No braze ons !!!
aka old dog
No braze ons !!!
The old bike im fitting out for a winter/ rain commuter has a near perfect re-paint job under all the grease & grime, but it has no braze ons , id like to fit 2 water bottle cages 1 to the down tube & 1 to the seat tube but I dont want to make a mess of the paint job & I dont want it to look too clunky, I ,spose to be in period it should have one of those double cages that used to fit on the h/bars, have,nt seen any around for yonks. Anybody got any ideas how to fit my b/cages onto the down &seat tubes without braze ons .Thanks
Bikes: '87 Paramount & '02 Scapin EOS3
Quoted: 16 Post(s)
Liked 13 Times
How about on the seat? There are several cages for double bottles on the seat where a seat pack would normally hang. Out of the way and aerodynamically quite clean.
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
Oh I just might:
The Quick Cage™
Goes on any bike instantly, anywhere room is available on the frame or seat post. Great for cruiser bikes, BMX bikes, kids' bikes, and the serious commuter. The most convenient and cost-effective way to put a water bottle cage on a bike without braze-on lugs. Includes a 23 ounce water bottle with the Twofish insignia.
Bicycling Magazine's highest rating! July '96
see it here https://www.twofishunlimited.com/bike.html
The Quick Cage™
The Flying Scot
Location: North Queensferry Scotland and London (and France)
Bikes: Custom (Colin Laing) 531c fast tourer/audax, 1964 Flying Scot Continental, 1995 Cinelli Supercorsa, Holdsworth Mistral single speed, Dahon Speed 6 (folder), Micmo Sirocco and a few more
You can get band-on cages. Don't look pretty, but they'l do. Use tape to cover the frame so the band doesn't chip it.
My Flying Scot has no bottle cage bosses/ I hang a cage from the saddle loops
plus je vois les hommes, plus j'admire les chiens
1985 Sandy Gilchrist-Colin Laing built 531c Audax/fast tourer.
1964 Flying Scot Continental (531)
1995 Cinelli Supercorsa (Columbus SLX)
1980s Holdsworth Mistral fixed (531)
2005 Dahon Speed 6 (folder)
(YES I LIKE STEEL)
2008 Viking Saratoga tandem
2008 Micmo Sirocco Hybrid (aluminium!)
2012 BTwin Rockrider 8.1
(YES I LIKE STEEL)
Any decent mechanic should be able to drill holes in your old steel frame and set water bottle mounts into the holes. Be sure that you drill a pilot hole (a small one) first so that when you drill the large one the bit doesnt slide down the side of the round tube and destroy your paint. The threaded inserts are fairly cheap, around $3 and the labor at a shop is around $20. A special tool is needed for setting the inserts so I would strongly recommend letting the LBS do it.
-Ryan
-Ryan
Originally posted by greywolf
The old bike im fitting out for a winter/ rain commuter has a near perfect re-paint job ....snip....... but I dont want to make a mess of the paint job & I dont want it to look too clunky, /snip
I am a lonely visitor
Bikes: Michelle Pfieffer, the Carbon Fiber Wonder Bike: A Kestrel 200 SCI Repainted in glorious mango; Old Paintless, A Litespeed Obed; The Bike With No Name: A Bianchi Eros; RegularBike: A Parkpre Comp Ltd rebuilt as a singlespeed.
Zefal makes a plastic gizmo called the Gizmo. It clamps around the tube and allows for a bottle cage to be mounted. It is probably about as paint friendly as anything you will find. I've seen them at my LBS. I don't know who carries them online.
Click here for Zefal. Then choose "cages" and scroll to the bottom of the page.
Religion is a good thing for good people and a bad thing for bad people. --H. Richard Niebuhr
Check this out:
How to attach water bottles without braze-ons.
Or, of course, you could drill holes in your frame.
Don't tell me you would rather have this ****
or this
attached to your bike rather than factory looking bottle mounts that were installed in the frame? Anyone who can use a drill can put these in without damaging the paint.
-Ryan
or this
-Ryan
Well, the Zefal Gizmo doesn't look quite so cludgy. I stole the pic from the Nashbar site. You can buy them there.
-Ryan
-Ryan
You could use a drill press to get a whole exactly centered, and would have no problems positioning the drill then. Could be done with a hand drill to but would be a bit harder.
It is best to use a drill block or jig to get the holes properly aligned and spaced, this is not a good thing to drill freehand. You also need a drill stop to keep from pushing through the hole and damaging the other side of the tube. This can be done without damaging the paint.
Wide Load
Bikes: Trek 7300
Seems to me you'd need a right angle drill or a flexible shaft on a moto-tool, plus a drill guide that could be clamped in place. Those aren't cheap tools so I'd say the LBS is the way to go unless you already have the tool or are planning on upgrading a lot of old bikes
John
John
Most frames are big enough for a hand drill using a guide or a pilot hole to prevent the bit from slipping out of place. If a drill won't fit then a dremmel tool with a bit in it should slide in just fine. And a drill press, well thats applesauce.
-Ryan
-Ryan
serial mender
Stop the drill! I have read that it is a bad idea to drill directly into a frame. There is a rather significant tendency that the threads will get stripped during normal use. I suppose braze-ons are stronger because they add extra metal into which the screw goes. I think you are stuck with some of the different band solutions already mentioned.
Cheers,
Jamie
Cheers,
Jamie
Cheers,
Jamie
Cheers,
Jamie
aka old dog
Thanks for your suggestion , web-sites & feed-back its given my brain some ideas to work on ! The rive-nut idea is good but I would convince my-self that I`ve put it in the wrong place , its not quite straight you know how it goes !
Thanks again
Thanks again
Spin Forest! Spin!
Bikes: I used to have many. And I Will again.
Quoted: 7 Post(s)
Liked 11 Times
^^^ Yes, some CF frames use rivets to hold the cable stops. Of course, it wouldn't be my 1st choice if I was shopping for a CF frame and saw rivets instead of molded in place bungs/bosses.
Quoted: 2027 Post(s)
Liked 1,099 Times
Here is just what you need if $40 isn't too much of an investment.
https://www.biketoolsetc.com/index.cg...item_id=SN-JIG
I like bikes
Bikes: Raleigh M20
I usually take a normal water bottle cage and hose clamp it on the frame. Also it won't hurt your paint if you wrap electric paint where the hose clamp will go.
