What's Out There for Me in Pedal Assist Bikes These Days?
Bikes: Cannondale Carbon Synapse Road, Cannondale T2000 Touring, Vintage Mongoose IBOC Pro MTB, Vintage Peugeot 12spd racer, Old rusty Schwinn Manta Ray I neglected as a child, Diamondback Haanjo EXP Carbon & Metro, Specialized Roubaix Pro, RaleighSC Tandem
Quoted: 232 Post(s)
Liked 42 Times
Seeking a lightweight carbon-fiber road bike with FLAT bars because I can no longer ride drop bars for long hours.
I also want to be able to get on dirt trails & gravel with confidence and I require rear rack mounts.
I will only be using the motor for climbing,
Thanks for your help!
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Quoted: 144 Post(s)
Liked 317 Times
Happy hunting!
Clark W. Griswold
Quoted: 4470 Post(s)
Liked 4,133 Times
We used to do flat bar conversions on Specialized Creo's. For boss man we used a collar for rack mounting. I would recommend the Vado SL honestly it is already flat bar and comes with the EQ kit with rack and fenders or you can have someone drill and RivNut the frame (someone who knows what they are doing because it will technically void the warranty) and you can mount a standard rack. I have one and it is a fantastic bike and while not super light is plenty light and really a great ride and if you are a light enough rider you can go for lighter weight wheels and bars and such,
Quoted: 232 Post(s)
Liked 42 Times
About the Vado, I may have a hard time with spending 4 grand on a metal bike...
I realize that manufacturers of e-bikes don't like to tout the heavier weights, but where on the page does one find the weight of these bikes?
Clark W. Griswold
Liked 4,133 Times
Generally you don't find the weights and if you do find weights RUN don't walk to the exit unless they have a picture of a complete bike as you would purchase from a shop on a scale you want to be very skeptical of their weights. Keep in mind they want to sell you something so the lower the weight the better so if they leave out a thing or two or it is a pre-production sample or something like that and the weight is off it will make it more enticing but it won't actually help the weight. Go down to your local Specialized dealer and try out the bikes, that is more important than any stated/claimed weight could ever be.
Quoted: 890 Post(s)
Liked 849 Times
OP, you're in socal and the "major's" offerings are within driving distance. Ask them to weigh the bikes, but don't expect anything to be carbon and/or less than 40 pounds for < $4K (probably $6K+). The only route there is a fringe manufacturer. Don't despair, friends/relatives have had excellent success with lesser known companies as well as DIY.
Quoted: 144 Post(s)
Liked 317 Times
Good ebikes are considerably more than their standard equivalents and $4k CF ebikes seem few and far between, some have components not suitable for long-term parts and maintenance. Mine was $7k, discounted, but does hit the street @ 30#. Drop bars so I didn't bring it into the discussion.
Commuter
Bikes: Main Bikes: 2023 Trek Domane AL3, 2022 Aventon Level.2 eBike, 1972 Schwinn Varsity, 2024 Priority Apollo 11
Quoted: 308 Post(s)
Liked 427 Times
Seems like a Trek FX+ 2 is the closest to what you're asking for:
https://www.trekbikes.com/us/en_US/b...olorCode=black
I also replied inline below:
I think you could ride drop bars, but they would just have to be higher and further back than is typical, like on a touring bike. "Lightweight" to someone used to unpowered bikes is not going to happen unless you're giving something else up. Most eBikes are in the 60-80 lb. range. Motors are heavy and batteries are heavy. (even lithium)
This is all doable.
Since the weight will likely be more than you're expecting, you may find you want to use the motor more than you thought, for example coming up to speed from a stop.
Likes For Smaug1:
Just pick any bike you like and add a mid-drive kit like this one from CYC Motors:
https://www.electrifybike.com/collections/cyc-motors
I have been using the X1 Stealth for 2+ years on pedal assist only and the mid drive has been flawless (4500+ miles and counting). You can set the amount of assist you need via their App. With my settings, I can get between 24 to 31 miles per charge using a small 52V 10Ah battery (which fits in a saddle bag).
Total weight of mid drive and battery is less than 15 lbs (10 + 5).
Quoted: 12206 Post(s)
Liked 1,503 Times
If you want carbon, expect to pay for it..
If I could get a new bike, this is at the top of my current wish list:
https://www.trekbikes.com/us/en_US/b...rCode=bluedark
Clark W. Griswold
Liked 4,133 Times
Or for the same price (on sale) but way better spec'd and with a belt drive and Enviolo hub so technically almost zero drivetrain maintenance:
https://www.gazellebikes.com/en-us/g...ame=frame-high
Commuter
Quoted: 308 Post(s)
Liked 427 Times
Roadster models (which you may have been thinking of) have flat bars, but only one speed, which doesn't necessarily fit with his wish to only pedal for climbing. (but maybe so)
https://ride1up.com/product/roadster...avel-roadster/
Quoted: 232 Post(s)
Liked 42 Times
Quoted: 890 Post(s)
Liked 849 Times
If you do your own wrenching, a mid-installation will be duck soup IMO. Many (most, all) shops won't do the conversion because liability is a consideration, but there are individuals who advertise the service (or try Bike Craze in Orange).
The installation is straight forward and takes between 1 to 2 hrs. These are "install yourself" kits so any proficient bicycle mechanic can install for a fee. Personally, I wouldn't pay more than $100.
