Do Insoles Wear Out?
I've got some Specialized BG Footbeds, the red version, that I purchased about three years ago. It's hard to tell if they have squished down much or the shape changed a bit. I have had some foot discomfort recently so I'm looking at the possible causes.
How long are these supposed to last? Years or forever?!
[insert clever quote here]
Quoted: 571 Post(s)
Liked 604 Times
Lots of them never make it to 12 months without loosing their cushioning and support if you run or wear them every day. I get better life from quality gel insoles and notice less foot pains with them.
Serious long distance backpacker Ray Jardine would have in prearranged "drift boxes' mailed ahead, spare insoles and shoes, he practiced ultralight backpacking loads and hiked in running shoes. He said the foam in both shoes and insoles gets permanently mashed down, takes a set.
My old '90s Eddy Merckx bike shoes I think were cork insoles (not removable), and that would last. But modern insoles provide more cushion.
Quoted: 4541 Post(s)
Liked 5,048 Times
Likes For wheelreason:
My oldest pair of Garneau road shoes have more than 30,000 km on them in 7 years. My newest pair are duplicate shoes and insoles and have less than 250 km. Other than the cosmetic lettering worn off the surface of the insoles, you would not be able to tell the difference, they both have the same compressibility in the foam. Both pairs are comfortable. I had a pair of Adidas cycling shoes with no insole and a cork footbed with no cushioning, they were very comfortable so maybe I don't need any cushioning besides the sock.
Thanks for the responses. From my eye, it seems like the insole material is still fairly solid but hard to tell. Based on what you all have posted, I'll skip replacing these for the moment.
Bikes: 2014 Trek Domane 5.2, 1985 Pinarello Treviso, 1990 Gardin Shred, 2006 Bianchi San Jose
Quoted: 62 Post(s)
Liked 29 Times
Yeah, these are Sidi shoes and the OEM insoles were a waste. That's why I moved to the Spec. insoles though the red version is fairly flat.
OM boy
Bikes: a bunch
Quoted: 545 Post(s)
Liked 686 Times
Repurposing my older surf wetsuits provides some longer lasting insoles, custom cut, each full suit provides many insoles and enough material for many other uses - like pads for the helmet chin straps - especially good for cold winter riding days...
Ride On
Yuri
Ride On
Yuri
Likes For cyclezen:
Clark W. Griswold
Quoted: 4446 Post(s)
Liked 4,105 Times
They do wear out. It is not a bad idea to replace if you feel they aren't giving you good support. They aren't super expensive you are buying them every few years or more especially if you are more comfortable.
Liked 3,079 Times
havent had luck with finding replacements that are as thick & as stiff as the originals... Even wouldnt mind a pair that were more ridged & thicker. Stacking insoles drives the weight up, especially when they get water logged. Kinda need insoles that have the open cell foam design to reduce weight.
-Oh Hey!
-Oh Hey!
Liked 5,048 Times
Are you talking specifically about the Specialized BG insoles here? I don’t see or feel any wear on mine and they don’t lose their support. I compared a heavily used 3 year old pair against a nearly new pair yesterday and there was no difference, apart from maybe the smell 😂
Clark W. Griswold
Liked 4,105 Times
My insoles generally start smelling bad from the first week I cannot win.
Liked 5,048 Times
No just insoles in general, if used you are compressing them overtime so they will not be as good as they are from day one. Certainly yes some will hold up better but I have yet to have an insole that doesn't wear out. Certainly a very stiff insole and a very lightweight person will take a lot more time but it will happen.
Likes For PeteHski:
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4426 Post(s)
Liked 3,055 Times
I can't imagine that anybody actually rides with Sidi OEM insoles - they aren't really meant for any serious use.
I have a pair of Sidis (rather old now) and also newer Shimano shoes. I swapped out the OEM Shimano insoles from the get go also - they aren't as flimsy as the Sidis, but still not right for my feet.
Liked 5,048 Times
I believe that Sidi EXPECTS you to replace their insoles with ones that are better customized for your feet. Therefore, their OEM insoles are as cheap as can be.
well hello there
Quoted: 503 Post(s)
Liked 337 Times
Darn. Another thing to worry about.
I just bought some custom inserts for my running shoes, which cost about $100.00, and it greatly improved comfort.
I think I'll slip them into my Sidis and check it out.
