Campy Record ti 9 speed Ergo shifter
Quoted: 802 Post(s)
Liked 760 Times
I've never owned Campy, so before I take them apart potentially needlessly for service....are the downshifts for these older style brifters especially 'hard'? The upshifts are much easier to push.
I may be biased because 9 speed Ergos are my favorite type of brifter, but no the downshifts are not particularly "hard". I find them to precise and easy to shift, while being comfortable in the hand.
Check out www.djcatnap.com for articles on vintage Japanese & French bicycle restorations, components and history.
Quoted: 802 Post(s)
Liked 760 Times
Though, thinking more now, I guess that's to be expected because the thumb shifts will be aided by the cable tension...perhaps once setup on the bike this will make sense.
Ride, Wrench, Swap, Race
Quoted: 1568 Post(s)
Liked 1,308 Times
It's definitely precise, nothing mushy about it, just I'm surprised by how much more effort is required to push the thumb.
If there was a way to add lube with a needle-point applicator to the indexing ring and indexing springs I would put a squirt of motorcycle chain lube in, but only if this could be done without making a mess or with lube getting under the rubber hood which would be a disaster.
Bikes: many
Quoted: 1466 Post(s)
Liked 1,432 Times
Yes, the shifting force will be dramatically reduced!
Bikes: Yes
Quoted: 3284 Post(s)
Liked 4,039 Times
Yes, the Campy Ergo design attempts to balance the forces so that both upshifts and downshifts feel the same on the road. When they're not installed, it acts very weird, often skipping over gears in one direction, because the forces are out of balance without the derailleur pulling on the cable.
My Bikes
My Bikes
Bikes: Peugeot, Legnano, Fuji, Zunow, De Rosa, Miyata, Bianchi, Pinarello, Specialized, Bridgestone, Cinelli, Merckx
Quoted: 438 Post(s)
Liked 533 Times
Likes For billytwosheds:
