Coaster Brake Question
Bikes: Too many to count. Changes on a frequent basis.
I found a single speed coaster brake bike, is there a way that I can remove the coaster brake arm and be able to ride it like a single speed and then put rim brakes on.
Geek Extraordinaire
Bikes: Bianchi Advantage Fixed Conversion; Specialized Stumpjumper FS Hardtail
I would guess no. You would probably have trouble with the hub not catching when you start to pedal. But thats just a guess. Try it and let us know.
I'd rather have a bottle in front of me than a frontal lobotomy.
Sintesi Conversion Serotta Track
coasterbrakelockup
Bikes: surly steamroller w/coaster brake, electra single speed cruiser, specialized rockhopper commuter, no-name single speed folder, 700c ultimate wheel, 24" unicycle, specialized bmx lsd, single seat single speed huffy tandem, pink upsidedown parade bike
You can ride them as freewheel, but not by removing the arm. Search for "freecoaster". BMX/flatland riders do it all the time because it is the only way you can coast backwards without having the cranks move. You basically disable the brake parts but leave the rest the same.
Bike fiend.
Bikes: Giant STP SS, Trek 400 (Fixed), 1970's Orion, Huffy Flatbed BMX, Vintage Huffy Kids Cruzer, Vintage Sears Cruiser, Trek Prototype Frame (fixed)
I would assume that all you'd have to do is remove the two brake pads on the inside, and rea-assemble. Just leave the arm off when you do it.
Try it and see! The single-speed ones are really not that complicated on the inside.
Perineal Pressurized
Disassemble the left hand side of the hub and remove the brake pad component.
This might help
https://www.troubleshooters.com/bicyc...d_overhaul.htm
This might help
This is Africa, 1943. War spits out its violence overhead and the sandy graveyard swallows it up. Her name is King Nine, B-25, medium bomber, Twelfth Air Force. On a hot, still morning she took off from Tunisia to bomb the southern tip of Italy. An errant piece of flak tore a hole in a wing tank and, like a wounded bird, this is where she landed, not to return on this day, or any other day.
yeahh, becky
Bikes: 1990 Kotter Albuch, 2005 Empella Spaar Select Cross, 2007 Ridley Aedon
At one time, our resident coaster brake expert jimv gave some tips as to disabling the mechanism, which is what you need to do. Search for it, he put up some great diagrams. I looked and didn't see anything but try jimv
for more.
for more.
THIS SPACE FOR RENT
Pulling out the brake pads isn't going to allow you to backpedal. Not that you need to, but if you accidentally do it you might get some awful metal on metal action.
Also, coaster is rad, and most old coasters are laced to steel rims. Steel rims + rim brakes + wet weather = ruptured meatsacks.
yeh, the rims are steel, would a 700 rim fit on a 26 inch frame. By the way, the bike is a BMAC All Pro made for Kmart, it is rather old but in very good shape. I was looking at the welds( or lack of ) it looks like it glued or just spot welded.
THIS SPACE FOR RENT
I have futzed with a few of these down at ye olde co-oppe, it's a perfectly fine old gas pipe, lead sled cruiser but I would not put money unto it other than grease, tires, etc... Is it even drilled for a rear brake?
yes, it has a rear reflector on it right now. It even has a cool looking chainring cover. Solid cover with painted chainring holes.( weird huh) i will post pics tomoroow.
