ‘toggle’ section of the derailleur up from the main body. It should NOT move. If it can be lifted with your fingers, then the High Limit bolt is not set correctly. I recommend you refer to my installation guide for a Shimano front derailleur on how to reset the high limit bolt.
Front derailleur upper toggle resting on main body. You should not be able to lift it up with your fingers. The shift cable will pull the toggle up when we press the left brake lever to shift to the large chain ring.
If the front derailleur upper toggle has any upward movement using your fingers, then we need to adjust the high limit bolt. Once set correctly, the shift cable will achieve maximum pull.
Once you are able to shift the chain onto the large chain ring, then continue with step 6.
6. Fine Tune Cable Tension Setting
On previous designs of Shimano front derailleurs, there was no way to accurately judge the correct amount of cable tension. However, this new derailleur design features 2 markings that allow you to fairly accurately set the cable tension and therefore eliminate most of the guess work. Whilst the tension adjustment marks may be in visual alignment, the cable tension can be varied by small amounts whilst the 2 indicators remain aligned as discussed further in the Troubleshooting section later in this guide. This is how to set the cable tension;
When they make a single straight line,
the cable tension is perfect.
Once the alignment is correct, turn the cranks and use the shift levers to move the derailleur through a full range of movement a few times whilst changing gears. Now return to the HIGH TRIM position to check the alignment is still perfect. If not, make a small adjustment otherwise this step is complete.
An inline barrel adjuster should NOT be required to fine tune cable tension. Try to use the cable tension bolt only. If the bolt is not able to adjust tension adequately, then the shift cable is either too loose or too tight. Loosen the cable clamp bolt and adjust the cable in or out to fix the problem. Attempt this step again.
7. Adjust Front Derailleur High Limit Bolt
The HIGH LIMIT bolt is designed to control the outward movement of the front derailleur, but this bolt works differently on the modern Shimano ‘toggle’ style front derailleurs when compared to the traditional ‘pivot’ style front derailleurs of the past. The difference being;
Traditional Pivot Style Front Derailleur: the high limit bolt simply RESTRICTS how far out the front derailleur can travel. In essence the high limit setting resists any over-tension of the shift cable when shifting onto the large chain ring. You would adjust this bolt so the front derailleur does not rub the inside of the crank arm and the chain does not rub inside the derailleur cage when riding on the large chain ring and smallest sprocket. This setting would only affect the front derailleur in the HIGH shift position.
New Toggle Style Front Derailleur: the high limit bolt still determines how far out the front derailleur can travel, but it it achieves this in a completely different way. The high limit bolt works in conjunction with the shift cable tension, not against it. The high limit bolt determines where the derailleur is positioned relative to the tension of the shift cable. For this reason, the high limit setting also changes the location of the front derailleur in both the LOW and HIGH TRIM shift positions as well. Therefore, keep in mind that when adjusting the high limit bolt, any adjustment can impact chain clearance in other gear combinations.
Shimano instructions recommend to adjust the High Limit bolt to stop the chain rubbing the front inside face of the front derailleur cage (closest to the frame). However, as mentioned above, the high limit setting can affect derailleur clearance in other gear combinations, you may need to find-tune this setting later on to achieve the best overall outcome.
The high limit setting is done in a crossed-chain position, with the chain on the large chain ring and largest sprocket. Whilst it is not recommended to ride in this gear combination, Shimano recommend you adjust the high limit setting in this gear combination.
Move the left brake lever all the way to the right whilst turning the cranks. When the lever will travel no further, we are in the HIGH position. The chain should be on the large chain ring.
The final adjustment is the Low Limit bolt. This adjustment is designed to set the lowest position the front derailleur can shift down to. This setting is designed to eliminate any chain rub on the inside face of the front derailleur when the bike is in it’s lowest gear ratio. BUT, if the low limit bolt is screwed in too far, you may effectively negate the LOW TRIM position of the front derailleur. If this happens, shifting from LOW to LOW TRIM or visa versa will result in no visible movement of the front derailleur as the low limit bolt is stopping the front derailleur shifting down to the LOW TRIM position.
Important: Press the small inner shift lever whilst rotating the cranks. When the shift lever no longer clicks, we are now in the LOW TRIM position.
Now all the hard work has been done and you are familiar with how to set these adjustment bolts, we need to do a final test, shifting through all possible gear combinations. At this stage, you can fine tune the HIGH and LOW limit bolts further if there is still some chain rub. I also recommend doing a test ride on a quiet road to double check for chain rub in all gear combinations under load whilst riding.
10. Troubleshooting
Problem: Having followed all the steps in this guide, you are still experiencing some chain rub in the front derailleur cage using these gear combinations;
(i) Front derailleur in HIGH TRIM position, Chain on large chain ring and second largest sprocket (almost cross-chain). Chain rubs inside face of front derailleur cage.
(ii) Front derailleur in HIGH position. Chain on large chain ring and smallest sprocket (highest gear). Chain rubs outer face of front derailleur cage.
