Bike suggestions
Bike suggestions
Hi everyone. I’ve done tonnes of research and I’m still unsure what to buy. I have an old Giant mountain bike that is 25 years old and my over 50 body can’t take it anymore LOL
Looking for a bicycle with good suspension, upright seating and around $600 - $800 Canadian dollars which is around $450 to $700 US.
I ride mainly on pavement with occasional gravel and use my bike for modest exercise and riding with friends.
Any suggestions would be appreciated. Thank you.
Rhonda
Rhonda
Likes For spuzak30:
Quoted: 586 Post(s)
Liked 510 Times
Tell me why you need good suspension. You mention mostly pavement riding and some gravel. If it's a normal gravel road a car would easily travel, you shouldn't need any suspension other than from larger, higher volume tires. Suspension will add weight if you don't really need it.
Likes For RH Clark:
Clark W. Griswold
Quoted: 4451 Post(s)
Liked 4,114 Times
Rhonda
Rhonda
Commuter
Bikes: Main Bikes: 2023 Trek Domane AL3, 2022 Aventon Level.2 eBike, 1972 Schwinn Varsity, 2024 Priority Apollo 11
Quoted: 308 Post(s)
Liked 420 Times
What brands does your local bike shop support? (Giant is one, I presume)
I agree with RH Clark, that you don't necessarily need a suspension bike. Something with front suspension and then a suspension seat post would probably do for your use. ...or even without front suspension, since you're looking for something more upright. Less weight on your wrists means you won't feel impacts from the front wheel as much.
How about a Trek Verve? I think their entry level bike is a bit higher in budget than you're looking for, but very nice quality. It has largish tires, but smoother rolling than a mountain bike's. Includes the shock in the seat post too.
I am able to travel to a larger center and get a bike or I would consider ordering online. I can check out the Trek.
Quoted: 586 Post(s)
Liked 510 Times
What you need to do is find a good bike shop and try some different bikes to get a better idea of what you want and need. Even if you end up buying used you will need to know what size and style to look for. Spend some money at the shop if they help even if you don't buy a new bike there right now.
Likes For RH Clark:
Commuter
Quoted: 308 Post(s)
Liked 420 Times
Good point about the upright and less impact. I really just want a ride that allows me to not feel like I’ve been beaten the day following. Although my roads are paved they are not always smooth.
For example, the tires on my Trek Domane are marked "Inflate to 75 psi" (note that they omitted the word 'max' in this case, leading us to believe that was THE correct pressure no matter what!)
After learning a bit here and reading some online advice, I found that 65 rear, 60 front was a lot more comfortable and no slower!
Likes For Smaug1:
