What's your strategy for going down a steep paved hill?
where you will have to either slow to a crawl or stop dead at the bottom due to the potential of cross traffic, stop sign or lights?
No cars on the hill.
Do you slalom down to try and reduce speed while applying brake? I figure this wears tires unevenly; or just go straight and feather brake all the way down which must burn more rubber and cause more brake wear?
Ride down. Stop as needed.
Likes For phughes:
Straight down with brakes on. If it's somehow really really long I might go on/off/on if I am worried about heat. I would then plan my route to not go that way, since I have fun carrying speed down, through the hill, and up the next.
Rider. Wanderer. Creator.
Bikes: Bike Friday All-Packa & Pocket Rocket, Cinelli Hobootleg, Zizzo Liberte, Ozark Trail G.1 Explorer
Liked 1,522 Times
If it's a shorter hill, I send it and then hang my butt off the back of the saddle and stoppie at the bottom.
If it's a longer hill, I used to tuck and send, but these days I scrub speed by alternating front and rear brakes in order to give the rims time to cool off. Brake wear? They're consumables. So consume.
JohnMFlores.com | YouTube: JohnMFlores
Insta: JohnMichaelFlores | TikTok: @johnnymotoflores
Slalom down? ![Twitchy](images/smilies/twitchy.gif)
![roflmao](images/smilies/roflmao.gif)
Likes For shelbyfv:
Bikes: Hardrock touring bike
Liked 123 Times
I'm most concerned about what sorts of sand or debris might be present on top of the pavement and therefore my chances of not wiping out as I try to slow down then stop before reaching the blind crossroad at the bottom.
I had to do this once last summer with my loaded bike and the fairly short steep descent involved a lot of praying
I know it might sound like an idea but try it once and see how it turns out.
You may wobble all over the road but it's not slowing you down. You'd have to be skidding tires to do that. You have to brake anyway, just ride down like a normal person.
Liked 2,633 Times
Should Be More Popular
Liked 9,555 Times
Likes For datlas:
Perhaps spend some time riding instead of asking questions about how to ride. That way you will learn the basic fundamentals usually learned in childhood.
Likes For phughes:
Happy With My Bikes
Liked 2,749 Times
Cling to my disc brakes like a gerbil on greased teflon.
I am potato.
Liked 1,863 Times
You don't want to feather or drag your brakes. The heat build up leaves less margin for converting motion in to heat. You'll find that at some point, when you get to the bottom & really need your brakes there is no more margin left to convert any more energy and the heat saturated brakes simply won't work when you need them most.
Brakes on. Slow. Brakes off. Cool. Repeat.
Likes For base2:
When you slalom skiing, you're using the edges which are the skis brakes. Nothing like the bike tires.
Likes For Camilo:
Sunshine
Liked 8,003 Times
Lopsided biped
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Liked 161 Times
I do it like I've always done since I started riding (pre-teens, coaster-brake cruiser back then): crest the hill and let 'er rip; half-mile double-digit grades. Had to get the maximum fun going down, because pushing the bike back up was always a drag.
I usually start a thread at the top to gauge how to start the process. About halfway down, start another thread to check in and see how my progress is comparing with others. Then, just before I hit the stop sign at the bottom, it’s one more thread just to be safe. I might even throw a picture or poll in this last one for the sake of thoroughness.
For additional speed, grab a rock at the top of the hill to give you more potential energy and drop it off at the bottom once you are safely clear of the intersection.
Liked 8,293 Times
Why is this even a question? Clearly, the best way to stop at the bottom of the hill is with a hockey stop.