Solution: This is most likely due to shift cable tension being either a little too loose or too tight. Whilst the tension adjustment marks may be in visual alignment, the cable tension can be varied by small amounts whilst the 2 indicators remain aligned. By making small adjustments to the cable tension bolt and the high limit bolt independently, you should be able to find a setting that provides front derailleur clearance for scenarios (i & ii) mentioned above which are generally the problem areas.
Don’t forget when testing!
1. Riding in crossed chain positions may result in some drive train noise.
2. Trim the front derailleur (when required) when testing gear combinations. Double check the trim position is correct before making any further adjustment.
Finally, the chain stay length of some disc brake road frames is shorter than Shimano’s specified minimum length of 410 mm. Bike manufacturer’s do this to give the bike more snappy handling, but shorter chain stays can affect the chain line to a small degree which may result in noise as the chain moves toward a crossed gear combination.
11. Clearance Between Front Derailleur and Crank Arm
I was asked a question about how much clearance there should be between the front derailleur and the inside crank arm ie. when front derailleur is shifted to the HIGH position ie. chain on large chain ring, front derailleur shifted fully outward from the frame.
I measured this gap on my 105 (7000 series) group set to be approximately 3.5 mm. The gap to the crank arm was about the same for both the black upper body of the derailleur and the outside face of the metal chain cage.
Note: This gap may be slightly different on your bike, but you need to make sure that the front derailleur does NOT touch the crank arm when riding under load. If the front derailleur is too close or touching the crank arm, you may have allowed for too much clearance between the cage and chain when in the Large chain ring / Smallest rear cog gear combination. If so, first check the cable tension is correct (in High Trim position), then re-adjust the high limit bolt to move the front derailleur closer to the frame. Ultimately, you only want the MINIMUM distance required to achieve NO chain rub inside the front derailleur cage when riding in this highest gear combination.
Clearance between front derailleur and inside face of right crank arm is about 3.5 mm on my Shimano 105 (7000) setup. But it may be different on your bike.
Need to Install a Shimano Front Derailleur from Scratch?
Still having issues with your front derailleur or want to install one onto a new bike, check out my complete article on how to install a Shimano front derailleur. The article covers all aspects of the installation including;
References
I hope you found this article interesting. I have listed the following website pages as general references.
Shimano Dealer’s Manual for Front Derailleur Installation
Disclaimer!
Please remember that this information is only to be used as a guide.
I consider myself an enthusiast, not an expert. The information I have presented in this article is only a guide.
Whilst I enjoy working on my own bikes, I am not a qualified bicycle mechanic. The content of this article is purely illustrative and does not constitute professional advice. For your own safety, any type of work should only be undertaken by a qualified bicycle mechanic. Incorrect assembly of parts could result in equipment damage, personal injury or death.
About Me.
I have been riding and working on my own bikes for many years now. I wanted to share my experiences, knowledge and research with others. My aim is to inspire people to get involved in all aspects of this amazing sport. Cheers.
Comments.
I welcome reader feedback in the comments section. Should you wish to suggest an amendment, please include a note advising the source of your information so that myself and other readers can ascertain the accuracy of your information. Note: Trolling or argumentative comments will be removed as they are counter-productive.
36 thoughts on “Modern Shimano Front Derailleur Adjustment Guide”
Enjoy.
Introduction
- Reduced shift effort at the lever.
- More cable routing options (cable outer can now be terminated at the derailleur itself).
- Integrated cable tension adjustment (to eliminate the need for an inline barrel adjuster).
- Shorter minimum chainstay length of 410mm for disk brake equipped bikes (with 135mm OLD).
- Precise and easy front derailleur setup (once you know the steps).
- Inbuilt tension adjustment for the shift cable.
- Change in how the high limit bolt works.
- Shimano Dura-Ace – R9100 front derailleur (FD-R9100)
- Shimano Ultegra – R8000 front derailleur (FD-R8000)
- Shimano 105 – R7000 front derailleur (FD-R7000)
- Shimano GRX – front derailleur (FD-RX810, FD-RX400)
- The front derailleur is not shifting the chain from one chain ring to the other.
- The front derailleur is over-shifting the chain. It falls off either the large or small chain ring.
- The chain is scraping inside the front derailleur cage in certain gear combinations.
- The front derailleur is not setup correctly. This can even be the case with brand new bikes where the mechanic was not familiar with the different installation process required for this new design front derailleur.
- The cable tension is incorrect. Common for bikes with recently replaced or newly installed shift cables & housings. All bikes will require minor cable tension adjustments over time due to cable stretch or housing compression.
- The shift cable is not routed correctly or is kinked.
- The gear shifter is faulty. (Rare)
- Pressing the left brake lever all the way to right moves the front derailleur to the HIGH position which is the most outward position of the derailleur in relation to the frame. This setting is for riding the large chain ring and smaller rear sprockets.
