how long to soak chain?
A thousand threads on cleaning a chain, but seemingly none telling how long a chain should be soaked in simple green to remove all the crap! Half an hour, a day, what?
Bikes: Time RXRS, Specialized Stumpjumper FSR
Just received Bicycling today. They have an article about myths and one of them is chain soaking. They actually do not recommend soaking a chain as this results in removing lube from the inner parts of the links where it is almost impossible to insert it back.
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
Brought to you by Shimano?
Shimano doesn't want chains lasting very long so you can buy their stuff more frequently?
I read AAA's monthly mag and it said don't put denatured alcohol in a car to help it pass smog...it's just an old wives tale. But it really does work.
Honorable Member
I use mineral spirits, but this should work with simple green as well.
I put my chain in a coffee can. Big recumbent chain so big coffee can, WITH A LID due to spatter.
Cover the chain with degreaser of choice.
I use an old variable speed orbital sander upside down and set the coffee can on the pad. Turn the thing on and listen to a few tunes while holding the can on the sander. Really gets the grit out!!
so much for physics
Bikes: Scott CR1 team, Fuji track pro, NYCbike, Cannondale, Free Spirit, GT Edge
About the only thing t worry about and it is purely cosmetic is if you soak a chain in citrus cleaners or other high acid degreasers you'll discolor your chain. Doesn't hurt it just "tie dyes" it.
Bikes: Giant TCR Comps, Cdale R5000, Klein Q-Pro, Litespeed Siena, Piasano 105, Redline Conquest Pro, Voodoo Bizango, Fuji Aloha
Originally Posted by JanMM
So, Bicycling has joined the endless chain-cleaning thread.
I can understand why MTB riders who can't resist mud would need to soak their chains. Roadies and paved trail riders should not have to soak their chain ever. Clean it more often, and it won't get that groady. I use a little (very little) Brakekleen, Costco car towels and one pipecleaner to do the chain after every ride. I do it on the bike. Because the chain is relatively clean, it only takes a few minutes, and my 'bent has a 9 1/2 foot chain. Also, I use only a small amount of lube. My rig always works flawlessly. bk
OTOH, if the chain has been ignored for 2000 miles, just replace it (and probably the cassette) if it is out of spec for stretch. Soaking a chain will not improve a worn out chain.
Most problems with chains are due to lack of regular maintenance, regular checks and so on.
