Question about kickstand
Hi, I am a rookie of bikes. I bought my bike (Electra Townie 7D Step-Thru) several days ago and found that there's something wrong with the kickstand.
If I use the kickstand normally, it will become loosened. I checked the manual and the website, it seems there are no missing parts.
Is it by design? Is it possible that the thread locker was not applied when they assembled it? What should I do to fix it?
I live far away from the store, so I want to solve it myself if possible.
Thank you for understanding my poor English.
Expired Member
Quoted: 3782 Post(s)
Liked 5,769 Times
If it's coming loose from the frame, tighten it. If the leg is loose in the bracket, that's something else. Please clarify.
Thank you for your reply.
The kickstand of this bicycle is near the pedal, and it's a concave hexagonal nut with a small washer (circular). However, the hole through which the nut passes is an ellipse about one-third larger than the washer. Besides these, there are no other parts. After tightening the hexagonal nut, whenever I use the kickstand a few times, the washer and nut become loose, and the washer also wears off the paint around the hole. It seems like there is some movement space provided for the washer and nut by the hole.
Expired Member
Liked 5,769 Times
If this is what you have, it doesn't seem to have any additional parts.
Clark W. Griswold
Quoted: 4488 Post(s)
Liked 4,161 Times
Single bolt kickstands which are standard near the bottom bracket frequently come loose. Make sure it is properly torqued and that should help but if it is still coming loose a threadlocking compounded in a medium strength (typically blue in color) can help. You could also try a different kickstand if it is not Greenfield replace it with a Greenfield. If you do have the direct mount 18mm or 40mm mounts than that is going to be the best way to mount a kickstand.
If you wish to post pictures get involved with the various active threads on this forum and get 5+5 posts (5 per day 10 total) and you can post pictures and links and also get involved in the forums which are quite awesome.
Likes For veganbikes:
Likes For Paul_P:
Quoted: 6344 Post(s)
Liked 4,943 Times
What does the shop say about it? You just bought the bike, I'm sure they'll at least make certain there isn't any reason for it behaving like that. They've made Townies in various models for many years. Perhaps they've changed the part and maybe they need to know if it's not up for the job. But if you don't go tell them, it'll just take a longer time before they find out.
If it is just the bolt going into the threaded body of the kickstand, then I might put thread locker on it. But only after exhausting what the bike's dealer was willing to do.
Welcome to BF.
Oh, I found your pictures. All you have to do is let us know you uploaded them to the Gallery and we can find them...
This and the other pic's are here.......... https://www.bikeforums.net/g/album/34043979
Welcome to BF.
Likes For Iride01:
Bikes: Schwinn Broadway, Specialized Secteur Sport(crashed) Spec. Roubaix Sport, Spec. Crux
Quoted: 187 Post(s)
Liked 178 Times
The hole is slotted by design so that a kickstand can be placed correctly so it does not interfere with the crankarm or your foot while pedaling. You could add a larger diameter washer under the head of the bolt and even a split lock washer. The addition of thread locker like locktite to the threads where they enter the kickstand would also help.
Sir Mark, Knight of Sufferlandria
Likes For Black wallnut:
Quoted: 524 Post(s)
Liked 688 Times
Likes For wheelreason:
Quoted: 7696 Post(s)
Liked 3,607 Times
All these replies have been really useful and helpful
Is this BF?
Is this BF?
Likes For Maelochs:
Expired Member
Liked 5,769 Times
I credit the OP. He asked a reasonable question and didn't argue with those who tried to help.
Likes For shelbyfv:
Quoted: 18557 Post(s)
Liked 15,965 Times
Quoted: 598 Post(s)
Liked 516 Times
Make sure you have plenty of threads left to hold well after you add a washer. You can take the bolt to a hardware store and get a longer bolt if needed. Use some removeable thread locker on there or any fingernail paint will work in pinch. If it has that plate like the red one above and isn't clamping directly to the frame tighten the snot out of it. Don't overtighten if it is clamping directly to your chain stays.
I went to the bike store and they tightened it, but it seems screwed too tight, and the washer may be dented. Thank you for providing an alternative repair method.
Bikes: Trek FX 7.3, Specialized Roubaix, Orbea Terra, Aostimotor S17 ebike, Huffy RedRock (first bike)
Quoted: 227 Post(s)
Liked 347 Times
The proper way to fix a kickstand is to unscrew the bolt and throw the whole thing away. Then you have tons of other solid methods to prop your bike without extra headache.
Likes For XxHaimBondxX:
Likes For winwin96:
Quoted: 3625 Post(s)
Liked 3,047 Times
Thread lock PLUS a lock washer for good measure!
Likes For smd4:
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 276 Post(s)
Liked 461 Times
^ It is missing the lock washer. There should be one on top of he flat washer.
Likes For biker128pedal:
Method to My Madness
Quoted: 2054 Post(s)
Liked 1,548 Times
Likes For SoSmellyAir:
