how do i remove my handlebar grips w/o destroying them?
Bikes: Surly CC, Raleigh Team Pro, Specialized Rockhopper with an xtracycle
wd40 and work it off??
Bikes: Land Shark, Level Professional, Tsunami singlespeed, Giant Reign 1
if you use (Maruni) rubber cement, Bestine works wonders. It's available at most art supply stores.
señor member
Bikes: Malvern Path Racer, Schwinn LeTour, Follis, Bridgestone 400 (RIP), concord 2sp
Plain old water has always worked fine for unglued ones for me, or ones that were stuck on with hairspray. From a spray bottle works best for me, but I've just pulled up an end and drizzled and smooshed around with success as well.
Doesn't WD40 leave an oily residue?
Bike fiend.
Bikes: Giant STP SS, Trek 400 (Fixed), 1970's Orion, Huffy Flatbed BMX, Vintage Huffy Kids Cruzer, Vintage Sears Cruiser, Trek Prototype Frame (fixed)
I always use Denatured Alcohol (Or everclear), works great, evaporates quickly.
drunken ass
Bikes: davidson track bike, cecil walker track bike, conversion fixie polo bike
i jsut use rubbing alcohol. Take a butter night, dip it in the alcohol and slide it in the grip and rub the knife all the way around the bars. **** slides right off.
ride fast...take chances
Bikes: 2004 titus switchblade, '96 marin rocky ridge ht ss; '91 marin rocky ridge ht (soon to be fully rigid); 2006 motobecane grand sprint; '06 bianchi pista; '83 (?) haro freestyler - neon green.
if you have access (bike shop, service station, buddy's house)...the compressor is the best. i've done them all. it's the easiest, fastest, and requires no sloppy liquids to clean up off the garage floor.
Guest
Originally Posted by gregtheripper
also you can use a screwdriver to leverage against the grip. i usually roll them off partially like a condom and then use brute force.
Use rubbing alcohol instead of screwdriver and peel off as describe above.
S/F,
CEYA!
Gone, but not forgotten
Bikes: spicer fixie, Haro BMX, cyclops track, Soma Double Cross, KHS Flite 100
Originally Posted by 1fluffhead
I prefer using chopsticks to screwdrivers because it will not scratch the hell out of your bars.
air compressor works great,
but when at home i sometimes use a plastic syringe to squirt soapy water/whateva way under the grip..
same idea with wd40 and the long nozzle, but a littel cleaner
^^ yes
Plastic syringes are handy as hell for other stuff too. I originally got one from my dentist to wash out the bloody holes where my wisdom teeth once were, and now I use it three or four times a year. It's surprising how often a tiny high pressure jet comes in handy.
elite
Bikes: track, road, cross, fixie
roll it off. usually works with ourys and moderately loose grips. start inside, and rolll baby. and lube the outside of the grip so it slides easily.