- Pressing the small inner shift lever once, moves the front derailleur just slightly inward to the HIGH TRIM position. This position is for riding the large chain ring and the larger rear sprockets.
- Pressing the small inner shift lever again moves the front derailleur to the LOW position. This causes the chain to shift from the large chain ring to the small chain ring. This position is for riding the small chain chain ring and the smaller rear sprockets.
- Pressing the small inner shift one last time, moves the front derailleur just slightly inward to the LOW TRIM position. Now the derailleur is in it’s closest position to the frame. This position is for riding the small chain ring and the larger rear sprockets.
Tools Required
- 2mm Hexagon Wrench (Allen Key)
- 4mm Hexagon Wrench (Allen Key)
- 5mm Hexagon Wrench (Allen Key)
- Torque Wrench (with 4mm & 5mm Hexagon fittings).
Highly recommended to avoid stripping the thread on the nut that secures the cable to the derailleur.
- Using the left shift lever, rotate the cranks and change the chain down onto the small chain ring.
- Next we need to position the outside edge of the front derailleur cage directly above the teeth of the large chain ring. You can either use your fingers (pulling from behind the derailleur) or pull the shift lever to move the derailleur across. You will need to manually HOLD it in this position. Don’t shift the chain onto the large chain ring as you will not be able to see the gap.
- Whilst holding the derailleur in this position, check there is a 1 to 3 mm gap between the teeth of the large chain ring and base of the underneath OUTSIDE EDGE of the derailleur cage.
- The chain should still be on the small chain ring from the previous procedure.
- Looking at the OUTSIDE edge of the derailleur cage from above. Check it is PARALLEL to the front chain ring as shown in the diagram. We don’t want the rear end of the derailleur angled in or out.
- Take a look from behind the derailleur to see if this bolt is in contact with the frame. We don’t want the support bolt directly in contact with the surface of a carbon frame. Typically a small metal frame protection plate will be stuck to the frame where the support bolt makes contact with the frame. On some frames the support bolt may contact the braze-on derailleur mount instead.
- If you need a frame protection plate. Visit a local bike shop to see if they have a spare one. Fit the plate in the correct location where the support bolt will contact the frame. Tighten the bolt to make contact with the plate.
- The shift cable is slack. Loosen the shift cable clamp bolt and pull the shift cable tighter, then re-tighten the clamp bolt to correct torque. Try shifting to the large chain ring again.
- Move the left brake lever all the way to the right whilst turning the cranks. When the lever will travel no further, we are in the HIGH position.
- IMPORTANT: Press the small inner shift lever ONCE to move the derailleur down to the HIGH TRIM position.
- When in the HIGH TRIM position, look at the 2 markings on the rear of the derailleur as pictured. We want both these lines to line up and form a straight line. To achieve this, turn the cable tension bolt as required. Turning the cable tension bolt clockwise will move the upper line anticlockwise and visa-versa.
- Shift the chain is on the largest sprocket at the rear.
- The chain is now on the large chain ring and largest sprocket.
- Important: Press the small inner shift lever once to move the derailleur to the HIGH TRIM position.
- Now slowly turn the cranks and adjust the High Limit bolt until there is a 0 to 0.5mm gap between the inside front face of the derailleur cage and the chain. We want to achieve the smallest possible gap between this surface and the chain. If you create too much gap here, you could experience rubbing in other gear combinations, so start with a very conservative gap. It can be readjusted at any time by repeating this step.
- The chain should now be on the SMALL chain ring.
- Shift the chain to the LARGEST sprocket at the rear.
- The chain is now on the small chain ring and largest sprocket.
- Slowly turn the cranks and adjust the Low Limit bolt until there is a 0 to 0.5mm gap between the inside face of the derailleur cage and the chain. We want to achieve the smallest possible gap between this surface and the chain. Again, start with a very conservative gap. It can be readjusted at any time by repeating this step.
- Check if the front derailleur still moves when shifting from LOW TRIM to LOW positions.
Note: Depending on your bike, you may need to over-shift the lever a little past the ‘click’ to make the front derailleur move to the LOW position. This is due to a combination of acute cable angle, high spring tension and small cable pull.
10. Troubleshooting
- Resetting all the adjustment bolts on a previously used derailleur.
- Fitting and alignment of the derailleur.
- Connecting and tensioning the shift cable.
- Adjusting the frame bolt, high and low limit bolts.
- Fitting the plastic top cover.
References
Disclaimer!
About Me.
Comments.
- martin Webster says:
Expired Member
Quoted: 3784 Post(s)
Liked 5,774 Times
Enjoy.
Introduction
Tools Required
10. Troubleshooting
References
Disclaimer!
About Me.
Comments.
Enjoy.
Introduction
Tools Required
10. Troubleshooting
References
Disclaimer!
About Me.
Comments.
Quoted: 3631 Post(s)
Liked 3,052 Times
Likes For smd4:
