which brake lever to use?
Quoted: 321 Post(s)
Liked 7 Times
I want to put caliper brakes (dual pivot) on my front fork. Should I use a canti lever or V-lever? (on a flat bar racer.)
Mad bike riding scientist
Quoted: 6286 Post(s)
Liked 4,329 Times
Stuart Black
Stuart Black
barnfullagts
Bikes: GT BI Ti/BI Steel - Edge Ti and Steel Xizang Ti and Psyclone Steel
I'd try to find a pair of NOS Ritchey Logic brake levers if I was you. Nicest hand fit of any upbar lever.
Bikes: homemade cyclocross, 2005 KHS Flite 100 frame + assorted parts
Cheap Tektros are handy because they can be adjusted for both.
Commuter
Bikes: Jamis Coda Comp, Kona Killuaea
I have the same question. Apollo, how does one adjust the Tektros levers for caliper brakes?
Quoted: 3450 Post(s)
Liked 420 Times
I'm building a bike with the same setup at the moment and I bought some Shimano levers designed for the job. V brake levers pull more cable so if you used them the pads would move from rest to the rim rather quickly but you wouldn't have much leverage power. Using levers designed for dual pivot on V brakes would have the levers reaching the handlebars before full brake force was reached.
Regards, Anthony
Regards, Anthony
Regards, Anthony
Regards, Anthony
