Shimnano Brake pads question
Hi,
I have Shimano Titanium K03Ti Resin brake pads on my s-works roubaix. On one pad, there are two indented dots and it says TE and 24 in the two indentations. On the other pad it says TE and 30. I am assuming there is no difference between left and right side of the caliper - or are these numbers something I should know more about?
Thank you.
Thank you.
aged to perfection
Quoted: 866 Post(s)
Liked 1,308 Times
they are probably just manufacturing lot numbers.
not a detail worth worrying about.
there MAY be "left" and "right" pads on your brake, but at least the 8000 series pads that I have will fit either side of the caliper.
/markp
/markp
Clark W. Griswold
Quoted: 4514 Post(s)
Liked 4,204 Times
I don't think they are numbers to worry about at all. I have never bothered to look at the back. If the pads are both the same size and shape and actual holes you are fine and it doesn't matter. Next time I get some Shimano pads needing replace I will look at the backs more closely.
Really Old Senior Member
Often, when parts are mass produced a set of dies, punches, molds etc. will be in use at once.
When QC finds a bad part, they know which specific "tool" is at fault.
OR date codes, batch #'s, factory #, shift # or who knows?
Quoted: 5978 Post(s)
Liked 2,894 Times
As noted. Manufacturers assign lot numbers to everything. This allows tracing and identification of any defects and potential defects.
It's how recalls, as we so often see with food, can be limited to specific batches rather than 100% of the product.
FB
Chain-L site
FB
Chain-L site
Thank you all.
Sounds right to me as they look identical under my huge magnifying glass/light which is invaluable for me when working on bikes at my advanced age! Cheers all!
bill
bill
Likes For wddossett:
