How do I pull my Segino AT cranks?
Older, but wizened
Bikes: Purchased a Soma "Speedster" in May '08 to replace my cludged-together Peugeot "UO-8" with alloy upgrades which will be up for sale on craigslist in the near future.
I thought this would be a simple matter of using a hex wrench to take the dustcap off the cranks and use a standard crank tool for the removal. However, when I turn the hex wrench about half a revolution counter clockwise, it starts to tighten up again. I see that there are slots in the dustcap on either side of the hex bolt (see attached image). Is there some special tool I need to get or is there something I need to do differently? As always, I appreciate y'all coming to my rescue. Thanks.
All generalizations are false.
Retrogrouch in Training
Those are probably self extracting. The "dust cap" is really a ring that threads into the extractor/dustcap threads so that as you back out the fixing bolt, it pushes the crank off.
Quoted: 2026 Post(s)
Liked 1,096 Times
Yep, you have an "Autex" crank bolt set. As recommended, keep unthreading the hex bolt and the crank arms will come off.
BTW, it's a nice feature and Shimano adopted a very similar arangement with it's Ultegra and Dura Ace "Octalink" crank sets.
